Jurgens XCape - Page 8
Page 8 of 52 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 33 ... LastLast
Results 141 to 160 of 1022
Thread: Jurgens XCape
  1. #141
    Victory Park
    Thanked: 124
    Look good Clive, well done.
  2. #142
    Ruimsig
    Thanks. Next is nose cone / aluminum storage box from case connection.
  3. #143
    Feb 2007
    Thanked: 74
    Nice mods!....anyone of you considered colouring the bright outside led light? A lady camper gave me the tip to spray paint the cover yellow..about 3 layers should be ok.
  4. #144
    Ruimsig
    You can buy one that has different colors. I wouldn't spray it. Maybe see if you can get on the inside of the lens
  5. #145
    Victory Park
    Thanked: 124
    I wouldn't spray it either. Rather buy the coloured ones available.
  6. #146
    Feb 2007
    Thanked: 74
    thanks Guys..trust the covers are available at campworld shops?
  7. #147
    Ruimsig
    They don't sell covers. It's a new unit. Loftus had plenty stock.
  8. #148
    Feb 2007
    Thanked: 74
    thx Clive
  9. #149
    Victory Park
    Thanked: 124
    Tomorrow - Xcape to KNP - a week - cannot wait!
    Packed and ready to roll.
  10. #150
    Sinoville
    Thanked: 7
    Afternoon all,
    I see a lot of nice mods on the xcapes, have had mine for a few months now but have not done much yet, would like to ask if any of you have had any problems with the geyser and water system, I have heard a few stories that the geysers give problems and that if you run the system dry it is apparently very difficult to get it working again, any comments and advise would be appreciated.
    Regards.
  11. #151
    Feb 2007
    Thanked: 74
    hi Des, the only issue i had was with the below standard water pump which i opted to replace with a shurflow pump. Other than that no issues with the geyser...one obviously need to ensure that there is enough water in the tank before switching on the geyser on either 220v or gas and then give it around 15-20 min to heat up.
  12. #152
    Mar 2015
    Thanked: 7
    Quote Originally Posted by skub View Post
    Some changes made to our Xcape
    the shower and canopy
    [IMG][/IMG]
    the pole box
    [IMG][/IMG]
    [IMG][/IMG]
    jockey wheel
    [IMG][/IMG]
    the door cupboard,the bed and the radio
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    solar panel
    [IMG][/IMG]
    Oom Buks, hoe was Ezemvelo in die winter? Daai plek is my hart se punt en my droom plaas .
    So rustig en in die natuur.
  13. #153
    Sinoville
    Thanked: 7
    Thanks Paul,
    Does yours also have the hanson geyser, mine stopped working just after I got it, after much searching found it had blown the fuse on the geyser itself.
    Des
  14. #154
    Feb 2007
    Thanked: 74
    correct DESS same geyser...how did you manage to replace the fuse...is it reasonably accessible?
  15. #155
    Ruimsig
    I use my geyser on gas or 220 when available without any problems
  16. #156
    Sinoville
    Thanked: 7
    Paul,
    No, I had to remove the geyser from the caravan, just as well I opened the side by the chimney, I found the geyser was not even screwed down.
  17. #157
    Feb 2007
    Thanked: 74
    flippen poor workmanship...also had some quality issues
  18. #158
    Ruimsig
    I think it's a good idea to check it. Do I just remove the outside plate? Did you screw it down yourself Dess?
  19. #159
    alberton
    Phillip, ons het die drie dae lekker gekamp. Die weer was heel aangenaam. Die ape was nogal lastig. Sal sekerlik weer daar gaan kamp.
    Buks
    Isuzu Frontier 320 4x4
    Jurgens Safari Xcape
  20. #160
    Sinoville
    Thanked: 7
    CliveR,
    When you open the side cover you have access to the geyser and can then see if it is screwed down, to replace the fuse you have to remove the geyser and open the inspection cover on the back of the geyser.
  1. Fortuner Instability while towing Jurgens Xcape with Fortuner
    By Brian Fourie in forum Toyota
    Last Post: 2016/08/16, 05:31 PM
  2. Jurgen's Xcape in Australia
    By Laith76 in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/13, 08:06 AM
  3. Jurgens XCAPE doorway step
    By PRA in forum Trailers, Caravans, Towing etc
    Last Post: 2013/03/25, 09:27 AM
  4. Fair Price for 2006 Jurgens XCAPE
    By PRA in forum Camping, Fridges, Accessories
    Last Post: 2009/10/17, 12:11 PM
