Jurgens XCape - Page 6
Page 6 of 52 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 31 ... LastLast
Results 101 to 120 of 1027
Thread: Jurgens XCape
  1. #101
    Feb 2007
    Thanked: 80
    hi AVM..I just purchased a xcape and also upgraded from a lightweight 4x4 trailer without brakes to the xcape....the weight factor is overrated in my mind...towing from Centurion to Phalaborwa via Tzaneen was a breeze...fuel consumption was equal to towing my 4x4 trailer...average of 11,7lit per 100km. I simply didn't expect that. I tow with a pajero sport 3.2 DID. Towing in deep sand will obviously be heavier than most other caravans in it's class but I can live with that.
  2. #102
    Ruimsig
    Hi AVM, the xCape comes standard with a Brad Harrison connector on a cable which needs to be connected from the vehicle and then also a built in 220v battery charger .
    The solar charger is for my panels which are connected separately because there is no dc to dc charger. Your alternative is to use a dc to dc charger for the cable from the vehicle and also the solar panels (I use this setup in my car for my fridge) but the controller in the caravan has the added advantage of being able to see what is going on with your 12v power.
  3. #103
    Ruimsig
    Smile
    Quote Originally Posted by kznjeep View Post
    The previous owner of our Xcape converted the left corner of the tent to a square corner, making the tent a lot bigger. It is drawing attention wherever we camp. Should be manufactured like that by Jurgens
    Could you possibly post some pics of the tent? Inside and outside.
  4. #104
    Victory Park
    Thanked: 124
    Hi AVM, as Paul says, weight isn't an issue. I towed the Afrispoor Mongoose for years and still have it so my comparison remains current. Hardly noticeable change if at all. Go for it - you won't regret it.
  5. #105
    Sep 2008
    Wellington
    Thanked: 43
    Thanks for reassurance on weight issue.
    Clive, so the controller you are referring to is not a charger but rather a regulator?
    Ranger 3.2 XLT D/C 4x4 A/T 2019
    Armadillo Plus
  6. #106
    Ruimsig
    Quote Originally Posted by AVM View Post
    I am not so technically advanced but here are the details from the web
    The Steca PR series of charge controllers is the highlight in the range. The latest charging technologies, combined with the Steca-AtonIC state of charge determination which has been significantly improved once again, result in optimal battery maintenance and control of the module output of up to 900 Wp which can be connected to it. A large display informs the user about all operating modes with the aid of symbols. The state of charge is represented visually in the form of a tank display. Data such as voltage, current and state of charge can also be displayed digitally as figures on the display. In addition, the controller has an energy meter which can be reset by the user.
    The regulator is managed with simple menu-driven programming buttons and has a manual load switch.
    FEATURES
    Hybrid controller
    State of charge determination with Steca AtonIC (SOC)
    Automatic voltage detection 12V/24V
    PWM control
    Multistage charging technology
    Graphical LCD display for operating parameters, fault messages and self test
    Load disconnection depending on SOC
    Automatic load reconnection
    Temperature compensation
    Common positive grounding or negative grounding on one terminal
    Integrated data logger
    Night light function >LI>Integrated self test
    Monthly maintenance charge
    Electronic protection functions: overcharge protection, deep discharge protection, reverse polarity protection of load and module and battery, automatic electronic fuse, short circuit protection of load and module, overvoltage protection at module input, open circuit protection without battery, reverse current protection at night, overtemperature and overload protection, battery overvoltage shutdown
  7. #107
    Sep 2008
    Wellington
    Thanked: 43
    Yes its a fancy regulator. Very nice product which enables you to manage your 12v power availlabilty nicely.
    Armadillo Plus
  8. #108
    Lanseria
    Thanked: 26
    When I bought my Xcape I changed the jockey wheel from single to double. It works much better in thick sand. I also put a bracket to clamp it on the A frame. Further I also fitted in the original space where the jockey wheel was a tube to store the jockey wheel on when I am driving ( see trailer plug in picture). Stock standard towing in thick sand and a high middelman will destroy the jockey wheel if you don't remove it
  9. #109
    Victory Park
    Thanked: 124
    That is clever, well done. Is yours the one featured in a recent Caravan and Outdoor magazine?
    Certainly worth looking at doing and yours looks like a really nice job was done - did you do it yourself?
  10. #110
    Ruimsig
    Default Jurgens XCape
    I am not sure how strong the bracket would be for the jockey wheel.
    I found that it wobbles on a previous trailer I had.
  11. #111
    Lanseria
    Thanked: 26
    No Mike that is not mine. The job was done by Loftus Caravan. On my first trip with the xcape I destroyed my jockey wheel on the way to Savuti. I lost the wheel of the jockey wheel. Much better and stronger than the single jockey wheel. Will look for a picture where it is hitched. Going to khutse next week.
  12. #112
    Victory Park
    Thanked: 124
    I'd give anything to be going to Khutse! In Rome for two weeks and 4x4ing is far from anyone's mind. Kruger at the end of June and I'd rather be there. But, Rome ain't bad as a substitute.
  13. #113
    Feb 2007
    Thanked: 80
    that deep sand road to Savute is a real killer even without towing anything...reminded me of a small rubber duck in the waves...i nearly got sea sick!
    Mur, did the skid plate on the Xcape not help with the middelmannetjie? If not, the only other option would be to remove the jockey wheel
  14. #114
    Lanseria
    Thanked: 26
    Paul I should have removed the jockey wheel. The same thing happened to my Brakhah caravan. I then also had it changed similar to the Xcape. Brakah later on made all jockey wheels double and mounted out of the way from possible damage.
  15. #115
    Lanseria
    Thanked: 26
    Here is a picture and if you zoom in you can see where the jockey wheel rides now - out of harms way;
    Mike I love Rome - enjoy.
  16. #116
    Victory Park
    Thanked: 124
    That jockey solution looks really good but man, that Xcape looks good behind your car!
  17. #117
    Lanseria
    Thanked: 26
    This is a close up of where my jockey wheel is riding.
  18. #118
    Ruimsig
    Hi mur2
    How do you mount it while not in use? I don't quite understand how it stays up like that.
    Clive
  19. #119
    Lanseria
    Thanked: 26
    You fit a round pipe in the hole where the jockey wheel was originally, the jockey wheel then fits over the pipe and when you are driving you rely on gravity to keep in place. Have been doing it for more than 10 years.
  20. #120
    Ruimsig
    Quote Originally Posted by mur2 View Post
    Ok. Makes sense. Is it a galvanized pipe? I suppose you need to measure the lot before you just buy.
  1. Fortuner Instability while towing Jurgens Xcape with Fortuner
    By Brian Fourie in forum Toyota
    Last Post: 2016/08/16, 05:31 PM
  2. Jurgen's Xcape in Australia
    By Laith76 in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/13, 08:06 AM
  3. Jurgens XCAPE doorway step
    By PRA in forum Trailers, Caravans, Towing etc
    Last Post: 2013/03/25, 09:27 AM
  4. Fair Price for 2006 Jurgens XCAPE
    By PRA in forum Camping, Fridges, Accessories
    Last Post: 2009/10/17, 12:11 PM
