Electrickery for camping - Page 63
Page 63 of 63 FirstFirst ... 13 38 53 54 55 56 57 58 59 60 61 62 63
Results 1,241 to 1,253 of 1253
  1. #1241
    Thanked: 501
    Default Re: Electrickery for camping
    My Victron is of the 600 series before Bluetooth.
    When the charge voltage remains above a certain voltage AND the charge current drops to below a certain threshold for a preset time, then the monitor automatically synchronizes.
    You would have to consult your specific model's manual to know if yours does the same or if it requires some form of user intervention.
    Eggie.
    - apology to Edward Langley.
  2. The Following User Says Thank You to Eggie For This Useful Post:
  3. #1242
    Oct 2012
    Fourways
    Thanked: 188
    Hi Guys,
    Why would my DC to DC charger be charging my Auxiliary battery at 17.4v? Surely this will damage the battery?
    2017 Fortuner 2.8 GD6 4x4 Auto
  4. #1243
    Thanked: 501
    Quote Originally Posted by Donlux View Post
    Hi Guys,
    That is bad news - disconnect your utility battery without delay and have the utility charging system checked out.
    While you're at it, have your meter checked as well.
    If it is a multitester type, check/replace its battery.
    Eggie.
  5. #1244
    King Williams Town
    Thanked: 906
    Quote Originally Posted by Eggie View Post
    Aaah, very good advice. Once had a contractor claiming our municipal voltage was at 500v plus between phases and 300v phase to phase. Installed a new battery into his test meter and voltages came down to what they should be.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  6. #1245
    Cape Town - RSA
    Thanked: 318
    With a trip to Maubua coming up, I recently did an experiment with my current setup, in order to clarify in my own mind how the fridge and battery behaves and to measure the amounts of amps required to do typical work loads. I share here for anyone interested. A lot of what I discovered lines up with existing forum advice.
    Setup:
    10mm cables running direct from main battery to boot.
    Plugged into snomaster battery box, which has a manual isolator switch.
    Ritar 105aph AGM battery
    Snomaster 50L fridge.
    basic inline voltage and amp meter (Link)
    I only recently purchased the meter. So for the first time I could measure the amount of amps flowing through the system.
    Experiment:
    Input charge:
    First thing I did was discharge the battery by roughly 20amps (so open to bulk charging), then I plugged in the battery and meter to the Jeep and took a drive. Measured the amount of amps flowing into the battery through the 10mm cables. After about 15 minutes of driving around normally it averaged out at between 11 and 13 amps. This was very valuable and interesting to me. As the Jeep has a really powerful alternator, I was expecting this number to be higher. I'm currently considering if its worth it to switch to a WRND DC DC system, and was worried that the 20amp max charge limit may actually hinder me. This proves that it will certainly not. Now I might have gotten better results with thicker cables or a high cycle battery, but for my personal setup this was good data.
    Consumption:
    Now that I had a baseline for how fast I could recharge a battery, I wanted to get a feel for how much power I would pull from it, considering some worst case scenarios. So I let the fridge warm up to room temp (20 degrees), then put in a few bottles of room temp water, including a big 5L one. Set the temp to -15 and let rip. This was all pulling from the 12V battery, not 220V, and I simulated a 120W solar panel by plugging in my battery charger which delivers max 5A. The fridge started out at 15c and then slowly started dropping. 21 hours later I checked it and it had dropped to -5c. This was much slower than I had expected, although it is understandable considering what it needs to cool. What is interesting and important is that everything inside was now frozen solid. So I'm not convinced that going any lower will make any difference. I adjusted it this morning to -10. Will check when I'm home tonight.
    The compressor ran pretty much full time and used an average of between 3.5 and 4.5 amps constantly. The battery has charged back up via the charger. However this assumes the sun will be shining for 21 hours which seems unlikely. But it does prove that with a 5amp input it will at very least hold its charge, and with a bit of luck add a small amount back.
    Take Aways:
    Precooling your fridge at home before you leave on the trip definitely makes sense. It takes a lot longer than you think to get everything frozen. A 8 hour drive to your camp spot will not be enough. Bank on 24 hours to be safe.
    Try get a measurement of how many amps you are getting whilst on alternator charge. It might be less than you think. An hours game drive will probably only give me 5-8amp hours if you stop and turn off your engine to view animals.
    If you are at hot location, bank on your fridge pulling 4amps an hour constantly. Plan accordingly.
    I don't really see the value in setting your fridge way low, like -18. Unless someone can explain to me? Once everything is frozen, its frozen.
    Future plans:
    I think i'm going to invest in a WRND, and see if the amps improves when alternator power. If it can consistently give me 20amps, that will help.
