Page 81 of 81 FirstFirst ... 76 77 78 79 80 81
Results 1,601 to 1,618 of 1618
  1. #1601
    Thanked: 235
    Default Re: Electrickery for camping
    Thanks all for the input. Much appreciated.
  2. #1602
    Nov 2008
    Ellisras
    Thanked: 2447
    Quote Originally Posted by vanderw View Post
    Hi All,
    I have had this unit in my camping trailer for ages. It has started giving issues and now I need to replace it? What would be the Victron alternative for this or any other units I should look at?
    Chris
    Can I take that one off yer hands?
    Don’t blame yourself over past mistakes. It’s like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km, almost.
    2007 Patrol Pickup TD42 "bulldozer" - 500 000km
    2014 Patrol GU 3.0CRD "teenager" in puberty - 180 000 km
    2007 Echo3 Trailer "the nest" with Braked Axle fitted + 265/75/R16 rubber on Patrol Rims!
    Ewiks Caravan Movers now fitted to trailer, lekkerrrr - I should have done that long ago. AND 2.6kW lifepo4 in trailer, 3.1kW lifepo4 in NL box with Victron MPPT and DC-DC in Patrol, 2x1kW in small packs with MPPC/ DC‐DC as backup in case , all self built, 480W panels Victron MPPT and 220V 25A IP67 charger
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 158 000 km
  3. #1603
    Thanked: 235
    Of course you can. I am in Pta East.
    What would be a good combination for a Solar charger from Victron if I had a 160/200 Ecoflow sunpanel?
    Thanks all.
  4. #1604
    Dec 2007
    Thanked: 340
    Post Re: Electrickery for camping
    What is the "best" rigid panels for camping ?
    I am not sure and need some help.
    Thinking of 200W max and not sure if it should be FIXED or movable ...
    We have Roof space of : Max 2090 mm x 1200 on canopy roof it is the https://customleisuretech.co.za/product/crt-1/
    It is actually the hard shell RTT that is part of the canopy
    There are rails already fixed on roof
    Nico
    Nico van Diemen
  5. #1605
    Thanked: 554
    Thanks all.
    This is what I use with 2 x 100 w panels
    https://thebluestore.co.za/product/v...xoC0HAQAvD_BwE
    Platkar 1: BMW 118 (SWAMBO)
  6. The Following 2 Users Say Thank You to Mitsu Fan For This Useful Post:
  7. #1606
    Port Elizabeth, South Africa
    Not sure whether this might have been asked somewhere else, but might one damage a LiFePO4 100A/h battery if using a C-TEK D250S DC to DC Solar Charger (i.e. C-TEK's "non-lithium compatible charger" - the D250SE?)
    I ask because I can barely afford the Lithium battery without coughing more for a new solar charger as well.
    Jonathan
    Toyota Land Cruiser 79 4.0P P/U S/C
    BMW R1200GS Adventure
  8. #1607
    Default D250S and Lithium
    Jonathan
  9. #1608
    Dec 2020
    Thanked: 35
    Deleted
  10. #1609
    Malmesbury
    Thanked: 246
    when we bought our blinkgat from sarel in 2020 i started to wire the camper ,just reading through this forum to get a good idiee what is needed and what not ,that suited our needs , it is time to remove the old stuff and look into the modern electrics ,
    that is when i looked at a program of 4xoverland of andrew st pierre white and partner hein where they developed the EGON DC HUB ,now that got me going and that is what i need to get ,no fuzz and wireing to this hub ,all the deurmekaar wires wil be sorted out ,and neat ,but just to get it shiped here is pricey
    anyone that had a look into it ,what is your take on it ,is there another system like the egon in the market
    [SIGPIC]
    alberto pereira
    Colt clubcab 2.8tdi 4x4 2005
    nissan x trail t30 2008
  11. #1610
    Malmesbury
    Thanked: 246
    [SIGPIC]
    alberto pereira
  12. #1611
    Lonehill (JHB)
    Thanked: 268
    Something like this?
    Check this out on takealot: ATEM POWER Smart Hub DC to DC Dual Voltage Display with Anderson Style Plug
    https://www.takealot.com/atem-power-...n/PLID97149023
    2024 Suzuki Fronx 1.5 GL Auto (Swambo)
    2022 Suzuki Swift 1.2 GLX Auto (my city bug)
    2018 Ford Everest 2.2 XLS 2x4 auto (holiday car)
    Echo 4 trailer
  13. #1612
    Apr 2019
    Thanked: 430
    Good day All
    Some advise would be greatly appreciated.
