Electrickery for camping - Page 57
Page 57 of 58 FirstFirst ... 7 32 47 48 49 50 51 52 53 54 55 56 57 58 LastLast
Results 1,121 to 1,140 of 1142
  1. #1121
    Jun 2018
    Hoedspruit
    Thanked: 11
    Default Re: Electrickery for camping
    I would like to run something by you all. We have purchased an off-road trailer at last (packing up the vehicles RTT every time we wanted to go somewhere got a bit tedious).
    I am going to be redoing the trailers electronics and lights etc as the previous owner only had 220v and this will not work for us as we like to go to remote areas with no power as well.
    So instead of having two different systems in the trailer I would rather just use a 12v system.
    What ive been thinking is the following drawn in the diagram below.
    Please let me know if I’m missing something and having a moment or if there is another option than this idea. You should be able to have it all work at the flick of a switch.
    Mike
    Out in the bush!!
    1999 Discovery 1 3.9 v8 (3 door)
    1956 Series 1 (just running with rebuild about to start)
    2016 VW Polo Vivo Maxx (for the long road)
  2. The Following User Says Thank You to AfricainHD For This Useful Post:
  3. #1122
    Mar 2011
    Salt Rock
    quick question for the electricians..
    wired a WRMD charger in, has been chariging dual nicely..
    However, main batt is dropping when freezer is running ( whilst not driving)
    ignored the 'optional' red cable to ignition, would this be the culprit?? - as far as I understood, charger would not drain main batt below 12.5?
    if this is the problem, where would be a good place to splice in on a 95 series Prado?
    TIA
  4. #1123
    Thanked: 218
    Quote Originally Posted by 1342 View Post
    TIA
    That ignition point is the input to the WRND to indicate the engine is running and the main battery can be connected to the 2nd battery. Without is at 12V it should not connect. That is how I understood it when looking at the unit at a 4x4direct shop.
    @AfricainHD
    Drawings looks fine but bear in mind that to input the 220/12V power supply to the WRND AFAIK you will have to put a 12V pos on the IGN point in order for the power to go through to your 2x105Ah batteries.
  5. The Following User Says Thank You to ekkekan For This Useful Post:
  6. #1124
    Mar 2011
    Salt Rock
    Thanks Ekkekan
    I'm on it, gonna be a late night
    without going through the dash, is there a + point I can use?
    Sorry for the late questions, leaving tomoorow on a trip hahaha
  7. #1125
    Thanked: 128
    Maybe get 12v + from towbar aux connector. Is usually powered by ignition. Check with volt meter un plug & try to splice into cable as likely runs in boot trimming if standard fitted.
    http://www.ventertrailers.co.za/trai...g-diagram.aspx
    Bennie van der Merwe
    2007 Discovery 3 V8 SE
    Prev 2001 Pajero 3.2 DiD Lwb M/T
  8. #1126
    Mar 2013
    Molopo
    Thanked: 56
    Thanks Ekkekan
    The + ign wire only needs to be connected if you have a vehicle with smart alternator, which yours do not have.
    Sounds to me as if something else is wrong there. Double check all your connections. If all in order the unit might be defective.
  9. The Following 2 Users Say Thank You to HannoK For This Useful Post:
  10. #1127
    Polokwane
    Thanked: 231
    TIA
    This is from their website, the main battery should not drain.
    "If the engine is turned off charging will stop once the primary battery settles at 12.8V. At this time the WDB1220B will start charging the secondary battery from a solar panel if available. "
    "Primary battery voltage for charging: 12.5V - 14.5V"
    What colour LED on the charger controller is lit when this happens?
    How do you know/see that the main battery is dropping? The main battery will drop when the vehicle is switched off and will settle on about 12.6-7V (if the battery is in good health) after 10-20min.
  11. The Following User Says Thank You to DC Polokwane For This Useful Post:
  12. #1128
    Polokwane
    Thanked: 231
    Quote Originally Posted by AfricainHD View Post
    I would not run the 12V/20A 220v power supply (charger?) through the WRND but connect it to the 2 x DC batteries. Skip on the three-way switch.
  13. The Following 2 Users Say Thank You to DC Polokwane For This Useful Post:
  14. #1129
    Mar 2011
    Salt Rock
    Thanks DC Polokwane, thats what I thought too
    Spliced + into wiper motor, now blue light comes on when ignition is on, and blue light is off when ignition is off..
    hopefully all good, into bots tomorrow morning, hopefully all works
  15. #1130
    Mar 2011
    Salt Rock
    Quick report back... After spice into ignition, via wiper motor, charger worked well... not sure why it drew off main below 12,3V, but all went well for the trip.. had ice when I got home ( beers froze ) Bad earth on buzzbar, but easily solved... thanks for the advice
  16. #1131
    Apr 2014
    Hi All
    Before I blow something up, just want to get some advise. I would like to connect the laptop charger to an inverter when we are off grid.
    I have a HCDP MK 4 power power panel in the trailer to which I connect the solar panels and run all the 12v and fridge. The panel also changes the battery. Would it work connecting the inverter directly to the battery while it is also connected to the power panel?
  17. #1132
    Thanked: 218
    Yes all will be fine. Actually better to have the battery connected to the HPP MK4 so that battery can charge while the inverter is being used either from solar or 220V.
  18. The Following User Says Thank You to ekkekan For This Useful Post:
  19. #1133
    Gauteng - Ex Cape Town
    If you’re charging the battery from 220 I guess u don’t need an inverter
    Just an observation.
    Jeep Grand Cherokke 4.7 V8
    Outback Roof rack
    Draw sytem
    Dual battery with DC-DC
    OME suspension
    Air lift Air suspension - Self installed
  20. #1134
    Apr 2018
    Baie dankie vir die mooi uiteen setting!
  21. #1135
    Apr 2014
    Quote Originally Posted by iluvjeep View Post
    No will only be using the inverter when off grid. Battery will be charged from solar
  22. #1136
    Apr 2014
    Quote Originally Posted by Andre Bos View Post
    Ek teken te lelik so moes maar prentjies gebruik
  23. #1137
    Thanked: 557
    Finally got round to fitting the hinges and legs to the solar panels. The 10m power lead is made up with the correct plugs to connect into the caravan and the panels. The blue B/H is the solar into the caravan, the grey and cigarette lighter socket is a 12v output for use around the caravan. Click image for larger version.
ID:	526164Click image for larger version.
ID:	526165Click image for larger version.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  24. The Following User Says Thank You to Paul#25 For This Useful Post:
  25. #1138
    Dec 2010
    Thanked: 92
    Nice setup. What size panels are those? Looks like x2 120w? I'm looking at making similar but I'm torn between rigid panels or semi flexible. Only reason being semi flexible take up less space as I plan on packing it in my trailer
  26. #1139
    Thanked: 557
    Quote Originally Posted by GKE View Post
    They are 2 x 100w panels. The cable is made up from solar grade 4mm cables I have linked together with shrink sleeve. Click image for larger version.
ID:	526167Click image for larger version.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  27. The Following User Says Thank You to Paul#25 For This Useful Post:
    GKE
  28. #1140
    Feb 2017
    Klerksdorp
    Thanked: 61
    Very Nice enjoy
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
