Electrickery for camping - Page 62
Page 62 of 62 FirstFirst ... 12 37 52 53 54 55 56 57 58 59 60 61 62
Results 1,221 to 1,233 of 1233
  1. #1221
    Hillcrest, Malaysia
    Thanked: 5888
    Default Re: Electrickery for camping
    Nothing wrong with the setup. With the current of each panel at about 5.5A if you don't want to limit the current the MPPT must be 25A or more if the panels are in ||. If in series you would need MPPTs that can handle 5x open circuit voltage which you can get on the panels. It could be as high as 110V.
    As you intend using the panels for one of the two batteries at a time I would use only 1 MPPT and connect the output via plugs to the battery being charged. Nothing wrong with 2 x MPPT as above it is just a saving of perhaps R2000+ as a 25A MPPT does cost a bit. If you have the MPPTs fixed then 2 would be the only way to go.
    Just out of interest, the MPPT would need to be the same current, doesn't matter if the panels are in series or parallel. The current spec refers to the charger output current, not the input current.
    I wish I could convince people from to converting Watts to V and I unnecessarily and just stay with Watts.
    5 x 100W panels is 500W input which is 42Amps at 12V So ideally one would need 50A chargers. (Think of the case where the one battery is flat and the other is full. The flat one may try and pull all 500W)
    Just out of interest, as already noted above, I have never seen two MPPT's with their inputs commoned. Just exactly what would happen is unknown and depend of the actual chargers. In any event the chargers would have to be designed to do so and need a communications link between them. Just this last week I did a 10kW system where the MPPT's literature dealt extensively with connecting the batteries, AC input and Loads in parallel between the two system but expressly had the PV's separate.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  2. The Following User Says Thank You to Fluffy For This Useful Post:
  3. #1222
    Thanked: 290
    Perhaps one must start with knowing what fridge model and make is to be installed in orfer to calculate the load supplied by the battery for the period without sun.
  4. #1223
    Hillcrest, Malaysia
    Thanked: 5888
    Quote Originally Posted by Paul Smith View Post
    Are lithium batteries somewhat more affordable these days?
    The last time I looked, the prices were astronomical...
    You are correct on both accounts. They are both more affordable and astronomical.
    Worth watching this
    https://youtu.be/7xxqP4Tt71w
    About R10K
    ZS5KAD
    3 V8's
  5. #1224
    Ellisras
    Thanked: 412
    Drop in replacement for 105.
    Will my existing HcdP DC -DC Mppt charger be compatable?
    2000 Patrol GU 4.2D(onkey) beyond 830 000 km
  6. #1225
    Hillcrest, Malaysia
    Thanked: 5888
    My assumption is yes. ?
    ZS5KAD
    3 V8's
  7. #1226
    Aug 2017
    Tygerwaterfront Bellville
    Thanked: 85
    Good evening electrickery experts. I need advice please. I have 2 x 100 W solar panels with a solar charge controller permanently fitted on my caravan roof. I also have a loose standing 105 W Solar panel with a solar charge controller that i mostly use to power the fridge in my car. My question is, can I plug the loose standing 105 W panel into the grey brad harris plug fitted on my caravan to increase my available power to 300 W or should i rather just use the power from the panels on the roof ? Thank you for any advice.
  8. #1227
    Thanked: 290
    You can plug the loose panel in the BH on van. If the Caravan does not stand in full sun all day it will boost the charge rate quite a bit. If standing in full sun your battery might just be fully charged earlier unless you use more power than only fridges.
  9. #1228
    Florida
    Thanked: 630
    Quote Originally Posted by SP1971 View Post
    The panels on the roof have separate controller. You will firstly need to check your wiring/setup to see if that grey BH plug is connected to the same controller. If it is then you need to check what the max input Watts are that the controller can handle. Yours would be 305W.
    Also IMHO you should not connect two different controllers to the batteries via the setup you have. Saying this I have isolated my two batteries in the van from each other so that when the need arises I charge each battery separately from two different solar setups. One being a HCdP MK 5 (which has a max 270W input) in the van and the other an Outback unit.
  10. The Following User Says Thank You to TRON For This Useful Post:
  11. #1229
    Florida
    Thanked: 630
    My personal feeling is that the time has come for people to at least consider Lithium based systems, especially in a new build.
    Look at the offerings from BlueNova. Same format as a standard battery with built in BMS so they are compatible with alternators etc.
    You will save on weight and space and have superior performance. Not only that but it will probably be the last battery you ever buy.
    Get the trailer manufacturer to rather install the battery now and offset the costs against the intended 105AH.
    Fluffy is spot on, especially with a new build. I am considering doing a change to LiFePO for both my Companion and Defender.
  12. The Following User Says Thank You to TRON For This Useful Post:
  13. #1230
    Hillcrest, Malaysia
    Thanked: 5888
    Depends. We need a lot more information.
    Panel types and configuration.
    Solar charge controller type.
    Why would you need to or want to do this ?
    ZS5KAD
    3 V8's
  14. #1231
    Aug 2017
    Thanked: 85
    Good morning Fluffy. Thank you for the reply. I will send more info asap. Its just for peace of mind should the caravan maybe stand in the shade then i can at least move the 105 W panel around to have max sun. Currently i have a 90 L NL Fridge and a few LED Lights so im sure the 200 W will be fine. But with my luck in the bush...lol
  15. #1232
    Thanked: 197
    anyone have experience with the flexible panels?
    Wondering if I can mount them to the roof rack while driving, not sure if the flapping/vibrations will damage them over time?
    https://www.bushpower.co.za/product/...flex-panel-kit
    https://flexopower.co.za/products/mo...19505395269689
  16. #1233
    Mar 2011
    Walker Bay
    Thanked: 1000
    I don't think that is a good idea. Plenty of vibration on the rack. I have Flexopowers and would not mount them there. If I recall they are not waterproof.
    See this:
    https://flexopower.co.za/blogs/news/...e-a-slow-death
    Quote Originally Posted by D-tox View Post
    za/product/flexpower-tacoma-120w-semi-flex-panel-kit
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