    I recently did some basic upgrades to the camper, adding a 12v, 100ah lifepo-4 battery,
    30a PWM,
    2 x 100w panels (Nominal Max. Power (Pmax) 100 W
    Opt. Operating Voltage (Vmp) 17.82 V
    Opt. Operating Current (Imp) 5.62 A
    Open Circuit Voltage (Voc) 22.14 V
    Short Circuit Current (Isc) 6.29 A)
    Would I be better off having the panels in series or parallel?
    I know the implications, voltage vs amps, but looking for some wisdom as to which will suit this setup better?
  14. #1613
    WC
    Thanked: 266
    I'm also hoping for a more learned response to this interesting question.... As I have it the following applies. Please correct me!
    In parallel, your combined output voltage will be lower, amps higher, but you will lose more over the length of your connection leads. You will also do better if one of your panels is in partial shade.
    In series output voltage will be higher, amps lower, and you will lose less over the length of your connection leads. But you will have no partial shade protection.
    It also depends on the power profile of the dc2dc charger. If this is not an issue, your connecting leads are short and say 4mm copper, go parallel.
  15. #1614
    WC
    Thanked: 266
    This from AI, I played a bit:
    Wiring solar panels in series increases the overall voltage, while wiring them in parallel increases the overall amperage. The choice between series and parallel wiring depends on the specific needs of the solar system, such as the desired voltage and amperage output, and whether shading is a concern.
    Series Connection:
    Voltage: Increases, with the voltage of each panel added together.
    Amperage: Stays the same as the individual panel amperage.
    Advantages: Useful for raising voltage to meet inverter requirements or when shading is not a concern.
    Disadvantages: Sensitive to shading, as one shaded panel can significantly reduce the output of the entire series string.
    Application: Suitable for systems where higher voltage is needed, such as for 24V or 48V battery systems.
    Parallel Connection:
    Voltage: Stays the same as the individual panel voltage.
    Amperage: Increases, with the amperage of each panel added together.
    Advantages: More tolerant of shading, as a shaded panel only affects its own current output.
    Disadvantages: Higher current can lead to increased wire gauge requirements and potentially higher power losses over long distances.
    Application: Suitable for systems where higher current is needed, such as for charging a large battery bank or when shading is a concern.
  16. #1615
    Thanked: 770
    Quote Originally Posted by stof-lappie View Post
    Good day All
    30a PWM,
    In your case with a PWM solar controller you should absolutely stick to parallel.
    Should you use a suitable MPPT solar controller, you could go either parallel or series.
    Series if your cable is fairly long (10m+) and/or thin say 4mm˛ or less.
    Personally I prefer series, but then I use long cables and make sure to get decent sunlight on the panels.
    Eggie.
    "You’re 18. Take that spoon out of your nose, take the needle out of your arm, take the beer out of your mouth, and go vote, you know what I mean? Vote. Register and vote like a beast.."
    - Frank Zappa
  17. #1616
    Apr 2019
    Thanked: 430
    Good day All
    30a PWM,
  18. #1617
    Apr 2019
    Thanked: 430
    Good day All
    30a PWM,
  19. #1618
    Bedfordview
    I've been wanting to create detailed wiring diagrams for my LC200, not only for my reference, I sometimes forget what I did, how I did it and why I did it a certain way, but also for 3rd party fault finding. I broke it up into three general areas:
    a) Vehicle Powered Accessories (Spots, Winch, VHF and some other smaller accessories)
    b) The 12 V Aux Power Solution (Load Draw, Charge and MOST important Monitoring the System)
    c) Shore Power Solution to enable safe shore power hookup. (AC Electrical work was built and installed by a certified electrician, and I have a COC for the solution)
    I am attaching the three screenshots that reference a, b & c above. Please feel free to comment and ask any questions. Additionally, I welcome constructive criticism. The "design" and "drawing" were done in Excel; I'm happy to share the file. DM me if you're interested.
Name:	Screenshot 2025-05-16 at 21.39.23.png
ID:	754132Click image for larger version.
Name:	Screenshot 2025-05-16 at 21.43.11.png
ID:	754133Click image for larger version.
Name:	Screenshot 2025-05-16 at 21.42.18.png
  20. The Following User Says Thank You to mkhumbioverlanding For This Useful Post:
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
