Results 1 to 13 of 13
    Thanked: 38
    Default Put a free flow 2.2.T6 on a dyno?
    Hi Guys, Was wondering if any of you have put a 2.2 T6 on a dyno after cat removal or fitting a free flow exhaust?
    2015 Ford Ranger 3.2 Diesel DC 4x4 6spd MT
    2018 Ford Everest 3.2 Diesel AWD 4X4
    Brits
    Thanked: 475
    Would be nice to find out.
    Renault Duster 1.5Dci 4WD
    Thanked: 284
    am sure it will make a diffs and also be better for the engine...
    JT
    Sep 2012
    Thanked: 25
    Quote Originally Posted by BAX4x4 View Post
    If this is a diesel ,sorry they dont have catylitic converters.
    Jul 2014
    West Rand
    Would be nice to see the diff in consumption
    Brits
    Thanked: 475
    Quote Originally Posted by Reccepops View Post
    In the U.S., all on-road light, medium and heavy-duty vehicles powered by diesel and built after 1 January 2007, must meet diesel particulate emission limits that means they effectively have to be equipped with a 2-Way catalytic converter and a diesel particulate filter.
    http://en.wikipedia.org/wiki/Catalytic_converter
    Im not sure if this also applies to our regulations but elsewhere they do come with a catalyc convertor.
    Strand
    Thanked: 188
    Climbed under to see if I had a cat, and found an oil leak.
    2021 Ford Ranger 2.2 XLS Auto
    Jul 2014
    West Rand
    Quote Originally Posted by nieljooste View Post
    Not a nice find,
    HoneyDew
    Thanked: 8
    LOL - Cant be a Ford.... The New Fords doenst have Oil Leaks
    FordRanger T6 / 3.2 XLT 4x4 Auto.
    The 3Ton Gravel Road Monster over weekends.
    The Pavement Special in the week.
    Since March 2013
    ConquerorComfort.
    Camping instyle since January 2012.
    HAM CallSign: ZS6LSC
    ORRA CallSign:AG34
    <a href="http://www.fuelly.com/car/ford/ranger/2013/zs6lsc/172702" target="_blank"><a href="https://badges.fuelly.com/images/sig-metric2/172702.png" target="_blank"><a href="https://badges.fuelly.com/images/sig-metric2/172702.png" target="_blank">
    Strand
    Thanked: 188
    Quote Originally Posted by ZS6LSC GP View Post
    Hehe
    Cannot see any "LR wannabe spots" where it usually stands, but it's definitely sweating out oil somewhere. Oil level is fine. I'll just report it to the dealer and they can look at it at the service which is in less than 2k.
ID:	300464   Click image for larger version.
    Strand
    Thanked: 188
    Popped in at B&M Ford Swellendam. They are replacing the oil pressure switch/unit while I'm waiting.
    Strand
    Thanked: 188
    While at the dealership I spoke to the main mechanic about the cat.
    Mine does not have one fitted, and neither does most 2.2's. The 2.2's going to the overseas market does have them fitted and they are situated just after the turbo.
    The 3.2's do however have a cat, situated on the same spot. For the overseas market they are also fitted with an injector that squirts diesel into the cat at certain intervals to help it burn clean. When this happens, depending on how you are driving at that moment, it could lead to some black smoke out the rear.
    He has however seen 3.2's that wasn't fitted with a cat, and also ones that has the cat with the injector fitted.
    Bottom line, if you have a cat in the line, I can see no reason why not to remove it. The only reason it is there is for European emission standards, and not for the health of the engine.
    May 2012
    Dubai
    Thanked: 74
    Niel. You are close, but not quite correct.
    Sa has euro 2 emissions standard. The 2.2 doesn't need a cat but 3.2 needs it to meet it.
    For European markets with euro 5 emission standards, both 2.2 and 3.2 has a cat just after the turbo.
    They also have a diesel particulate filter (dpf) to catch particles. This is under the floor. The dpf has an extra injector to build up heat and burn off the particles in the dpf from time to time.
  1. 4x4 Community Dyno Day Saturday 8th June
    By Baben in forum Land Rover
    Last Post: 2014/06/11, 05:55 AM
  2. Free flow on D4D
    By Chris8d in forum Toyota
    Last Post: 2013/11/21, 03:57 PM
  3. Free flow 54mm? for 2.5TD and a pic of DVR down pipe?
    By Ford Courier in forum Ford & Mazda
    Last Post: 2013/03/22, 06:26 AM
  4. Free flow - Pajero 3.2 Di-D
    By MariusFourie in forum Mitsubishi
    Last Post: 2012/07/15, 10:54 AM
  5. Discovery 1 Branches & Free flow exhausts
    By Die Hard in forum Land Rover
    Last Post: 2009/09/24, 08:35 PM