    I'm also going to go for a 120W solar panel, and will do some experiment to check if I can average 5amps an hour. Also, it might we worthwhile have the WRND auto switch between the alternator and solar, that way if you are out on a drive, you make max use of the time. (assuming solar panel on roofrack)
    Ex - 2005 Cherokee CRD
  7. #1246
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 755
    It seems your system is designed to operate while driving, if I read correctly?
    What is your plan for overnight supply?
    Your 1x105Ah battery may not hold up through the night when your fridge is running at optimum.
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
  8. #1247
    Cape Town - RSA
    Thanked: 318
    Well, I dont think you can have anything overnight unless I setup a windmill.
    But yes, the motivation here is to find out if I will get by with 1x battery and a 120w solar panel, with a daily game drive. I don't think I will.
    Option 2:
    Get a second battery and leave it in the trailer running the fridge and getting solar. Therefore splitting the load between the two batteries.
  9. #1248
    Jun 2008
    Thanked: 755
    I will recommend 2x panels at the campsite.
    Trying to remember our figures
    - Remember the camp panel needs to replenish the previous night's battery use AND the fridge use at the time simultaneously.
    - One panel may supply around 5A and that will not be sufficient to charge the battery full and ready for the following night. Two panels will do.
    - Why then fit one panel to your tow vehicle? The alternator does that job quite well.
    Use both panels at the camp while on your game drive and connect the panels when back in camp to both the (car) additional and trailer batteries
    My setup.
    Isuzu 300 d-tec
    BMW R1200GS & GSA
  10. #1249
    Thanked: 605
    So I have a question regarding LifePO4 batteries.
    I see you get affordable ones now that would do well in my Trailvan. 120AH. From here https://lithiumbatteriessa.co.za/
    How do I go about charging such a battery from the alternator/solar panels? I have DC - DC charger in the Trailvan, but pretty sure that is no good for the LifePo4 as it does a trickle charge after fully charged, which LifePO4 batteries cannot handle. Or can I just use it anyway and the batteries own BMS (battery management system) takes care of switching off additional charge to the battery? Not sure what that will do to my DC-DC unit?
    Any experience with this here?
  11. #1250
    Polokwane
    Thanked: 476
    My setup.
    Quiksilver this is good advice from Johan.
    My setup consists of three batteries and two sets of solar panels.
    One - The fridge in the Jeep is powered by the first 105ah DC battery in the Jeep, which is charged by a WRND when mobile and 2x120W solar panels when stationary.
    Two - The second 105ah battery for my CPAP is in the trailer and is charge by 2x150W solar panels through a charger controller.
    Three - When leaving camp there is a third 105ah battery with it's own charger controller, also in the trailer, which get connected to the 2x120W solar panels mentioned in "One" above.
    I run my fridge on 2º during the day, 4º during the night and 0º when driving around.
    This setup gives me great flexibility for a lot of camping scenarios.
    I've build this setup over a couple of years.
  12. #1251
    Thanked: 342
    AFAIK these controllers have settings to use the correct setting for Li-Ion
    https://re-volt.co.za/Store/index.ph...product_id=102
  13. #1252
    Apr 2012
    Pretoria East
    Thanked: 9
    yello:
    also saw those batteries:
    the national luna dcdc 25a will work according to their website.. bit pricey though at almost 6k
    wnrd and hcdp :
    cannot get info on their websites..
    victron orion tr dcdc charger will work but still need solar charger then....
    the hcdp power panel can be ordered li ion ready afaik
    W
    Wouter
    Me:2018 Toy Fortuner 2.8 auto 4x4
    Swambo: 2017 Audi Q3 aka cutie
    Echo 2 in tow
  14. #1253
    Jan 2017
    Thanked: 129
    I note these batteries are 3.2volts each...so one would need a bank of 4 of them to run, for example, a 12v fridge/freezer?
    Correct?
    Series 80 'Cruiser GX Diesel 1996
    Cooper ST Maxx 265/75/16 tyres;
    ARB bullbar; 9000kg T-Max winch; Outback roofrack; Double fuel tank; Outback Extreme spare wheel carrier x 2; Air Spring boosters; Racor diesel filter; NL dual battery set-up; 2 x 100w solar panels; Big Coubtry gullwings, Front Runner drawer system; Stofpad 4x4 drop-down fridge slide; NL 78-litre double door fridge/freezer; NL 60-litre freezer; Eeziawn rooftop tent; Eeziawn awning.
    Previously: '98 Defender 110 HT TDi, Lady SIII S/W, Hilux D/C 4x4,
    Isuzu 2,3 4x4, Isuzu 2,0 4x4, Isuzu 1600 4x4, Chev Nomad, Cheetah beach buggy!
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
