Electrickery for camping - Page 64
Page 64 of 64 FirstFirst ... 14 39 54 55 56 57 58 59 60 61 62 63 64
Results 1,261 to 1,273 of 1273
  1. #1261
    Apr 2012
    Brackenfell
    Thanked: 19
    Default Re: Electrickery for camping
    Morning
    Looking for a proper copy of this doc, it is settings for Victron MPPT and BMV-712 Monitors. Don't know if i download it from this forum or Victron website tried the Victron website don't see it there, also did a search on 4x4 Community website.
    Also want to ask I Have 200Ah AGM battery if the settings on the doc make sense.
    I have the following Victron products installed. Also looking for possible settings for other Victron products I have.
    2 X BMV-712
    2x MPPT 100/30
    1x Charger IP22 12/20
    1x Charger IP67 12/25
    Thankyou
  2. #1262
    Apr 2012
    Brackenfell
    Thanked: 19
    Quote Originally Posted by DieselDonkie View Post
    Morning
    2 X BMV-712
    2x MPPT 100/30
    Thankyou
    het vandag my solar getoets ek het 3 x 100W panele en die volgende gesien dit was bewolk so watss was laag maar kyk die volts hoe hoog dit is en amps laag ek is confused Click image for larger version.
  3. #1263
    Thanked: 190
    P=VI
    25 = 15.32(1.6)
    Yeah, it sounds about right.
    2018 Ranger DC 2.2 XLS Auto 4x4
    Canon 5DMkIV with L-goodies.
  4. #1264
    Mar 2011
    Walker Bay
    Thanked: 1068
    How many Amps?
  5. #1265
    Wartburg
    Thanked: 1555
    Quote Originally Posted by Mtber View Post
    P=VI
    25 = 15.32(1.6)
    The figures add up. But I would have expected slightly higher figures as well, comparing them to my setup on my camper.
    I wonder if fitting them in series would give better efficiency in cloudy weather during peak times, like when the above data was taken? It would certainly start charging a bit earlier and a bit later, even if not substantial. I have 4 panels, 2 parallel banks, each in series. It still gives a decent charge in full shade - about 20% of full sun capacity, if I remember correctly.
  6. #1266
    midrand
    wow what a marathon read !! taken me about 5 days start to finish.
    I have the following setup in my 2010 DC Hilux , 100w panel from Bushpower on the roof rack, via 10w PWM controller to discover EV31A-A ( 4 years old) in engine bay linked to main battery by NL intelligent solenoid. One lead into cab to run 40l NL fridge on back seat , one lead to bin to run same fridge when canopy is on and we go away.
    I have added and modified the system as time has progressed and I am ashamed to say that the wiring looks like a big mess but it works. Who can you recommend to re do the wring so it looks really neat ?
    PS I'm located in Fourways ...
    Many Thanks
    The slight variations in spelling and grammar enhance this email's individual character and beauty and in no way are to be considered flaws or defects<o>.</o>
    Toyota 3.0 Double D 4x4 2010 AT
    Rubber drivers floor mat
    Scratch on right rear
    Cooper ST Maxx
    Orange spade on front nudge bar
    ARB 6" spot covers ( broken and fixed many times )
    Detachable tow bar
    Hot blonde co pilot
  7. #1267
    Thanked: 49
    Quote Originally Posted by oxman View Post
    Many Thanks
    maybe share a pic as a pre warning
    When nature calls
    Jacques Steyn
    2009 Toyota Prado 150 VX (202kw)
    OL Front bumper | Snorkel | OME Suspension
    Swambo : 2012 VW Polo 1.4 Comfort line
    Ex 2008 Nissan Patrol 4.8 GRX A/T (199kw) | TD Suspension | Outback Extreme Rear Bumper | Ironman Front Bumper | Air Helpers | Snorkel | FR Roofrack
    Ex 1996 Ssangyong Musso 602EL TD A/T Exec (82kw) |Snorkel | Bilstein B6 | Disco 2 springs | FR Roofrack | ARB Front bumper | Rear Bumper
    Ex 1982 Citroen CX Prestige automatic
    Ex 1976 Citroen GS Club
    Ex 2013 Honda CRV Exec Auto AWD
    Ex 2007 Toyota Auris 2.0 D4D
    Ex 2010 Honda Accord 2.4i Exec Manual (148kw)
    Ex 1997 Isuzu KB280LE TD D/C 2x4
    Ex 1997 Toyota Corolla RSI (121kw)
    Ex 1989 Toyota Corolla GLI TwinCam Exec (98kw)
  8. #1268
    Stutterheim
    Thanked: 19
    Hi! Just want to check if this looks ok
    At long last did the solar panel connection to my Jurgens Oryx today.
    WRND Solar controller and DC-DC charger
    1x 100W (120W?) solar panel
    2 x 75ah AGM batteries in the Oryx, connected for 12V
    See photos -
    WRND shows charging from Solar
    volts from Solar panel before WRND - 33.2V
    volts at batteries after WRND - 13.5V
    Does that look about right? The charging voltage from the WRND not too high?
    Appreciate any input.
    Groetnis
    Deon
    2012 Nissan Navara DC 2,5DCi 4x4 AT
    (SOLD) 2002 Nissan Terrano 2.7 TDi
    1982 BMW R100RT
  9. #1269
    Ellisras
    Thanked: 556
    Not to high. Above 14.4V will indicate a problem
  10. The Following User Says Thank You to Dungbeetle For This Useful Post:
  11. #1270
    Aug 2010
    Boksburg
    Thanked: 14
    Quote Originally Posted by DeonStr View Post
    See photos -
    Groetnis
    Deon
    I would suggest TOO LOW. Unless the batteries are already at full charge?
    From my understanding, deep cycle type batteries require 14.4 V to get to a full charge. The WRND does detect the charge status of the batteries and then 'switches' off the charging to the batteries to protect them. There is a low threshold where it will switch back on again.
  12. The Following User Says Thank You to Festi1 For This Useful Post:
  13. #1271
    Stutterheim
    Thanked: 19
    Quote Originally Posted by Festi1 View Post
    Hi Festi!
    Thanks for the info! The batteries were full or just about.
    Groetnis
    Deon
    1982 BMW R100RT
  14. #1272
    Feb 2017
    Klerksdorp
    Thanked: 73
    Ek sien die tyd van jou lesing was net na 1 die middag die rede dalk vir lae watts is om jou batterye dalk al reeds vol gelaai was dan deop die watts en die amps namate die batterye vol laai , nie altyd bewolk wat min watts in bring nie,
    Ek het ook ge sien die UV beteken meer as direkte son en oartykeer kry jy meer gelaai met n wolk voor son as direkte son.
    N koue & skoon PV son paneel gee ook beter werk verigting jy kan dit toets waneer jy dit skoon gemaak het en nat gespuit het om af te koel dit gee meer amps
  15. #1273
    Feb 2017
    Klerksdorp
    Thanked: 73
    Yup thats all said correct this is why they call it intelligent chargers
    Otherwise we had overcooked batterys all the time & hot drinks & meat in the freezers
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
