Electrickery for camping - Page 33
Page 33 of 63 FirstFirst ... 8 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 58 ... LastLast
Results 641 to 660 of 1241
  1. #641
    May 2016
    Germiston
    Default Re: Electrickery for camping
    good day all
    i would appreciate some help.
    what amp solar regulator will i need for a 140w solar panel and charging 2x105ah batteries.
  2. #642
    Quote Originally Posted by RANGERFAN View Post
    good day all
    A 15A solar controller (regulator) will do the trick.
    Eggie.
    - apology to Edward Langley.
  3. #643
    May 2016
    Germiston
    Quote Originally Posted by Eggie View Post
    Thanks Eggie
  4. #644
    Default My DIY 12V Powerbox
    So after a weekend camping and having to 'sukkel' with getting (and keeping) all things connected and charged up, I put a few of my too-imaginative brain cells in tandem, and came up with this power box for 12V use:
    Voltage/Ammeter, Hella socket, USB charging pod, 50A fuse and Brad-Harrison connectors to feed power in and out...
    I've used the following 'flow':
    50A B-H plug as input, with 50A fuse on positive line feeding the Volt/Amp display meter on a 50A shunt resistor. Output 'post-fuse' to Hella socket and USB charging pod, and output through a 50A B-H plug.
    A piccie paints a thousand words:
ID:	484674   Click image for larger version.
ID:	484675   Click image for larger version.
ID:	484676   Click image for larger version.
ID:	484677   Click image for larger version.
    Thys de Wet
    Jimny 2009
    Ek het nou klaar gewerk, maar ek weet nie of die bank daarvan gaan hou nie...
  5. #645
    Mar 2017
    Has anyone installed a dual battery system in the engine bay of an Amarok 132kw Double Cab?
    If so, what advice can you give me as my goal is to achieve the following:
    Stage 1:
    Add 2nd battery
    Add DC-DC charger
    Outlets at the back to drive 1 x Engel 40l, 1 x Waeco 40l & maybe a few LEDs.
    Stage 2:
    Add 2 x solar panels
    Although we typically camp where there is electricity, we did play "Camping Roulette" this past weekend in Baviaans, and since we are interested in more such trips IT IS TIME
  6. #646
    Quote Originally Posted by wims_za View Post
    Stage 1:
    Add 2nd battery
    Add DC-DC charger
    Stage 2:
    Hi Wims, the Amarok loadbay is huge and I would rather place the battery in a box in the loadbin, add a DC-DC charger to the box, which can cater for solar input and fused outputs of your choice. The nature of the DC-DC charger is that you don't need thick cables from the main battery to the loadbin.
    Have fun..
    ORRA Callsign: X130
  7. #647
    Polokwane
    Quote Originally Posted by Subok View Post
    Have fun..
    I agree with Subok.
    There are a couple of advantages when putting the battery and DC-DC charger in the back.
    • Less heat and vibration that is bad for any battery
    • Only one 4-6mm cable from the front to the back, less obtrusive and money saver.
    • The battery is still close to your DC-DC charger.
    • but your fridges are very close to your battery, less voltage drop, less money on thick cables.
    • your solar connection can be accessed easily.
    • DC-DC charge can easily be monitored.
    • a removable battery box will allow you to quickly take out the battery when not in use.
    Two solar panels is a great idea, I would go for 80 - 120 watt. (Check what size will fit in)
    a Second battery would also be a good idea or maybe one 200ah.
  8. #648
    Mar 2017
    I agree with Subok.
    Tks for the input.
    Now to get all the parts together to build this. Anyone in PE who wants to advise or lend a hand is always welcome
  9. #649
    Feb 2014
    Stage 1:
    Add 2nd battery
    Add DC-DC charger
    Stage 2:
    Very nicely done!
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  10. #650
    Aug 2010
    Hi All,
    I need some advice regarding the joining/splicing of 16mm wire…..
    I am planning on running a 16mm feed from the vehicle main battery to the back of the Isuzu to connect the caravan for charging purposes. At the same time I would like to add a feed to the loadbin as I often use a battery box when I do not tow the caravan. This in effect means that I will need to split the feed as I would not want two sets of wires from the main battery. The options I have been looking at:
    1. Split at the BH-plug. The problem I have here is that the wires are too thick to crimp two 16mm wires into a grey 50A BH-plug (one fits nicely but not two)
    2. Somewhere close to the back join/splice the feed to the bin by exposing the main feed and then crimping bin wires to main feed using lugs and solder suplimented by multiple layers of crimp to make the join watertight.
    Are there better alternatives as I would not want to do it wrong running a risk of either a short (breaker is installed at both ends of the batteries) or a break in connection??
    Please advise
    Deon
  11. #651
    Mar 2017
    Okahandja
    Check out National Luna. They have a kit with all you need. You only have to add battery box and battery. I payed 2200.00 for ky kit.
  12. #652
    Aug 2010
    Hi Erwin,
    I already have the complete battery box. I just want to find a safe method to 'slit' the main feed from the main batery to he loadbin (battery box) and the towbar (caravan), ie. two feeds. The problem I have is the 16mm is very thick and cannot be joined like thinner wires hence my question on what works from the experiened members.
    Deon
  13. #653
    Nov 2014
    Hi Deon
    I don’t know the answer unfortunately, but try giving Jacques from Bushpower a call. He will definitely have some good advice.
    www.bushpower.co.za
  14. #654
    Melkbosstrand
    I saw a video on YouTube a while ago, where they spliced into the main cable and then soldered the living **** out of the join... could work
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  15. #655
    Feb 2016
    Quote Originally Posted by IceAge View Post
    Would the 175A BH plugs not work?
    http://www.4x4direct.co.za/brad-harr...110661522.html
  16. #656
    Mar 2017
    Okahandja
    Hi Erwin,
    Deon
    How about a small PVC DB with 2 circuit breakers miunteed to the side of the load bin. Then you van switch lines on and off as you like. Black can be connected via a terminal block.
  17. #657
    Quote Originally Posted by MrTolbos View Post
    no
    The lugs for the BH connectors needs to be tight fitting, that is not splicing solution - adding more than 1 wire of the wrong thickness to get 2 wires will result in a possible bad crimp
    I'd rather do this below, found the write-up on another forum when I needed to do this.
    You can,
    a. use a sharp knife to strip away about 1 cm of insulation from your existing wires WITHOUT cutting or damaging the metal conductor inside.
    b. Expose about 1 cm of metal conductor at the end of the wire you want to attach.
    c. Then twist the exposed wire you want to attach (b) around the exposed section of wire (a).
    d. Melt solder into the join for a permanent connection.
    e. Bind the whole lot tightly with insulating tape.you should really use shrink-wrap
  18. #658
    Hi All,
    Please advise
    Deon
    Get hold of Quick Splices
    http://www.4x4direct.co.za/563-quick-splice
    Just bigger to fit 16mm Cable
  19. #659
    Quote Originally Posted by Erwin Schimper View Post
    I did it this way, this also enabled me to connect canopy lights and 12V Hella Outlet for pumping beds etc from the load bin
  20. #660
    Quote Originally Posted by mannemerak View Post
    he is asking how to splice.... 8)
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
