Bigger tyre on 16 inch spare wheel
Results 1 to 12 of 12
    Apr 2014
    Somerset West near Cape Town South Africa
    Thanked: 11
    Default Bigger tyre on 16 inch spare wheel
    Rather then fork out for another wheel rim, I'm thinking of putting a 265/70/16 tyre on my spare as the circumference and diameter are identical as my 256/60/18 as near as damnit, unlike the 245/70/16 fitted . A local (more friendly and helpful) tyre fitter said it should work ok. So much for Tyger Wheel and Tyre being helpful.
    Later on next year I might replace my 18 rims with 16 inch and fit 265/70/16 tyres all round.
    2013 Chev Trailblazer 2.8 4x4 auto.
    Thanked: 21
    Quote Originally Posted by Malcolmj View Post
    Looks like 13mm difference in Diameter.
    Click Here....
    If you go for 245/75/16, the difference will be little less.....9.5mm
    Click here.....
    Apr 2014
    Thanked: 11
    Quote Originally Posted by peyperj View Post
    Looks like 15mm difference in Diameter.
    Click here.....
    Click here.....
    OOPs I made a typo, my tyres are 265/60/18 not 256/60/18
    When I checked using your tyre reference the difference in diameter is 2,2 mm
    265/60/18 is 775.2mm
    265/70/16 is 777.4mm
    Thanked: 21
    Ha Ha Ha , that's more like it now the difference is 2.2mm!!!!
    Click here to see the specs...
    Apr 2014
    Thanked: 11
    lol I had a senior moment.
    2.2 mm is nothing in the great scheme of things, so it should work out OK, as well as being over R1K cheaper per tyre compared to the 265/60/18
    Thanked: 21
    Agree, should be fine as a spare until you change all to 265/70/16. Just changing my 18's on my Wildtrak to 265/75/16
    2014 Ford Ranger T6 Wildtrak 3.2 (4x4)
    Tough Dog Suspension, Rhino Bumper, PBE Dual Battery System, Takla Floor Covers, Escape Gear Seat Covers, LED Light Bar, Hytera VHF, Dick Cepek with Cooper ST/Maxx 265/75/R16, National Luna 90L Twin & 55L, Gobi-X Fridge Slide (Next upgrade - Winch, Snorkel, Rock Sliders, Alu or S/Steel Canopy)
    2018 Volkswagen Kombi
    Metalian Maxi - On order!!!
    Greyton westerncape
    Thanked: 31
    Find out if it works,fit it,i had serious problem with incorrect diameter almost rolled due to axel wind up on a defender 90
    Apr 2014
    Thanked: 11
    Quote Originally Posted by mike cullen View Post
    Hi Mike, I don't understand why you would have wind up unless you had the center diff lock engaged on a hard surface. What diameters are you talking about?
    Apr 2014
    Thanked: 11
    Apr 2014
    Thanked: 11
    The 265/70/16 should work fine with my 265/60/18.
    Its a good idea to change your 18's as 16's are a lot cheaper and easier to find.
    Thanked: 21
    Agree! But for now its not so cheap to buy it all ,as I only have around 500km on my Wildtrak, LOL
    But yes, 16's are far cheaper than the 18's
    Apr 2014
    Thanked: 11
    I was quoted just under R2 thousand for the 265/70/16, compared to over R3 thousand 5 hundred for the 18 inchers. My tyres are now at 20000 kms with a load of tread left, I wont even consider changing over until they are well worn. Even then I can hopefully sell off my 18 inch rims to offset the cost of new 16 inch rims and tyres.
  1. Alert! Daihatsu terios 4x4 off road owners
    By Gulliversmate in forum Softroaders
    Last Post: 2013/04/10, 07:59 PM
  2. Good Ground Clearance Advice
    By kalahari in forum Land Rover
    Last Post: 2012/06/03, 02:40 PM
  3. Why bigger tyres?
    By SimonB in forum Tyre chat
    Last Post: 2010/10/05, 01:22 PM
  4. 6 Wheel tyre rotation???
    By BigRed in forum Tyre chat
    Last Post: 2007/01/18, 10:45 AM
