Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers - Page 14
Page 14 of 20 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 261 to 280 of 386
  1. #261
    Klerksdorp
    Thanked: 386
    Jola, I stopped putting prices on the forum because they change with each shipment.
    Please email me at 'info at repcom.co.za' and I will forward the price list on to you.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  2. #262
    Please send pricelist to [email protected]
  3. #263
    Jun 2013
    Thanked: 2456
    Some questions if I may.
    Typical 4x4 set up, fridge, a few lights, charging headlight battery's and so on.
    Should you:
    Charge the battery's without the load or is it OK to run your equipment while the charger is connected.
    The question arises out of places like KTP where you have limited power time. ideally I would switch off the load or switch to 220 and recharge overnight but some items only work off 12 V.
    BMW R1200R
  4. #264
    Klerksdorp
    Thanked: 386
    Preferably without the load (a fridge draws quite a load) but the BX-2 should cope well enough. The BX-1 is a bit light for this.
    The overall charge rate would be a mean 7A minus whatever the load consumption is.
    -F_D
    White Fang:
  5. #265
    Klerksdorp
    Thanked: 386
    Quote Originally Posted by Jamie Seldomseen View Post
    Jamie, you have email.
    -F_D
    White Fang:
  6. #266
    Hi - it sounds like a really good charger, what is the price/cost of the BX2?
  7. #267
    Klerksdorp
    Thanked: 386
    Correspondence entered into!
    -F_D
    White Fang:
  8. #268
    Dec 2015
    Weskus
    Please send the price for the BX2, to [email protected], thank you
  9. #269
    Klerksdorp
    Thanked: 386
    - Done -
    -F_D
    White Fang:
  10. #270
    Krugersdorp
    I have a BX1 that I've had for about 5 years that died last week. Any ideas on where I could have it repaired? Could it be a fuse?
    2000 Toyota Hilux 2700i Raider DC 4x4 - OME, dual battery, Front Runner RR
    2006 Toyota Yaris Sedan
  11. #271
    Klerksdorp
    Thanked: 386
    It could be a fuse, but unlikely to only be the fuse. Have you had bad weather lately - lightning? Am electrical surge or lightning could blow the fuse but it may also have blown something else deeper into the electronic circuitry.
    With courier and repair costs being not that much lower than a replacement charger, you might be better off replacing it with the newer BX-1 Pro model.
    -F_D
    White Fang:
  12. #272
    Krugersdorp
    Thanks, will be in touch for a new one.
  13. #273
    Thanked: 758
    Quote Originally Posted by Family_Dog View Post
    -F_D
    My BX-1 has packed up on me recently as well. It had been used to keep my and my EX's race car batteries from dying in between races. It won't allow me to select the charge mode although the red power LED is on.
    I have the wiring with in-line fuse fitted to all of my cars so wouldn't like to have to buy three extra set-ups again because plugs are different if I go with another make when replacing the charger.
    What will the cost be to replace the BX-1 as I like the maintenance feature on the chargers.
  14. #274
    Thanked: 44
    Paul - it's more likely that the microswitch inside the charger is the problem. If you can open the charger you could spray it with electrical cleaner and it will work much better again.
    2013 Amarok d/c TDI 103kW 4motion
  15. #275
    Klerksdorp
    Thanked: 386
    Paul, you can definitely do as Phuma suggested. We have Mode switches for the BX-1 & BX-2 in stock as well, but 90% of the time a good douse with Contact Cleaner should sort you out.
    Be careful when you open the unit (you can modify an Allen key for that if you do not have the correct triangular tool) because the little red mode button loves jumping out into oblivion.
    Failing that, we do have stock of BX-1 Pro, but yours appears to be the older BX-1 or BX-1(M) model.
    -F_D
    White Fang:
  16. #276
    Thanked: 758
    -F_D
    Thanks for the advice Phuma and Family Dog. Yes it is the older BX-1.
    Luckily I have a good selection of the "odd" bits necessary to open most of the modern appliances that are designed to be disposable. I'll open it up and give it a good clean with contact cleaner which I'm using to clean all the plugs on my project SJ 410 wiring looms.
    I'll give feedback on the results of giving it a "bath".
  17. #277
    Jan 2015
    Vredenburg
    Thanked: 934
    Default Re: Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers
    I was once the proud owner of a Benton BX1 charger. It gave me amazingly good service over the past 5 years.
    However I am in the market for a proper charger again by unhappy circumstances.
    This morning when I looked to my trusty charger to condition the car batteries again...
    It along with the brand new motorbike battery and my 12v LED light and my multimeter has dissapeared. It turns out a "suspect" came into my most sacred garage and helped himself to my stuff when I topped up the dogs water before leaving home.
  18. #278
    Apr 2012
    Springs
    Thanked: 9
    Hi Family dog.
    You have p.m
  19. #279
    Klerksdorp
    Thanked: 386
    Replied to
    -F_D
    White Fang:
  20. #280
    Hi Eric,
    When I am out of the country for long periods, I put my deep cycle battery on the BX2 to.keep charged. When I was at home recently, I noticed that the charger only had the orange power light on. I disconnected one of the clamps and reconnected the clamp.and then the 12V and the 3 red charging status leds came on and went off again after a few seconds. I tried my other BX2 and it did the same thing. Is this normal or is there an issue with the battery?
    Life is a journey, not a race. Enjoy it!
  1. Benton BX-1 Battery Chargers
    By JDeV in forum Camping, Fridges, Accessories
    Last Post: 2015/02/12, 06:05 PM
  2. Differences between a normal lead-acid car battery and a deep cycle battery.
    By Eggie in forum Vehicle & Technical Chat - General
    Last Post: 2012/01/25, 08:50 AM
  3. Battery chargers
    By Paul Dold in forum Camping, Fridges, Accessories
    Last Post: 2011/11/22, 05:14 PM
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. Automatic switch over system between battery charger and solar panels.
    Last Post: 2009/10/08, 03:32 PM
