Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers - Page 6
Page 6 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 101 to 120 of 386
  1. #101
    Thanked: 618
    Little bit of topic guys.
    But why can't Benton come up with something like this?
    Eric, I think you need to speak to Developers of the Benton range and tell them its time to keep up with the Jones's and to make us something like this.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  2. #102
    Klerksdorp
    Thanked: 382
    I've tried!
    But they can't quite see the need for it.
    What we should be receiving anyday now is a far smaller DC-DC Charger, nominal 4.5A, max 6.5A, small unit and very well priced too. We've been testing thjis unbit since June last year. We're hoping for about R850 selling price or thereabouts but will only know the true figures when stock arrives towards the end of this month. Should be ideal for trips and won't fry the battery. Easy & quick to install.
    It will be pre-set to a range of DC outputs from 13.5 - 14.2v.
    Will announce the news as soon as it arrives.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  3. #103
    Thanked: 618
    Quote Originally Posted by Nico.Swart View Post
    This Ctek little bugger is sommer rigged to quickly and hassle free accept a charge from solar panels.
    Nico Swart
    ZS6NJS
  4. #104
    JHB
    I have a BX1 and a Rechargeable Sealed Lead Acid Battery (FM12170C) 12V15Ah/20HR from a Generator.
    Can I use the BX1 to charge it?
  5. #105
    Klerksdorp
    Thanked: 382
    Yep!
    The BX-1 is good for charging batteries of capacity ranging from 1.2 to 120A/Hr rating.
    -F_D
    White Fang:
  6. #106
    JHB
  7. #107
    Thank You Family_Dog !
    Benton BX-2 Received and already put to work !
    2005 Ford Ranger SuperCab XLT 4000V6 Manual 5 Speed 4x4
    Petri
    1997 Ford Explorer XLT 4.0 L SOHC V6 Auto AWD 4x4
    Pieter
    2013 Audi Q5 2.0 TDi S-Tronic Quattro
    Daily Drive
  8. #108
    Klerksdorp
    Thanked: 382
    Good to hear! We had a sudden run on them the past few days, must be the cold weather...
    -F_D
    White Fang:
  9. #109
    May 2013
    Sabie
    Thanked: 165
    Hi Family_Dog
    I need a charger for my motorbike and for my Hilux that is not driven very much during the winter months due to being on fire standby (forest fires). I can only do short trips, but my batteries take a pounding as these trips are not enough to keep them in good shape.
    I need to keep the batteries on charge permanently. What models would you recommend.
  10. #110
    Klerksdorp
    Thanked: 382
    The BX-1 is fine for your car and the BX-4 for your motorbike, both these chargers can be left permanently connected. PM your email address to me and I'll send you the details.
    -F_D
    White Fang:
  11. #111
    Nov 2006
    Perth, Australia
    Thanked: 216
    Hi FD.
    My little Benton BX-1(m) is still going strong after all these years. THANKS !!!
    One question though. It says in the manual that this unit is good to charge up to 120AH batteries.
    I have two 110AH batteries in parallel in the nose cone of the caravan. I presume I cant use the BX-1 to keep these charged?
    I have to confess, I did do it and it seemed to work. During the day and evening when sitting at a caravan park we might use 10 to 20 Ah from the batteries. Then when we go to sleep I was hoping the Benton BX 1 would be able to replace that back into the batteries.
    Any advice. (I dont really want to spend more money on another 240V charger, but if I have to then so be it.....)
    I only have a couple of LED lights running off of them, the fridge is plugged into the 240V caravan park supply.
    JD
    No more Jeeps for me for a while.
    2009 Ford Ranger PK 3.0
  12. #112
    Klerksdorp
    Thanked: 382
    JD, it will work while the batteries are still in good condition and are exactly the same type and in the same state of charge. But it is not to be recommended - see here:
    Don't do this!
    -F_D
    White Fang:
  13. #113
    Nov 2006
    Perth, Australia
    Thanked: 216
    Ooo grote griet !!!
    Nou hoe nou gemaak?
    From the Hilux forum am I to understand that I can draw power from both of the batteries at the same time, but when I charge them I should somehow do them each apart from the other?
    Should I install some sort of switch so that the Benton only charge one at a time?
    I wonder if there might be a electronic device that can do the 'switching over' automatically?
  14. #114
    Klerksdorp
    Thanked: 382
    In short:
    Remove the links connecting the batteries in parallel.
    Charge one or the other - only.
    If the batteries are going to stand for any length of time, use one charger per battery rather than play around with switches, electronic or mechanical, which simply add unwanted resistance to the charger leads.
    -F_D
    White Fang:
  15. #115
    JHB
    Just ordered another 2 BX1's my dads going away for a month so wanted another one for his BMW and I have been meaning to get myself one.
    Thanks again Eric
    Sent from my GT-P5100 using Tapatalk 4
  16. #116
    Klerksdorp
    Thanked: 382
    Thanks Andrew, shipping tomorrow!
    -F_D
    White Fang:
  17. #117
    Sep 2013
    Humansdorp
    Hi Eric
    How does that BX-1 do with a silver calcium battery? I believe they need a slightly higher charge rate of 14.8v.
    Is it advisable to charge them in the AGM/sub-zero mode (14.7v) rather than the normal 14.4v?
  18. #118
    I've tried!
    -F_D
    Hi Eric
    Any news on this DC-DC converter?
    Price, availability?
    Johan van Rensburg
    2009 Mitsubishi Triton 2.5 - Rocksliders - Bashplate - Radio Replacement
    DiWa Offroad Caravan
  19. #119
    Plett
    Thanked: 53
    Would like to know as well.
    Dents are like scratches but with better stories attached
  20. #120
    Klerksdorp
    Thanked: 382
    Yep, these are available - PM me with your email addresses for more details.
    -F_D
    White Fang:
  1. Benton BX-1 Battery Chargers
    By JDeV in forum Camping, Fridges, Accessories
    Last Post: 2015/02/12, 06:05 PM
  2. Differences between a normal lead-acid car battery and a deep cycle battery.
    By Eggie in forum Vehicle & Technical Chat - General
    Last Post: 2012/01/25, 08:50 AM
  3. Battery chargers
    By Paul Dold in forum Camping, Fridges, Accessories
    Last Post: 2011/11/22, 05:14 PM
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. Automatic switch over system between battery charger and solar panels.
    By Uys in forum Camping, Fridges, Accessories
    Last Post: 2009/10/08, 03:32 PM
