Results 1 to 14 of 14
    Witbank
    Default 3.2 Ranger Boost Pipe Burst
    Just a bit of info or to check....the pipe from the intercooler to the intake manifold burst....
Name:	Ford Ranger.jpg
ID:	299781   Click image for larger version.
Name:	Ford Ranger1.jpg
ID:	299782   Click image for larger version.
Name:	Ford Ranger2.jpg
ID:	299783   Click image for larger version.
    May 2012
    Thanked: 89
    Quote Originally Posted by WTaute View Post
    Is this different to the usual one that goes on the auto's?
    http://www.4x4community.co.za/forum/...d.php?t=173693
    http://www.4x4community.co.za/forum/...d.php?t=171583
    Current: 2018 Ford Ranger 3.2L XLT AT D/C 4x4 (since: 24/04/2018 )
    Previous: 2015 Ford Ranger 3.2L XLT M/T D/C 4x4 (31/08/2016-24/04/2018 )
    Previous: 2013 Ford Ranger 3.2L XLT M/T D/C 4x4 (05/01/2013-31/08/2016)
    Previous: 2010 Nissan Navara 2.5D LE M/T D/C 4x2 (Sold: 30/10/2012)
    May 2012
    Thanked: 15
    Yes this looks like the boost pipe from the inter cooler to the intake manifold.
    I see the Bakkie is on 81k km so not a concern. as long as the insode of the pipe is not soaked in oil then the replacement pipe should be the end of your issue.
    Currently do not own a 4x4, driving a sedan
    Ex: 2013 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2012 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2013 Ford Ranger 2.2 XLS 2WD manual
    Ex: 2009 Mazda BT50 3.0 CRDi double cab manual
  4. The Following User Says Thank You to Andz For This Useful Post:
    Witbank
    Yes it is the boost pipe from the inter-cooler to the intake...Ford is replacing it under warrenty...while it is in ,they are doing the water coolant pipe to the Auto Box also.
    Is dit die eerste keer dat hulle hierdie pyp vervang.
    2013 Ford Ranger 3.2 D/C Auto
    Witbank
    Op my voertuig ja...maar daar is al van die pype vervang op ander Rangers.
    Noordheuwel
    'n Familielid van my se boost pyp het ook op presies dieselfde plek geskeur, net die pyp vervang en daar gaan hy, blykbaar 'n swak batch.
    Syne was op die 2.2
    If guns are outlawed only outlaws will have guns.
    2.5 Nissan Pathfinder
    Ford Ranger 2.2 Supercab - Ex
    Dec 2019
    Palapye
    Default Re: 3.2 Ranger Boost Pipe Burst
    Quote Originally Posted by Andz View Post
    What will be the issue if there is some little oil inside the pipe?
    Thanks,
    I just had the exact same problem (splint on intercooler pipe/hose) where my Ford Ranger Wildtrak 3.2L was going into "limp mode" and showing a powertrain warning ⚠️ light.
    I found I little bit of dark oil 🛢 in the intercooler pipe. Is that normal?
    #Problem details & facts:
    -⚠️ Warning lights? =Powertrain (see below)
    -Limp mode activated (Speed restricted to 40 KMPH max!)
    -If I turned the Vehicle off then on again, the Warning ⚠️ sign would go away then I could drive normally until i need power again to go up hill, etc then the warning ⚠️ would appear and limp mode would kick in again
    -There was a different noise everytime I turned off the engine (like air leaking noise, which was coming from the splint on the Turbo intercooler hose)
    -The original intercooler pipe was manufactured in 2014 só it last 7 years. ⚠️ I do recommend you check the manufacturer date on the new one to see how long is sitting on the shelf. I found one at the dealer that was already 2 years old!
ID:	624673   Click image for larger version.
ID:	624674   Click image for larger version.
ID:	624675   Click image for larger version.
  11. The Following User Says Thank You to Manuel4x4 For This Useful Post:
    Jul 2021
    Boost pipe on my 2.2 Ranger went a week ago (48 000kms). Ford advised me to fit an aftermarket pipe (silicone bends and aluminum) at 1/3rd of the price. Appartently this will outlast the OEM part. I installed the aftermarket pipe....all good so far
  13. The Following User Says Thank You to Lappies1980 For This Useful Post:
  14. #11
    I found I little bit of dark oil 🛢 in the intercooler pipe. Is that normal? Thank you!
    Quote Originally Posted by Manuel4x4 View Post
    _______________
    2015 Ford Ranger Wildtrak 3.2 TDCi
    LANDrover Dicovery 3.0, TD6-V6, SE, 2006
    [SIZE="2"]Previous Vehicles: Jeep Cherokee 2.7, H.Getz 1.6, Nissan Hardbody 2.4, Audi 2.4, Opel Astra Sedan 2.0
    [/SIGPIC]
  15. #12
    Thanked: 19343
    It is normal. Crank case vapour.
    Jakes Louw
  16. #13
    Thank you do much brother!
    _______________
    [/SIGPIC]
  17. #14
    Thank you so much brother!
    _______________
    [/SIGPIC]
  1. 2003 Ford Ranger Pipe swap possible or not?
    By Danny_Boi in forum Ford & Mazda
    Last Post: 2020/09/30, 10:43 PM
  2. Unresponsive or "slow" Ranger T6 3.2 Auto box.
    By Michael Jefferies in forum Ford & Mazda
    Last Post: 2014/12/01, 04:37 PM
  3. 3.2 4x4 Manual ranger - feedback
    By jaenswart in forum Ford & Mazda
    Last Post: 2012/04/19, 01:58 PM
  4. Latest Pipe spcifications.....:)
    By BigRed in forum The 4x4 Pub
    Last Post: 2008/04/17, 12:09 PM
  5. Burst aircon pipe on Hilux
    By Willem Grobler in forum Toyota
    Last Post: 2008/01/08, 09:01 AM
