Waypoints and google earth
Results 1 to 13 of 13
    Botriver
    Thanked: 82
    Default Waypoints and google earth
    Hi,
    I have taken soil samples on my farm and marked all the points as waypoints on my eTrex20.
    Is there a way to import the waypoints to show up on Google Earth by exporting from Basecamp ?
    '65 Jeep Wagoneer
    SOA conversion
    Work in progress....
    https://www.facebook.com/Honingklip-...6324709414350/
    Forest Hills, KZN
    Thanked: 732
    Make sure you have Google Earth installed. Copy the waypoints into a folder in Basecamp files library, select it (left click) then click on Basecamp, View, Google Earth, and click on the folder name..
    It will open all those waypoints, files, etc. in that folder in G Earth
    Only discovered this today
    2004 LR Discovery 2 Td5 GS - mods in thread en route. (Ingwe)
    Feb 2012
    Piggs Peak
    Thanked: 28
    Default Re: Waypoints and google earth
    No this doesn't work. maybe Im doing it wrong.
    If you highlight a waypoint on BC and then go to View there is no option (Like there used to be) for selecting View in Google Earth.
    Brits
    Thanked: 446
    Export the waypoints to a GPX file. Open Google Earth. Click on File->Open. Change file type to "GPS File". Browse for the file you exported and voila.
    Okahandja, Windhoek
    Thanked: 755
    Any tracks, waypoint etc in Basecamp or Mapsource can be viewed in Google earth. Just go to View and than select google earth.
    Johan Kriel
    LCs, Hilux and Echo Chobe
    Brits
    Thanked: 446
    This used to work fine, but it no longer works on my Windows VM. Which is really not a problem, as I only use Windows in VMWare for specific applications (such as BaseCamp, for example) and use Linux the rest of the time. So I could not be bothered to figure out why it does not work and fix it. At the moment, I simply do the export and open.
    Okahandja, Windhoek
    Thanked: 755
    Thanks.
    Sometimes you have to open Google Earth first , before opening it in Basecamp or Mapsource.
    Johan Kriel
    Brits
    Thanked: 446
    Thanks.
    Yes. I know - that is how I used to do it. But no longer works, but I couldn't bother fixing it.
    Nissan Patrol GRX 4.5
    Jul 2017
    Rayton
    If you have the .GPX files downloaded you can use a program called QGIS (Free open source) Software. Very Powerfull program to view and edit about any format. I can also send you a link that you add so that you can view google imagery on the program.
    Gaborone, Botswana
    Thanked: 984
    The "View in Google Earth" was only available up to BaseCamp V4.6.3. From V4.7.0 on it was removed.
    In BaseCamp: Press and hold 'Ctrl'. Select all the waypoints you want to export. Then File -> Export -> Export Selection. Save as .gpx
    In GE: File -> Open. .... your .gpx file.
    You can do the same with tracks from BaseCamp.
    Kobus
    Nissan
    Feb 2012
    Piggs Peak
    Thanked: 28
    Thank to all. yes it is true - the view function (View - View in Google Earth) in BC is no longer available.
    As you say - you have to export the data you want.
    See Post #63 in the sticky (GPS Tips and Tricks) which some member from Nelspruit has very kindly made it easy to do.
    In fact if you export your whole library (say your trip to Bots and Nam) and the import into GE then its actually even better than viewing waypoint by waypoint. Its all there for you to browse through all the trip data. on GE. Brilliant!
    Jan 2014
    Thanked: 477
    Quote Originally Posted by Jeepers View Post
    Just a note. It is not in the sticky but in this thread: https://www.4x4community.co.za/forum...d.php?t=269460
    Garmin BaseCamp - Tips & Tricks
    The 1st post has an index with links to the post you want to look up.
    Okahandja, Windhoek
    Thanked: 755
    Did not notice I dont use basecamp for trips planning other than its search function
    Johan Kriel
  1. Getting Oregon features with Nuvi & PC??
    By oubaas1 in forum GPS & Mapping
    Last Post: 2010/01/12, 05:55 AM
  2. Looking for waypoints
    By jacquespienaar in forum GPS & Mapping
    Last Post: 2008/07/01, 07:32 PM
  3. How do I call up tracks on a Quest?
    By AndreG in forum GPS & Mapping
    Last Post: 2008/05/14, 07:31 PM
