Electrickery for camping - Page 7
Page 7 of 63 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 32 57 ... LastLast
Results 121 to 140 of 1241
  1. #121
    So what do you guys think about a boat swich board build into the back.
  2. #122
    Hillcrest, Malaysia
    Quote Originally Posted by Adam Stander View Post
    Nice, but be careful. Most are utter Chinese junk.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
  3. #123
    Dec 2009
    Quick question?
    Where in Pretoria would one be able to buy all the goodies needed to wire up the Ctek 250s and battery and solar panels etc. Anyone have a good referral that does not charge stupid prices?
  4. #124
    May 2014
    Abu Dhabi
    Bushpower.co.za
    Based in Midrand
  5. #125
    May 2011
    Hi Guys, hope you can help? Firstly, thanks to all involved in putting together this guide; excellent work. I have been following this guide whilst building my system (will post some pics later) and have a couple of questions. But firstly the system I am looking to build:
    -input 1: 2 x 85 W solar panels in parallel to a BH plug. BH plug to Regulator. Regulator directly to aux battery in battery box.
    -input 2: starter battery to BH plug via 100A fuse. BH directly to aux battery in battery box (will connect/disconnect manually; as this charging will only be used on the odd occasion)
    -input 3: 25A AC charger with crock clamps onto aux battery terminals when AC is available.
    -output: Aux battery to fuse box via 100A fuse. Fuse box to: 2 x BH's, 2 x cigarette sockets.
    Question 1: My understanding is that the regulator (Victron 75/15) I will be using could also be used as a "traffic manager" (supply fridge, as well as charging aux battery). I have not put much thought into possibly using the regulator in this way? Suggestions?
    Question 2: Should there be a fuse/switch between the solar regulator and aux battery, seeing that the connection will be "permanent" to the aux battery; even when charged from AC / alternator?
    Any additional comments and suggestions would be greatly appreciated!
    Joe
  6. #126
    Mossel Bay / Roodepoort for Work
    Hey Joe.
    Copy from the Cruiserclub!! Phone Andrew at our offices and have a chat.
    Solareff - Solar PV Specialists
    www.solareff.co.za
    [email protected]
    011 675 1114
  7. #127
    Bellville
    Joe I have not tried this (using the battery and power point outputs) function. Sadly cant provide you with first hand info on this practice and its benefits.
    LEt's see what the other members say.
  8. #128
    Florida, West Rand
    Cool
    A question please, if I may.
    In post #8 the image of the MPPT regulator.
    What is the "Load" (+ and -) for?
  9. #129
    Quote Originally Posted by Hanman View Post
    You can leave it open. It is where you would connect loads such as lights for typical fixed solar installations. In our case with recreational vehicles equipped mainly with fridges, we seldom make use of this output, but rather connect directly to the battery.
    As an odd example: Should you use an Engel fridge/freezer that comes without it's own low voltage disconnect, this output could be useful to prevent the fridge from totally discharging the battery.
    Eggie.
    - apology to Edward Langley.
  10. #130
    Sep 2012
    Default VA meter
    Hi ek het die VA meter by 4x4Direct gekoop en gekoppel.
    Ek gebruik hom op my "ou zero" yskas.
    Wat vir my nou "odd" is die wyser A meter wys in orde van 4A wat volgens my min of meer standaard is vir enige yskas.
    Die digitale een wys soos op fotos in die 10ne .Maw 14.5 ens.
    Sien fotos aangeheg.
    Het ek dalk erens iets verkeerd gekoppel of gedoen. Het probeer om volgens die diagram te werk wat ek hier op die forum gekry het.
    Hoor graag een van julle se kommentaar.
    Groete Gerhard
ID:	298800   Click image for larger version.
ID:	298801   Click image for larger version.
ID:	298802   Click image for larger version.
  11. #131
    Krugersdorp
    Great post. It now makes sence to dumies to me!!
    Question I have the N/L system in mine(vehicle) with the selenoid, when my ship comes in I would also like to fit a Ctek but for now what dc2dc can I fit?
    Where can I get one that doesn't cost ann arm and leg??
    Tx
    Dirk
    Member - 4x4 Community
    Member - 4x4 Action Group (0044)
    Member - V Owners Group (VOG 081)
    Member - patrol4x4 forum
  12. #132
    Bellville
    Dirk will you be installing/using solar panels ??
    Use either the Ctek250 or the HCDP unit which switches AUTOMATICALLY between alternator and solar charging - IF you are going the solar route.
    If solar is not part of your planning, speak to the guys at HCDP and ask about their MPPT dc2dc charger options.
  13. #133
    Bellville
    time for the next episode ....
    Those that have read the full thread, and especially those that have bought some of these parts KNOW there are some "interesting sales talk" out there.
    So to TRY and get a bit closer to the real story behind the salestalk I installed three off Volt-Amm meters - these are distributed by 4x4Direct http://www.4x4direct.co.za/shop/
    Pieter is also a commercial member here.
    Here is the wiring diagram to my system -
    The attached pdf tells more of how I wired this.
    EDIT / UPDATE : 4x4Direct now has a number of different meters. I used a 20A meter for the soalr and Ctek circuits. Then used a 50A meter for the battery circuit - bear in mind I have a full distribution network supplying various electrical items, thus the larger meter.
    I am planning a series of experiments ...
Name:	wiring VA meter.jpg
    Attached Files Attached Files
  14. #134
    Jan 2008
    North of Zambezi
    Chris why only 12.9V to the battery, was your battery SOC 100%?
  15. #135
    May 2012
    Hout Bay
    Apologies if I'm posting this in thew wrong thread but I need some advice on supplying electricity to a bush camp.
    The camp will accommodate 10 - 15 people and the electricity will not be required for heating or cooking. Main requirements will be fridges, lighting and charging batteries for cameras and computers etc. It's a permanent requirement - not just once off.
    Any thoughts on the options and costs will be appreciated.
  16. #136
    Bellville
    Glassman please contact "Offroad Addict" - http://4x4community.co.za/forum/member.php?u=600
  17. #137
    Bellville
    Quote Originally Posted by mfuwefarmer View Post
    Oom Bertie ek het n reeks fotos geneem gedurende die installasie - ek kan regtig nie die omstandighede rondom die foto onthou nie ....
    Sodra ons weer son het hier in die Kaap wil ek die battery 50% ontlaai - dan in die son parkeer en die laai spanning en stroom monitor. Ek het nou al reeds gesien hoe die Ctek die stroom "throttle" soos die battery se SOC styg.
    Sit die yskas aan en die grafiek verander weer ! So dit sal n ander eksperiment wees.
  18. #138
    May 2012
    Hout Bay
    Thanks. Will do.
  19. #139
    Mar 2011
    Walker Bay
    Excellent post Chris!
    Nice to continue passing on your expertise to forum members.
  20. #140
    Jan 2008
    North of Zambezi
    Quote Originally Posted by Mistral View Post
    +1
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
