Roofrack "Work" Light
Results 1 to 17 of 17
    Thanked: 71
    Default Roofrack "Work" Light
    Does anybody know where (I stay in Pretoria) to purchase the spot light that is typically mounted on the rear of a roofrack/roll bar/canopy. It is inside a rubber type casing and has a handle and a switch on the light (I think??) See pictures.
Name:	Lig spot op sleepwa 2.JPG
    Apr 2008
    Its a Hella light, I know Mida's used to sell them, as well as 4x4 Megaworld. Don't know what they currently cost. Really useful to have if you are working at night, even just packing or unpacking a trailer, etc.
    May 2007
    AutoZone
    Mitsubishi 4 Door
    3lt V6 2006 Facelift 4x4
    ORRA Details:
    29mHz: ZRF430
    Club Call sign: B33
    Thanked: 71
    Went to have a look at the Hella light at Midas.
    Decided such a light is purely a nice-to-have in my case and can do without it!! At a price tag of R680 (no wiring & no bulb!!) I am sure I can use the money more efficiently. Must admit, well made & strong!!
    Any such second hand lights lying around in someone's garage?? Please let me know if you want to get rid of it!!
    May 2007
    I really like those Work lights...
    but has nobody made a light in the same fashion with a LED or Krypton bulb... well at least something that is more power eficient...
    May 2008
    White River
    Thanked: 13
    Most useful bit of kit, the Hella working light. Safari Center has them too.
    I have 3 of them rigged up (rear corners and rear center) and wired to a dash switch. Excellent for reversing in dark tight spots.
    Nov 2006
    Thanked: 408
    I just use an old spotlight.You dont need all the rubber and fancy handle.
    Thanked: 77
    Default Rear working Light
    Tha farmers use something similar on their tractors, but made out of metal. It is usually fitted onto on of the fenders. Don't know the price, but they are quite durable as well. Try one of the co-ops.
    Toyota Land Cruiser 76 4.5D V8 "Vuurhoutjie Boksie". Toyota Hi-Lux D4D 4x4 "Willebees" (My daily drive). Afrispoor Cheetah 2-Sleeper Easy Camper. Hyundai i20 1.6 (SWAMBO's daily drive).
    De Kelders
    Thanked: 131
    Quote Originally Posted by HermanvdW View Post
    It is called a plough light, used to be cheap. Normally had a switch on the lamp itself.
    Feb 2008
    Thanked: 947
    Try these guys:
    http://www.cariboodistributors.com/toledo_lights.htm
    hulle is in Centurion
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Thanked: 71
    Thanks to everybody for their input.
    H2F, I will contact them - it seems they have what I need - price will determine.
    Jun 2007
    Thanked: 52
    Default Work Light
    You do get a cheaper copy of the Hella work light - got mine at 4 x 4 Megaworld (Cape Town) not sure of brand name - shop around - its out there somewhere at a reasonable price !!!
    Brilliant for setting up camp, working at night, trailering boat at night etc !!!
    And if you set it up nicely and control from inside the vehicle ....... good for blinding idiots driving behind you with brights on !!!!!!
    Feb 2008
    Does this light (Hella) with the handle (discussed here) work off 12V or would I need to hook it up to my inverter? What's the Watts??
    Going to the bush, is going home...
    Thanked: 71
    Works of 12V, either permanently coupled (fused obviously) to the vehicle power supply or it could have a lead with a cigarette lighter plug. Your choice.
    I am waiting for prices from Cariboo Distributors on their Toledo working light - seems considerably cheaper that the Hella. Also the option of spot or flood light.
    Follow the link that H2F supplied earlier.
    Feb 2007
    melkbosstrand
    Thanked: 137
    Yes, these lights are very durable and very usefull. I had hella plugs fitted in various places on my vehicle and on my trailer in order to plug this light and other lights into. I also made a stand for it and a base with non/scratch and non/slip material underneath. I now want to know if you could fit a suction cup to the bottom of it. Where can you buy something like this? It will then be able to be mounted nearly anywhere i want to on my rig. I also wired up an extension cable for it. I now want to expand its functionality.
    JonoB
    Current: Toyota FJ Sport Cruiser
    Previous: VW Amarok ULTIMATE 4motion (auto)
    Previous: Amarok 4motion (MT) with a few goodies
    Previous: Isuzu KB300 Dteq 4x4 not that many goodies
    Prevous: Isuzu KB360 4x4 with a few goodies
    oryx1217 Guest
    Default hella work light
    I see you are staying in Pretoria.In Vermeulen street there is a small littel shop just after the big metro general store.If you pass the metro store on your left the shop is about 50m on you left hand side it almost look like a spare shop try them got my hella's from them for cheap and also saw the work light there they got the hella and a much cheaper one there (+-R120) try them I'm sure you will get what you whant there
    Feb 2008
    Thanked: 947
    Quote Originally Posted by jonoB View Post
    JonoB
    Jono.
    Maybe have a look at your local angling store ath the fishing rod holders - those things can suck a tennis ball through a garden hose and will not slip of the side of the vehicle. I assume some mods will have to be made, or an attachment bracket, but i'm sure they'll work.
    M2CW
  1. Replies: 70
    Last Post: 2014/10/24, 09:45 AM
  2. Light Speed Zero: Possible...??
    By Oppers in forum The 4x4 Pub
    Last Post: 2011/11/22, 05:49 PM
  3. How many forum members to change a light bulb?
    By Apocalypse in forum The 4x4 Pub
    Last Post: 2011/08/07, 05:13 PM
  4. Opinion wanted !!!!!
    By AndyF in forum General 4x4 Discussion
    Last Post: 2011/03/09, 01:52 PM
  5. Replies: 48
    Last Post: 2010/05/04, 07:29 PM
