Page 5 of 61 FirstFirst 1 2 3 4 5 6 7 8 9 10 ... LastLast
Results 81 to 100 of 1211
  1. #81
    Langs die rivier, op n berg
    Thanked: 6434
    Atlantis
ID:	321728Click image for larger version.
  2. #82
    Thanked: 6434
    Before and after
  3. #83
    Strand
    Thanked: 171
    Ooh, dit lyk baie nice.
    2021 Ford Ranger 2.2 XLS Auto
  4. #84
    Robertson/ Larissa, Greece
    Thanked: 10348
    Lyk lekker Reenen. Ek dink jy gaan nog groot plesier uit daai Patrol kry!
  5. #85
    Jul 2010
    Thanked: 98
    33'' is net lekker!
    Hier is hoe myne gelyk het...
    David
    There are no known unknowns
    Patrol 4.8 GRX & GS1200
  6. #86
    Thanked: 20097
    Dave will remember this wagon.
ID:	322739   Click image for larger version.
  7. #87
    Brits
    Thanked: 475
    For R15k I would just put a turbo on the L28......probably the smoothest Old 6cyl ever made.
    Renault Duster 1.5Dci 4WD
  8. #88
    Thanked: 20097
    Quote Originally Posted by JuanB View Post
    Julle Brits mense tog........
    The problem is there are no off-the-shelf manifolds for a turbo so Reenen, while competent enough, would need to waste a month having stuff welded and fabricated.
    The L28 is pretty flat when it comes to torque at low revs and the wrong exhaust makes it worse. Only a supercharger will provide punch off the bottom.
    Or else we must have a look at split branch headers.
    I see the Yanks do a Y-split manifold on the V8's where they cross-match exhaust ports to get extra extraction and use long header pipes for more torque.
    Grips can maybe add details?
    What I would do.......
    RD28 straight six diesel, and a variable nozzle turbo. Screw in fuel adjustment until it starts pushing smoke and then a quarter turn backwards. You'll have around 110kW at 4,400 rpm and over 300
    Nm at 2,400 rpm.
    So something that generates a nice fat power band between idle and over 4000rpm. That's similar to the L28 Turbo used in the 280ZX turbo car. And it will use half the fuel.
    4,400 rpm is more than enough for playing at AD.
  9. #89
    Brits
    Thanked: 475
    Nm at 2,400 rpm.
    So baie opsies......kyk n diesel is lekker maar ek mis die klank van n mooi petrol( SR20, L28 etc)
    Jy weet de wildt val ook onder madibeng ne
  10. #90
    Jul 2010
    Thanked: 98
    Thumbs up
    I like the lift from moving the axles from on top to below the leaves!
    David
  11. #91
    Thanked: 20097
    Ja ek het 'n 2.8 Skyline gery vir jare en voor dit het ek baie geld gemors oo Ford V6s.
    Twee Land Rover V8s, en tans 'n lekker Pentastar 210kW V6.......
    Ek hou van petrol, maar niks klop 'n vris turbo diesel vir off-road nie.
    Behalwe vir diep sand.
    Ja jong ons ou munisipaliteit. Darem kry ek krag van Tshwane maat, so geniet jou diskonneksie weens wanbetaling..........
  12. #92
    Thanked: 6434
    Nm at 2,400 rpm.
    Ja, so met daai selfde redenasie kan ek die Terano 2 engine en gearbox wat in stoor le, wat ek spesiaal vir hom opgebou het, daar insit
  13. #93
    Thanked: 20097
    Ja as ek een in die stoor gehad het sou ek ook.
  14. #94
    Thanked: 6434
    Wie het vir my n webber 36, ek sal 2.8 petrol hou vir eers, maar van kaap tot mosambiek met boot in tou in junie/julie met die nikki carb gaan my dood maak?
  15. #95
    Thanked: 20097
    Nie dood nie, net arm. Baie arm.
    TD27 or RD28T conversion will pay for itself in one trip.
  16. #96
    Thanked: 6434
    Die td27ti engin en gearbox wag in stoor, maar die L28 groei op my.
  17. #97
    Thanked: 20097
    Doen my 'n guns ek kyk hoe verskil die TD27 en L28 bellhousing/gearbox bolt patterns op die block asb?
  18. #98
    Atlantis
    Dis 'n mooi ou Patrol daai.
    Die fotos herinner my aan die laat '80s/vroe '90s toe my swaer so Safari 2.8 bakkie met 'n turbo gery het. Die hele familie was die Des vakansie na Onrusrivier en het ons te lekker met daai ding op die duine gespeel. Die dik rubber mat wat agter in die bak was, was gesleep met 'n tou agter die bakkie duine op en af. Daai Safari het darem krag gehad! Ek dink die 2.8 is seker nog een van die beste engines wat Nissan/Datsun ooit gebou het.
    Life is a journey, not a race. Enjoy it!
  19. #99
    Thanked: 6434
    Quote Originally Posted by VWSyncro View Post
    En daai engin is gecopy op die mercedes 280 se motor, toe prince nog onder lisensie vir nercedes engins gebou het
  20. #100
    Thanked: 6434
    As ek eendag die engin trek sal ek kyk, maar hulle verskil redelik
  1. Terug uit Kaokoland...
    By Mudder in forum Namibia
    Last Post: 2014/09/08, 09:03 AM
  2. My nuwe speelding het opgedaag!!
    By Frans Reichert in forum Cameras & Photography
    Last Post: 2013/03/19, 03:56 AM
  3. Nuwe rekenaar - data oordrag
    By CoenraadB in forum The 4x4 Pub
    Last Post: 2013/02/15, 08:26 AM
  4. 4.2d Patrol - Consumption & Maint. Costs?
    By Rooster1 in forum Nissan
    Last Post: 2008/04/22, 05:13 PM
  5. My nuwe Speelding
    By Hobo in forum Camping, Fridges, Accessories
    Last Post: 2007/04/02, 10:31 AM
