Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers - Page 12
Page 12 of 20 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 221 to 240 of 388
  1. #221
    Thanked: 498
    bought a new second hand trailer, it came with a 105 Ah deep cycle. The previous owners didn't use the trailer for a long time, at least a year if not longer and definatly didn't maintain the battery. Just connected the BX2 to it earlyer and nothing happend so probably under 8V, forced some amps in to it with supply mode for 10 minuts or so and then switched to regular charging, the empty light is now flashing so looks like it's charging normally. What do you think is the chance of getting some life back in to this battery and some useful Ah? If it works again it will only have to deal with a few LED lights for now, but know I will have to get a new battery eventually to run the inverter and 12V water pump.
    Sometimes you get lucky, but don't get your hopes up too high.
    Eggie.
    - apology to Edward Langley.
  2. #222
    Hillcrest, Malaysia
    Thanked: 5979
    Quote Originally Posted by Eggie View Post
    Yep.
    The problem with a compromised battery is not so much the reduced capacity, you can live with that and use it for an appropriate application.
    It's not a train smash if your 105AH battery is now a 60AH, as long as you only need and use it as a 60AH.
    The main problem is often that a compromised battery just doesn't hold a charge, even if you aren't using it. They tend to self discharge in a very short time.
    This is a very neglected aspect of battery performance for which I have never seen a manufacturers specification. ie, how does a batteries self discharge rate vary with battery age and condition and SOC.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  3. #223
    Feb 2013
    Thanked: 100
    As said, for the next few camps it will only be for a few LED lights, most will also be camps where 220V is available, will never ever go on a long trip with a dodgy battery.
  4. #224
    Klerksdorp
    Thanked: 388
    Some guys have reported extending the battery's usefulness by up to 12 months, but as stated above, consider anything that you get as a bonus, the battery will never be up to par again. Use it while you can!
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  5. #225
    Apr 2008
    KZN
    Thanked: 11
    Default Excellent Service - Thank you Eric!
    Just a little feedback on the inimitable Mr Skeen.
    I bought a Benton BX-2 charger from him a while back, and a few days ago it would not initiate the charging cycle when plugged into AC power.
    I mailed Eric about it, and he gave me a 'reset' procedure to try. When that didn't have any effect, he told me to get it back to him and he'd have a look and try some fault-finding.
    A day or two later, before he had even received the unit I had returned to him, I received another mail from him saying he'd already couriered me a replacement unit as mine was still covered by his warranty.
    That, Gentlemen, is how to successfully run a customer-oriented business!
    Thank you Eric, it's always a pleasure doing business with you - thank you again for backing your product and your customers 100%!
    Regards,
    P
    Prado 4.0L VX
    BMW R1200 GSA
    "Two roads diverged in a wood, and I.....I took the one less travelled by, And that has made all the difference."
    -Robert Frost-
  6. #226
    Klerksdorp
    Thanked: 388
    Paul, it's only a pleasure! The faulty unit arrived the day we closed for December and it is still sitting in its sealed Speed Services bag, and it can silently wait just there until we re-open in January!
    -F_D
    White Fang:
  7. #227
    Apr 2008
    KZN
    Thanked: 11
    Enjoy the time off Eric!
    Chat again in the New Year.
    Regards,
    P
    Prado 4.0L VX
    BMW R1200 GSA
    -Robert Frost-
  8. #228
    Thanked: 180
    Default How does it work?
    Quote Originally Posted by Family_Dog View Post
    BENTON BX-1(PRO) is a smart, 5-step fully automatic switch mode battery charger and maintainer, designed for charging a variety of SLA (sealed lead acid) batteries, widely used in motorcycles, cars, ATVs, boats, trucks, Jet Skis and Snowmobiles, communication equipment, information technology equipment, medical equipment, scientific equipment etc. The batteries may be of various types i.e. WET/Flooded, GEL, AGM batteries capacity from 12V/1.2 Ah to 12V/120 Ah. The BX-1 PRO also charges batteries in cold conditions, recovers slightly sulfated batteries and rescues drained battery as low as 3.0V. It provides trickle charge and maintenance charging which increase battery life and gives superb performance.F_D
    Hi Family Dog,
    I understand that the bigger units - e.g. BX2 - has a supply mode in order to lift a very low battery to a chargeable minimum - 8V or so. This then allows the charger to work as advertised.
