Results 1 to 8 of 8
    Aug 2014
    Post Lift kit precaution!
    Gents,
    I installed a 40mm lift kit some months ago without any issues, or so I thought...
    I noticed the 'woosh' fom my cooling fan was not too noticable since the lift and had a look under the bonnet only to see (feel) that the cooling fan is completely stuck and won't turn at all, my first thought is the viscous coupling has gone, so the next logical thing is to book it in at the dealers to get it replaced (not available after market it seems).
    The technician called me and explained to me that the cooling fan was actually catching the fan shroud behind the radiator, hence the reason for not turning... Now you may say 'duh...obvious', but I assure you, it is not, it is the last thing I would have looked for when I installed the lift kit, and I do think myself a 'not too slow' fella (well, not after this )
    So, just a friendly heads up, if you do the lift kit, remove the bottom part of the fan shroud or you'll have to fork out R2.8k for a new viscous coupling
    Hope this helps at least one Tritonian.
    Leon 'Leroy' Botha
    Pavement parker - 2012 Fortuner 2.5
    Thanked: 181
    Was the lift kit from SinWolf ? He has installed a few and hasn't mentioned a problem like you experienced
    May 2011
    Klipriver
    Thanked: 427
    When we did the lift kit on Bumblevee's Hummer it was listed in the instruction to cut the fan shroud
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    Thanked: 18110
    A body lift? One of the first things to check...........
    Dec 2007
    Harties
    was thinking the same!.....
    I like anything with 4 or more wheels...
    Jul 2009
    Thanked: 384
    Quote Originally Posted by Nakiboy View Post
    Gents,
    But WHY did you not remove it in the first place ?
    My installation manual CLEARLY instructs to remove the bottom piece
    Anyway... Hope you didn't damage anything with the fan not running
    Glad it's sorted now
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
    Aug 2014
    I clearly did not check that first off, hence the new viscous clutch.
    Anyhoo, lesson learnt, was hoping this post could just be a heads up to other guys.
    'Obvious' is experience dependant!
    Leon 'Leroy' Botha
    Aug 2014
    Well, now I know
    Leon 'Leroy' Botha
  1. Ranger T6 lift kit
    By Andz in forum Ford & Mazda
    Last Post: 2019/05/24, 10:34 AM
  2. Colt lift en tyres - nog een !
    By NetEddy in forum Mitsubishi
    Last Post: 2011/08/15, 08:26 AM
  3. KJ lift kit
    By 4x4fun in forum Jeep
    Last Post: 2010/10/11, 05:15 PM
  4. Cherokee Body Lift kit to accomodate 245/75/16
    By 4X4byFAR in forum Jeep
    Last Post: 2009/07/15, 10:03 AM
