Alva Gas Shower
Results 1 to 20 of 29
Thread: Alva Gas Shower
    May 2008
    Default Alva Gas Shower
    Hi,
    Has anyone used the "Alva Gas Shower" that OW sells. Looks like easy setup compact unit. With a Piezo ignition and all.
    All their stuff work
    [email protected]
    +27824453301
    On your screen
    I bought one just before leaving for the Swazi Raid, used it there as the facilities were not up to the quantity of campers. Must say, it is well designed, compact, easy to set up and works a charm. Heats the water quickly to nice temperature ( depending on your setting ). Only gripe I have with it, the moment the waterflow is stopped, the pilot flame also goes out, so now you have to have the shower running the whole time, using a lot of water, or stop the water flow, soap up, and when you want to rinse off you must "start" the flame again. That to me is not efficient. Took it back to OW and explained what I did not like, they phoned me yesterday to inform that they will change the setting to allow the pilot flame to keep on burning while waterflow is stopped, and once the waterflow is on again the burners will automatically ignite from the pilot flame, then it will work like the old farmhouse style gasgeysers and SWAMBO, the kids and I will definitely be happy campers. Will keep you updated when I get the unit back, might only be in a week or so.
    [B]Johan Prinsloo
    I'm in the market for this kind of shower. How does it compare with the Kariba shower ITO price and useability. The Kariba also convert into a stove?
    Johan, why did you decide on the Alva and not the Kariba?
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    laat weet ek soek ook een dan. .....Johan, soek jy warm water vir die olie lekke afwas?
    [email protected]
    +27824453301
    Jul 2007
    Gauteng
    Default Alva gas Shower
    Works well and is great as everything packs away in the shower unit. We chose it as it looked safer for our small kids than the ones that are attached to the top of a gas bottle. The big advantage is that you can operate it yourself while you shower which is some other bush showers cannot do. I have the same problem with the Pilot light going out, which OW did you return yours to, to get the settings changed.
    Disco 4 SDV6 SE
    Defender TD5 90
    On your screen
    H2F, I decided on the Alva, 'cause @ R 1699.00 it was the most affordable, the way it packs away, all inside the unit, the weight or rather lack of it, and the safety for little ones in the vicinity. It is really practical, compact and very efficient.
    Herman, olielekke ?? Ek ry mos nie 'n Datsun nie
    Reng, bought it at OW Zambesi in Pta and returned it to them. They don't do the setting themselves, they send it to the GP agent for Alva gas, will definitely give feedback once it is done and we have tested it.
    [B]Johan Prinsloo
    Jul 2007
    Pretoria (PvR)
    Quote Originally Posted by 2510JP View Post
    Ek het vir Alva gebel en aan hulle die probleem verduidelik.
    Die ou daar het gese dat daar niks is wat hy vir my kan doen nie, dit is blykbaar so gemaak vir veiligheid.
    Johan, hou ons asb op hoogte.
    Albert Gravett
    Isuzu KB6 3.0 D-Teq D/C 4x4 Auto
    ORRA Call Sign B66
    May 2008
    One can always let the shower head run into the container with the pump in order to circulate the water.
    Toyota Hilux D4D Dual Battery, Long Range Tank, OME
    Echo 4
    Garmin 60CSx, Montana 600, Nuvi 3760LT
    GME GX300 29MHz
    Jul 2007
    Pretoria (PvR)
    Quote Originally Posted by Derick View Post
    Dit is wat ek doen, maar die container staan buite die shower cubicle... en dit werk dan nie lekker nie.
    Albert Gravett
    ORRA Call Sign B66
    May 2007
    Welgelegen, Cape Town
    Shower cubicle
    Klomp moffies, staan buite en geniet die omgewing!!!
    Jul 2007
    Pretoria (PvR)
    Quote Originally Posted by johanvb View Post
    Shower cubicle
    Die omgewing gaan dit geniet!
    Albert Gravett
    ORRA Call Sign B66
    Jan 2007
    Tamboerskloof, Cape Town
    Shower cubicle
    Het jy al gesien hoe lekker lag 'n olifant?
    De Kelders
    Quote Originally Posted by stadleroux View Post
    Is dit nou vir die klein slurpie.
    Jan 2007
    Quote Originally Posted by Andre View Post
    Ja, en veral vir hoe daardie slurpie in die wind wapper as oom Ollie begin naderstaan...
    On your screen
    Na baie geduld en gewag het ODW toe uiteindelik na my teruggekom met 'n antwoord. Nee Alva Gas is nie bereid om die pilotvlam aan te pas nie. Volgens hulle is dit 'n veiligheidsfaktor wat ingebou is en Basta . . .
    Ok, in daai geval s vir Alva Gas ek stuur solank die potjie "lotion" want hulle kan hulle produk maar druk, thanx, ek sal mre by julle stop vir my refund . . .
    [B]Johan Prinsloo
    Jul 2007
    Weet die seker Offtopic, maar Kariba het nou hulle brander gedeelte verander van die ou cast-iron model na 'n baie ligter aluminium een. Die brander self is ook groter (meer vlamme). Lyk nogal heel nice, net bietjie duur.
    No hole too deep, No hill too high.
    Always take the road less traveled, there is less people and more obstacles
    Jul 2007
    Pretoria (PvR)
    Stuur vir hulle genoeg "lotion", want myne moet dan ook daar in!!!
    Albert Gravett
    ORRA Call Sign B66
    braam Luus Guest
    Good day johan, did the suppliers managed to get the adjustment done yet for the pilot lamp to stay on when waterflow is stopped?
    On your screen
    Hi Braam,
    Alva did not want to change the settings on the pilot flame and I gave the unit back to ODW and they gave me a full refund. I have heard that Alva is now looking at changing the operation of the pilot flame due to all the complaints they have had about the setup. I unfortunately don't know the outcome
    [B]Johan Prinsloo
    By charlatan in forum Jeep
  2. Problem with ALVA camping shower
    By Poen in forum Camping, Fridges, Accessories
    Last Post: 2015/08/05, 09:02 PM
  3. New Alva Gas shower
    By Vrystaat in forum Camping, Fridges, Accessories
    Last Post: 2009/11/21, 07:50 PM
  4. Safari Centre Gas Shower
    By Doc D3 in forum Camping, Fridges, Accessories
    Last Post: 2009/11/13, 09:46 AM
