Results 1 to 5 of 5
    Mozambique/Cape Town/Other
    Thanked: 25
    Default Safe water storage
    What's the lifespan of stored water?
    Water stored in a tank in your vehicle: How long is it safe? Must the tank be drained and cleaned, and how often?
    Bottled water: I often buy water (normal bottles and 5litre cans) and use a bit. Then the bottle stands. How long is it safe to use water that has been opened and stored?
    * "Wat Spike probeer sê in sy min woorde" -Die Skim "
    Swellendam
    I've often wondered at what stage water becomes unsafe to consume? Not just yucky, but dangerous to your health.
    Thanked: 2533
    drink it. when you get spuitpoep you left it too long. Depending on what water and what chemicals you have in it. I neglected to wash my last water bottle with fresh water at rust de winter.......nagmerrie broer nagmerrie!
    Angel Group
    Solar-Construction-Offroad
    [email protected]
    0824453301
    Next event: 4x4 Recovery-TBA
    Pretoria North, Patryshoek
    Thanked: 3314
    Quote Originally Posted by Spike View Post
    What's the lifespan of stored water?............
    I store my water for more than a month at a time. But I also only used filtered water that has a TDS of about 25. That about the same as bottled water. No problems to date.
    +27 zero eight 2 four 95 9252
    Thanked: 23
    It really depends on how much residual chlorine there is, assuming you use tap water. This will carry on killing bugs for a while. If you are using a cleaned water bottle, you will generally be quite safe - rinse before use with a little bit of Jik or Milton diluted in a lot of water and then rinse with tap water until the taste is gone. A tank with a little bit of water swilling around is going to grow some bugs, unless it is filled and used under sterile conditions.
    Tap water should keep longer than filtered water, unless the filtered water is kept clean. Unfortunately there are too many variables here for me to give an answer I would be comfortable with. I have drunk water which started off as tap water and had been kept in a clean bottle in the back of the Disco for more than 2 weeks with no ill effect.
    '97 Disco Tdi
  1. Fording / Wading Discussion
    By alanB in forum 4x4 Recovery & Recovery Gear
    Last Post: 2018/11/04, 08:56 PM
  2. Converting to solar water heating: My own DIY project
    By O.B. in forum Camping, Fridges, Accessories
    Last Post: 2018/05/05, 01:07 PM
  3. CT City Council water reading scam
    By Francois Theron in forum The 4x4 Pub
    Last Post: 2011/02/03, 09:00 AM
  4. Beaufort West + Water restrictions
    By Fabfender in forum The 4x4 Pub
    Last Post: 2010/12/10, 08:00 PM
  5. Safe Drinking water
    By Johan Barnard in forum Overland advice, reports etc
    Last Post: 2006/12/01, 09:02 AM
