Page 76 of 82 FirstFirst ... 71 72 73 74 75 76 77 78 79 80 81 ... LastLast
Results 1,501 to 1,520 of 1633
  1. #1501
    Jun 2022
    Thanked: 1551
    Default Re: Electrickery for camping
    Nice, makes them reusable.
    indeed. You hook up the two little wires to yours and then it has a little LED which lights up to show there is power.
    very neat.
  2. #1502
    Mar 2011
    Walker Bay
    Thanked: 2389
    Web link please!
    Quote Originally Posted by dilligafrican View Post
    No more crimping.
    Saw these in the web. Ozzie company makes them.
    will be ordering.
  3. #1503
    Jun 2022
    Thanked: 1551
    Web link please!
    whoops … sorry. Thought I did paste it.
    https://www.kickassproducts.com.au/B...tions/TVUSCHEU
  4. The Following 2 Users Say Thank You to dilligafrican For This Useful Post:
  5. #1504
    Thanked: 391
    Hi folks
    Had an interesting 5 day camping trip with a poorly working electrical system.
    Hcdp mk4 power panel, two AtlasBX batteries, 180W solar panels. Batteries were ‘fully charged’ for a few days prior to the trip with AC. No charging during the trip to camping site. Evening noticed the fridge was off and voltage reading on the power panel low. No other 12V items working either. Next morning once the sun was up, and the PV panels were doing their thing, the fridge could run again. Once panels were oit of sun, the battery voltage drops quickly and fridge stops working.
    This ended up being the story for the next three nights as well. Luckily managed to keep the fridge cool through the night by using frozen items from the fridge in my bakkie.
    How do I determine the cause of the problem? Faulty power panel not charging the batteries as it should or faulty batteries? I suspect the batteries are the issue.
    Jacques
    2014 Hilux D4D dc 4x4
    2013 Metalian Maxi
  6. #1505
    Okahandja, Windhoek
    Thanked: 2317
    Quote Originally Posted by KrokODell View Post
    Jacques
    Meaning the HCDP panel is not charging from the alternator?, then it quit possible a poor connection somewhere?
    Johan Kriel
  7. #1506
    Thanked: 4907
    Losing power that fast I would go for batteries. With 2 batteries you should have power for at least 2 - 3 days, I have seen dead cell batteries come up to 12.6 and stay there for a few days only to drop like a stone with a light load on them
    Henk
    Follow us on Facebook
  8. The Following 4 Users Say Thank You to hbannink For This Useful Post:
  9. #1507
    Thanked: 391
    Yes I also think batteries. Is the best option for testing them to take them to a battery shop tobe tested?
    2013 Metalian Maxi
  10. #1508
    Thanked: 391
    No, sorry, the Hcdp is in the trailer, not connected to the bakkie.
    2013 Metalian Maxi
  11. #1509
    Thanked: 391
    Another question, how long can the cable be between the PV panels and Hcdp panel? I know voltage drop and thus cable size is important between the batteries and the load.
    2013 Metalian Maxi
  12. #1510
    Thanked: 4907
    On a 6mm cable I do not like to go more than 5m, at a push 10m. Your panel has a 18V open circuit output so it will not give the full charge if it loses voltage but it will still charge.
    Take them to a battery place and ask them to do a capacity test. There are some great testers available that can tell you exactly what you have
    Henk
  13. The Following User Says Thank You to hbannink For This Useful Post:
  14. #1511
    Hillcrest
    Thanked: 21657
    Batteries - if not an actual electrical fault - HCDP, loose connectors etc
    Do a controlled test now that you are at home and report back.
    NAGOF
    HAM Callsign - ZS5KAD
  15. #1512
    Thanked: 391
    Fluffy, what would a controlled test be?
    I assume - charge fully with AC, once full, switch on fridge and see how long the batteries last?
    I did check voltages last night. Voltage on terminals (with voltmeter) correlate to that of the power panel. When turning on the AC charge, the voltage does go up to >14V and the fridge is able to run. When I unplug it, the fridge turns off. Batteries are now charging. Will report back. Thanks
    2013 Metalian Maxi
  16. #1513
    Thanked: 391
    Thanks Henk
    I think I have around 5-6m cable. I want to make another section of similar length. Attach them to each other with the BH blocks. Just in those odd situations where you cannot get to decent sun with a shorter cable.
    2013 Metalian Maxi
  17. #1514
    Thanked: 391
    Not looking great...
    After 24 hours of charging (with AC) the voltage on power panel was 13.83V. Confirmed this with voltmeter on batteries - 13.9V.
    After swimming switching the AC charger off, the voltage drops down to under 12V within 10minutes, despite no load running (0.02A draw, assume this is the panel itself).
    Not able to switch on the fridge or even the LED lights when AC charge is off. When om, the fridge appears to run as normal.
    Next move... Will remove the batteries and test them individually. Will also try revive them with my National Charger. Will also see if the system runs normally with a different (functional) battery.
    2013 Metalian Maxi
  18. #1515
    Malmesbury
    Thanked: 246
    i don't know if this has been mention before
    this is my 2nd set BH plugs, the plugs is away from the sun in my camper , but they disintergrate as if the plugs nowadays are plastic crap , it is not the only the blue one's, the grey and red's fail overtime ,busy to rewireing mine so that there is min. plugs ,but on my solar i have to use the blue one's,,any advice please .
    [SIGPIC]
    alberto pereira
    Colt clubcab 2.8tdi 4x4 2005
    nissan x trail t30 2008
  19. #1516
    Mar 2011
    Walker Bay
    Thanked: 2389
    Where to buy quality plugs?
  20. #1517
    Tshwanetoria
    Thanked: 4771
  21. The Following 2 Users Say Thank You to hatjohan For This Useful Post:
  22. #1518
    Thanked: 4907
    Sadly at least one if notboth of your batteries have lost a cell or two. Fully charged just from the charger is 13+ V but that drops to full charge float after a while of 12,65v. Without load that should remain in that area but dropping below 12V shows a dead cell or...
    Henk
  23. #1519
    Thanked: 882
    Quote Originally Posted by Alberto View Post
    This is worrying. How old are these broken connectors?
    This is the first time I see this happening.
    I am using a set of Lumino brand connectors for a year now and just bought another pair of brand new Lichen brand connectors at 4x4 Ditect in Vredenburg last week.
    The Lumino ones is used at the back of my solar panel and to connect to a National Luna brand connector in the engine bay. No problems so far, but you got me worried now.
    Had the National Luna brand for a few years now with no problems at all.
  24. The Following User Says Thank You to Viertrek For This Useful Post:
  25. #1520
    Thanked: 391
    Yes Henk, both are kaput. Cannot even revive them with a decent charge. I tested the system with another battery and it all works. Now to replace both batteries. Eina.
    2013 Metalian Maxi
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