    On the BX1 (Pro) it states that it can get a battery back from 3V, although it does not have the supply feature in the comparison table.
    How does this work? Or can the BX2 recover from even lower, say <1V?
    PS I am of a technical background, so the explanation may waft in that realm .
    Johnie
    Volvo XC60 T5
    180kW/350Nm (1500 - 4800 rpm)
  9. #229
    Klerksdorp
    Thanked: 388
    Just the way it is designed. The older BX-1 chargers required 8-10v from the battery in order to commence charging and they do not incorporate a 'Boost' facility, such as the mode used in the BX-2. The newer BX-1 Pro version has apparently been programmed to charge batteries at a somewhat lower minimum voltage, as they state 3v, which is probably the minimum voltage at which the charger can sense what type of battery it is connected to. It does not feature a user-selectable Boost mode as such. The BX-2 should be able to charge a 12v battery that has fallen to 4.5v.
    -F_D
    White Fang:
  10. #230
    Paarl
    Eric
    ek is ook nou in die mark vir 'n BX2. Jou prys asb. Wat sal die Speed services vra tot in Paarl.
    Aanvaar jy werk met EFT betalings.
    koosoos
  11. #231
    Klerksdorp
    Thanked: 388
    Koos, PM vir gou gestuur.
    -F_D
    White Fang:
  12. #232
    Thanked: 180
    Dankie Eric,
    PM asb pryse vir die BX1 en BX2, gepos na Pretoria.
    Enige onlangse ondervinding van die posdiens dalk - is hulle nou weer op spoed? Of koerier jy?
    Ek het November steeds posstukke ontvang wat reeds in September gepos is.
    Johnie
    Volvo XC60 T5
  13. #233
    Klerksdorp
    Thanked: 388
    Nee wat, ons stuur net per kourier!
    PM oppad...
    -F_D
    White Fang:
  14. #234
    Howick
    Thanked: 50
    Hi FD,
    My Benton BX-1 has died today! Connected it to a battery, was charging fine but came back 10 minutes later to find all the lights off and no action..! I've swapped it to other plug points that I know are working so I can't blame Eskom for this one...
    Is there a reset method or is it something I could send in to get looked at?
    Thanks in advance.
    2018 Ford Everest 3.2 Limited
  15. #235
    Thanked: 498
    Did you buy from F_D & when?
    Eggie.
  16. #236
    Howick
    Thanked: 50
    No, I inherited it in a box of gear from a mate so no idea where it was purchased from! Just hoping FD can lend some expertise...
  17. #237
    Klerksdorp
    Thanked: 388
    If you bought from me, please PM me your details and then you can send it to us to check out for you. If still in warranty, we will repair or replace, if out of warranty, we will provide you with a new one at a price you cannot refuse.
    -F_D
    White Fang:
  18. #238
    Klerksdorp
    Thanked: 388
    Oops... you replied while I was typing...
    But in this case, we will still offer you a good price on a new model if you're interested.
    -F_D
    White Fang:
  19. #239
    Howick
    Thanked: 50
    -F_D
    PM sent!
  20. #240
    Jun 2008
    Vanderbijlpark
    Hi F_D. Thanks for the very very quick response. Did receive my BX-2 this morning. Thanks again. Barry
  1. Benton BX-1 Battery Chargers
    By JDeV in forum Camping, Fridges, Accessories
    Last Post: 2015/02/12, 06:05 PM
  2. Differences between a normal lead-acid car battery and a deep cycle battery.
    By Eggie in forum Vehicle & Technical Chat - General
    Last Post: 2012/01/25, 08:50 AM
  3. Battery chargers
    By Paul Dold in forum Camping, Fridges, Accessories
    Last Post: 2011/11/22, 05:14 PM
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. Automatic switch over system between battery charger and solar panels.
    Last Post: 2009/10/08, 03:32 PM
