Electrickery for camping - Page 32
Page 32 of 63 FirstFirst ... 7 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 57 ... LastLast
Results 621 to 640 of 1241
  1. #621
    Mar 2011
    Walker Bay
    Thanked: 1021
    Default Re: Electrickery for camping
    Well mine is displaying battery voltage but no amps as yet - it is a rainy day here. Does solar give one amps on a cloudy day?
    Incidentally I see there is a section at the back of the meter for ventilation. I made a cut out when mounting so that this area is not blocked.
    Quote Originally Posted by Advocatus View Post
    Thanks Mr Tolbos and Hendrik. I have learned something ....
    Also ran a quick experiment/test with the meter.
    Connected the meter as per Paul's equation between source (charger/solar controller) and battery. (Battery connected to meter's load)
    Without input the meter displays the battery voltage (no amps or watt) - (thanks Hendrik)
    Attachment 480045
    With input from source it displays the amps (and even watt) going to the battery - and the increase in voltage going to the battery.
    Attachment 480046
    Paul.....it should work...
  2. #622
    Feb 2012
    Thanked: 78
    Quote Originally Posted by Hendrik du Toit View Post
    Ive notice something a while back that i need to test again.....when you push amp through, you get a substantial voltage drop between input and output amps . Will test again.
    Ive tested again tonight pushing 7 amps through the meter and couldn’t simulate the voltage drop again.
    All working well
    LC200 V8 4.7 P
    LC200 V8 4.5 D
    LC105 4500EFI
    Bush Lapa (B867)
    Jurgens Exclusive
    GS1200R Adv
  3. #623
    Thanked: 22
    My system 'balances' with 2 x 105 Ah batteries, 2 x 130W panels and 2 x 40 lt fridge and freezer units. Recharges usage daily perfect. Assumes sunlight of course and can accommodate 1-2 days of rainy weather before I need to make a plan, followed by at least 2-3 days of good sunlight to get back in shape
  4. The Following 4 Users Say Thank You to wolley For This Useful Post:
  5. #624
    May 2010
    Lynwood Glen
    Thanked: 27
    Here is a quick question, and as always if it is already discussed please forgive and point me in the right direction. Current set up is: dual battery in the car charged via the cars alternator and a NL solenoid switch. This additional battery also has a 12v point in the boot for a fridge and then a 50Amp BH plug into which I plug my trailer. The trailer also has a battery and this is looked after by a HCDP power panel. The dual battery in the car is not being looked after well at all, and I would like to install a dc-dc charger. My concern is this, can I run one dc-dc charger into another?
    Does this make sense?
    2012 Fortuner D4D 4x4
    Metalian Maxi
  6. #625
    May 2010
    Lynwood Glen
    Thanked: 27
    So after some research - thanks works wifi - i have ascertained that, NO- you may not run one charger into another. In this instance i would need to disconnect the trailer from the cars dual battery and connect it to the cranking battery, so that that alternator is the one seeing the trailer battery and thus the Mk4 Power Panel will take over the management of this battery from the alternator. Thus the second battery will be a stand alone being looked after by the new dc-dc charger.
    Rob
    Metalian Maxi
  7. #626
    JHB
    Thanked: 120
    Further back there was a discussion about using an inline switch so that the meter could be reset. Can anyone advise what switch to use? The switches I have seen are rated at 10A at 240V. Will it be safe to use on the load side of the aux battery where one could at times be drawing 30-40A at a guess? Fluffy has shown examples of how D.C. switches can arc quite dramatically
  8. #627
    May 2016
    Beyerspark
    Thanked: 260
    Quote Originally Posted by Woolf View Post
    I have a 20 A 12V switch that I use on the input side of the battery. Got is from an electrical store in Boksburg, above Mica close to the East Rand mall.
    You apparently do get for bigger and but then they become really bulky. Will post a photo of the installation.
    Drive: Nissan Hardbody DC TD 16V 2007
    Camp with: Jurgens Xplorer 2010 with a couple of mods
  9. The Following User Says Thank You to Gerhardvr26 For This Useful Post:
  10. #628
    May 2016
    Beyerspark
    Thanked: 260
    Quote Originally Posted by Gerhardvr26 View Post
    Photo as promised, for what it's worth.
  11. The Following User Says Thank You to Gerhardvr26 For This Useful Post:
  12. #629
    Sep 2015
    Home
    Thanked: 516
  13. The Following User Says Thank You to HeavyG For This Useful Post:
  14. #630
    Wartburg
    Thanked: 1111
    That's neat Gerhard.
    If you can't find suitable DC switches, you can also use mini AC circuit breakers as switches, if you can fit them. But don't use low amp ratings, as they have a considerable volt drop across them when using 12VDC. I used 50A and 63A circuit breakers in my vehicle as switches.
  15. The Following User Says Thank You to mikeml For This Useful Post:
  16. #631
    JHB
    Thanked: 120
    Definitely worth it. That's exactly what I am looking for. 20A should be sufficient. Will make sure that no load is connected when zeroing so there will be no arcing across the terminals.
    Is the shop you are talking about in the building behind Roelene Electronics? There is a Shell garage at the exit of the parking lot.
    Another question for you. Have you noticed any issues with the ventilation slots at the back of the unit covered up?
