Gwm shows overheat
Results 1 to 11 of 11
    Sep 2008
    Mosselbay
    Angry Gwm shows overheat
    Hi,
    I am driving a 2.5 DTCI single cab 4x4 and experience some heating problems. It shows the temp rises, i losing power but when i stopped everything was normal. It shows hot but it isn't. It shows in the red but i can still put my vinger in the water and it is not burning my vinger. I then discovered that when i driving and the problem started i switch it off and after a while on again and everthing come back to normal. After a few kilos same story. Did anybody experience the same problem and how do you fixed it?
    Thanked: 1026
    Dit klink baie vreemd. Ek dink jou sensor is besig om te gaan. Of daar is n draad af...
    Thanked: 85
    My first guess was also a faulty temp sender unit but maybe also a sticky thermostat, possibly also on its way out. Possibly the ECU also picks up that the car has overheated and goes into a limp mode hence the drop in power, but once you turn off and on again it resets the fault and the engine continues to run properly until the sender unit/thermostat plays silly buggers again
    To be safe I would replace both temp sender unit + thermostat along with fresh OEM/good quality coolant.
    Rather spend a little on these important parts than damage the motor
    Geoff Craig
    '09 Toyota Fortuner 3.0 D-4D 4x4
    (M)
    '14 VW Polo 1.2 TSI HL (SWAMBO's)
    '10 Conqueror Comfort
    4x4 Action Group membership
    #0074
    Thanked: 1026
    Quote Originally Posted by Wave View Post
    +1
    Thanked: 181
    The critical part here is thermostat. Replace this urgently.
    On any healthy engine, you should not be able to put your finger in the water. It sounds like your thermostat isnt opening correctly.
    PS - Faulty temp sensors wont blow the engine, but a faulty thermostat will...
    Isuzu Frontier 280LX 4x4 2001
    Sep 2010
    benoni
    Thanked: 50
    In other words
    Get it checked quickly
    It can ruin your whole day
    4x4 action group
    www.gwm4x4club.co.za
    Nissan navara (camping and family truck)
    Jeep XJ (to make sure fortunes can't follow)
    Triumph tiger 800 (everyday drive)
    Conqueror safari trailer
    Sep 2008
    Mosselbay
    Die GWM gaan die 25ste Sept garage toe om die fout te soek.
    Ek sal terugvoering gee as dit herstel is
    Sep 2008
    Mosselbay
    Bakkie terug gekry van agente - Turbo inlaat pyp gat in, dit was blykbaar die rede hoekom dit in "lump" mode gegaan het. Volgens hulle geen fout met die sensor of termostaat nie. Snaaks genoeg, het die naweek meer as 500km gery en dit het nie weer warm geword nie. Hopelik is die probleem iets van die verlede
    Jan 2018
    Sunninghill
    Default Re: Gwm shows overheat
    Quote Originally Posted by Hennie100 View Post
    Hi,
    Jan 2018
    Sunninghill
    Hi Hennie100 did u manage to find the cause of this problem because i am having the same problem but iam still using the vehicle with the heat gauge in the H position no boiling gwm 2007 single cab 2.2lux.i have done 1000 km with this problem.
    i changed the heat gauge sensor no luck.
    Riaz
    Sep 2008
    Mosselbay
    Quote Originally Posted by Riaz2782010 View Post
    Riaz
    After the repair of the turbo pipe that stop the lumb mode the problem seems to be gone. It's 20000km further and still gone.
    hopefully it stay away
  1. GWM 4x4 Club
    By Heinz28 in forum GWM / Haval
    Last Post: 2015/03/20, 09:49 AM
  2. GWM South Africa, IS Changing
    By Jabu Jeep in forum GWM / Haval
    Last Post: 2014/06/28, 07:24 PM
  3. GWM Motors here now too
    By Dirk in forum GWM / Haval
    Last Post: 2014/02/21, 06:12 PM
  4. black magic?
    By Landyluvver in forum Land Rover
    Last Post: 2012/01/26, 05:31 AM
  5. Discovery 2: Terrible Fuel Consumption- help needed
    By Megaprop in forum Land Rover
    Last Post: 2009/06/19, 11:49 AM
