Difference in tyre thread size?
Results 1 to 9 of 9
    Queenstown
    Thanked: 30
    Post Difference in tyre thread size?
    I was wondering what would happen if for instance you have a puncture or blown out tyre and you replace it with a new tyre. If the old tyre was 6-7mm and the new was 12mm would it do any damage to your diff etc?? A guy from a local tyre shop told me that your tyres need to be more or less the same tyre thread in mm.. Is there a maximum that they can differ from each other and what damage could it cause running it like that?
    Hillcrest, Malaysia
    Thanked: 6607
    Depends on what car, what mode it is in, what surface you are driving on, how long you will drive like that and which axle or diff it is on.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Sep 2013
    It would possibly cause problems on a car with traction control and if you have difflock on a firm surface. Both those situations are only applicable if the 2 different size tyres are on the same diff and they're driven wheels.
    I'm not certain HT tyres have enough tread to create a big enough differential but a set of muds certainly could.
    Triton DC 2,5 SS 4x4
    Lynx Bashplate
    Powerbrake AT
    Kumho KL71 265/75/16
    DIY Dual Battery System
    DIY Rocksliders
    DIY 40mm Lift Kit
    Next Project, Transfer case skid plate
    May 2012
    Thanked: 11
    all depends on the vehicle. permanent softroader 4x4s like BMW X3/5 the tyre size differenece results in the transfer case straining, this then breaks the adjustment motor inside the VTG. doenst happen straight away, but rather over a few thousand kms
    Currently do not own a 4x4, driving a sedan
    Ex: 2013 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2012 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2013 Ford Ranger 2.2 XLS 2WD manual
    Ex: 2009 Mazda BT50 3.0 CRDi double cab manual
    Queenstown
    Thanked: 30
    Its a 4x4 bakkie with lockable hubs in front, i have a rear diffloc but only ised it once in mud.. I see on a few oversee forums they say its a big NO.. So 30's in the front and 31's in the rear should be a big no then as well😔
    Hillcrest, Malaysia
    Thanked: 6607
    Quote Originally Posted by Alton View Post
    Agree, also some cars, noticeably VW AUDI products use individual wheel speeds as a tyre pressure monitor.
    ZS5KAD
    3 V8's
    Jan 2011
    Thanked: 9
    When our SWB was in an accident TuffStuff only replaced one tyre (Hankook MT). The others were 50%.. Been driving it like that for two years, hoping nothing breaks inside the diff
    Out of Town
    Thanked: 741
    Do a search, this is currently being discussed on another thread.
    Out of Town
    Thanked: 741
    I think it's all been covered here
    http://www.4x4community.co.za/forum/...d.php?t=191630
  1. excel tyre size convertor
    By Apocalypse in forum Tyre chat
    Last Post: 2017/07/24, 04:31 PM
  2. Tyre size and fuel consumption
    By Mort in forum Tyre chat
    Last Post: 2014/03/12, 12:57 PM
  3. Snot plugs
    By Stefan in forum Tyre chat
    Last Post: 2011/10/12, 03:27 PM
  4. New Hilux Tyre Size Options?
    By RMackay in forum Tyre chat
    Last Post: 2011/10/07, 10:40 AM
  5. Thread size in SFA hilux chassis??
    By Barto in forum Toyota
    Last Post: 2011/08/24, 05:22 AM