    Thanks for your effort. Much appreciated
  17. #632
    May 2016
    Beyerspark
    Thanked: 260
    Spot on. When standing in front of the building, the entrance is to the very far right. Go up one flight of stairs and down the corridor for about 40 meters. Shop on the left hand side. Is open on Saturday mornings.
    No, but I have not really put it through its paces yet. Had the panels on it for a couple of hours without an issue but that was it. I can't think that it's will get that hot with only 20 A passing through it.
  18. The Following User Says Thank You to Gerhardvr26 For This Useful Post:
  19. #633
    Thanked: 110
    Careful with the statement 'only 20A' on a 12V system. Wire thickness and fusing needs to be appropriate to avoid tears later. In my experience anyway.
    ORRA Callsign: X130
  20. #634
    May 2016
    Beyerspark
    Thanked: 260
    Quote Originally Posted by Subok View Post
    Was waiting for this.
  21. #635
    Sep 2015
    Paarl
    Default Re: Stock power supplies in campers
    Quote Originally Posted by a2iPhoto View Post
    I am considering to replace the MeanWell 24A charger/power supply in Conqueror with a Victron BlueSmart 12V/15A model in order to monitor charging through software App, as well as benefit from the 7 stage charging. This would obviously reduce current from 24A to 15A, and I am trying to understand what possible real life limitations this will have.
    A typical max use scenario would be:
    Fridge/Freezer - 5 to 7A
    LED lights - 1 to 2A
    USB charging - 1 to 2A
    I have a 2x 102Ah battery setup that needs to be charged (and 15A should be more than sufficient for this purpose).
    Since the various different manufacturers uses different chargers, and must have thought through this already, I am curious what is in use out there (i.e. I noted some Bushlapa models coming out with Victron but not sure what strength).
    Anyone?
    Brian
    2016 Ford Ranger XLT 3.2 Dcab 4x4
    2016 Conqueror Courage
  22. #636
    Feb 2016
    Thanked: 602
    In other words you will only be relying on solar power?
    How many watts solar do you have available?
    Is the panels mounted flat on your roof or can you adjust them to optimal angle to face the sun?
  23. #637
    Thanked: 136
    Default Electrickery for camping
    Anyone?
    i think both the meanwell 24amp and victron 15amp is 220v chargers. Meanwell is 3stage and victron 7 stage. 3 stages is correct for good charger (bulk, absorption & float stages) and more than 3 stages mostly looks like most marketing mumble jumble.
    Bushlapa went from 10amp ctek to 15amp victron. Recommended Charger size should be around 10% of battery ah, so 21amp in your case. 24amp should be close enough.
    I do not think you need app monitoring on 220v chargers as will only tell stage that in with wide range of battery charge status.https://www.victronenergy.co.za/char...t-ip22-charger
    I would rather get solar controller and small panel to supplement when there is no 220v available for the same money. Will also charge whilst towing if panel is roof mounted.
    Alternatively get a proper monitor that can accurate read state of battery measuring incoming and outgoing current with calculated remianing ah. See victron bmv700 or bmv712 now has bluetooth.
    https://www.victronenergy.co.za/batt.../bmv-712-smart
    Bennie van der Merwe
    2007 Discovery 3 V8 SE
    Prev 2001 Pajero 3.2 DiD Lwb M/T
  24. #638
    May 2016
    Beyerspark
    Thanked: 260
    Had the two 100 W panels in the full sun for a couple of hours this afternoon. Regularly felt the monitor for heat but could not detect any rise in temperature at all.
  25. The Following User Says Thank You to Gerhardvr26 For This Useful Post:
  26. #639
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 177
    We had in the Echo 4 with 2x100 Amp batteries and the HCdP power pack mark iv with 12Amp charger for 6 years and never had an issue.
    The HCdP power pack had a 150 Watt solar input, many a time we camped with no 220 V and only once we ran dry on the day we departed.
    It was overcast for 3 of the 4 days we stayed
    Now in the BL we have Victron 15 Amp charger with 2 x 100 Amp batteries.
    The batteries are kept faily full as the camp only has power for 2 hours in the morning and 4 hours in the evening (did not use the solar as a test)
    For solar we have 2 x 100 Watt panels and a Victron 100/15 MPPT (tested for 2 1/2 days so far and OK).
    So far so good.
    To short a time have lapsed with the new setup.
    Should now more in May/June after some more tests
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
  27. #640
    Dec 2014
    Thanked: 358
    Having just changed my Hilux set-up from an RTT to a Blinkgat Camper conversion, it looks as if my previously basic electrical system must be improved by increasing the service battery capacity. My previous system was plain Vanilla Flavour: A 94 Ah Deep cycle battery mounted in the engine compartment and an 80W solar panel on the RTT, all controlled by a C-TEK D250S mounted behind the cubby hole. Two cables of 10 mm2 feed back to the tailgate, where the Snomaster 52 L and one LED light were mounted. This has worked well.
    Now I have doubled the solar panels to 160 Watt and increased the load by with more lights, USB chargers etc, and a 12V fan for hot nights. It seems to me that I can make it all work very simply by (in effect) inserting a second identical 94 Ah battery into the 10 mm2 line at a convenient spot in the camper body. I would buy two batteries so that both start off in the same condition.
    Am I wrong?
ID:	484026   Click image for larger version.
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
