Electrickery for camping - Page 11
Page 11 of 63 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 36 61 ... LastLast
Results 201 to 220 of 1241
  1. #201
    Bellville
    Quote Originally Posted by ash007 View Post
    Thanks Chris
    Would love to hear the other answers from Manni.
    It seems like this pannel would work so much better for me than the cteck and all the addons for distribution and charging.
    I am hoping to learn from all your school fees Chris and do it once properly.
    P.S. will find a way to block wheels whilst connected to AC
    I LOVE my Ctek. But as you say, this panel is just SO MUCH cleaner and easier than the Ctek and all the add-on's. Should I do a new installation for myself tomorrow - Mk4 Power Panel without a doubt !!
    a friend use a "clip-on tag" - as soon as the 220V is connected the tag is clipped onto the steering wheel.
    Elders was on charge at home ... got in and drove off ... nearly ripped the plug box off the wall !!!
    I now open the door at the back and loop the lead over the handle - cant close the door and not remember about the 220V connected.
  2. #202
    Hillcrest, Malaysia
    Hi Ashley some interesting questions. We were able to figure out some of these as we did the installation, but I love to contact Manie to get all the answers. Here are what we have figured out :
    2) believe this to be same as the 12A charger - thus while on alternator power, charging the battery at 12A, WHILE providing power to the fridge without reducing the charge rate. Thus a 4 hour drive required to charge the battery at 50% SOC.
    3) we noted two fuses - 1 small fuse for the 220V charger, 1 off 25A fuse for the complete unit. The drawing also requires a 50A fuse to be fitted at the 2nd battery.
    4) would love to know
    5) YES We played between solar\alternator\220V ... it has about a 30 second delay for each switch over, but does so completely automatically !! NO issue having the 220V connected WHILE starting the engine.
    6, 7) due to the installation configuration the box with the power panel wont be opened each time. Thus ALL switches were left ON.
    8) dont know for sure. Expect it to be charger only. Surely one of the questions I would love Manie to elaborate on ....
    9) it came with this configuration. Testing showed it took about 30 seconds before switching off. (MUCH simpler installation - simple bolt on to the primary battery, with no need to T into vehicle wiring. Remember this Ranger had 1 000km on the clock when we did this installation. DONT want to touch the vehicle wiring at this stage)
    10) we tested it, and the charge rate DO drop down on a full battery. Would appreciate some confirmation from Manie on the float charging of this unit ...
    NOTE - from previous school fees - make SURE you cant drive off with the 220V socket plugged in ...
    Hi All,
    Nice project Chris, super well done.
    Just one point that I am not sure if you covered in your answer above.
    The Charger may only be 12A but unlike C-Tek and others the entire max current is available for the battery to charge and the normal load is run by a bypass switch when charging from the alternator. That's why the unit has separate Load and Aux Battery terminals.
    Also you don't need a temp sensor because the charge rate of 12A is spot on for a 10C charge for a 105AH battery.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  3. #203
    May 2013
    Muizenberg
    Thanks Fluffy
    Ashley
    Toyota Hilux Dakar 3.0 D4D D/C 4x4 (2013)
    Toyota Hilux 2.7VVTi D/C (2006) - Sold
  4. #204
    North of Zambezi
    4. Is the solar charger a MPPT unit?
    MPPC solar controller
  5. #205
    North of Zambezi
    Jip agree the panel setup is excellent with the only drawback that it is not portable.
  6. #206
    Quote Originally Posted by mfuwefarmer View Post
    Probably a stupid question, but I admit I know very little about this.
    How big a disadvantage is that?
  7. #207
    North of Zambezi
    That depends on your camping style
    The panel is ideal for a trailer setup or a dedicated overlanding vehicle.
    I have the panel in my trailer and its brilliant
    But for my portable box I now have a 12amp HCDP unit attached to a NL box and its an excellent alternative to the solenoid system at roughly the same price as a fully kitted NL box.
    The portable box can be removed from the vehicle and be placed in a cooler environment thus saving on battery power consumption
  8. #208
    May 2013
    Muizenberg
    Thanks Mfuwefarmer
    Is there a difference between MPPT and MPPC
    Ashley
  9. #209
    North of Zambezi
    Thanks Mfuwefarmer
    Manie explains it quiet well, read this post
  10. #210
    May 2013
    Muizenberg
    Thanks Mfuwefarmer for the help
    Lets hope Manie_dup pitches up soon to answer questions 8 and 10 then of post #198
    Ashley
  11. #211
    Bellville
    Oom Bertie baie dankie vir die insette.
    The unit is small enough that one could actually bolt it to the side of a battery box. Certainly not designed for this purpose, but it is possible.
    Dimensions : Without inverter 235(W)x235(D)x100(H) mm3
  12. #212
    Dec 2012
    Nice Project Ranger, Chris!
    I have a question on the fuse on the main battery. I recently had power installed, but I still need to get the second battery. The installation on my vehicle also goes through a solenoid. The fuse between the positive terminal and the solenoid is 100 amp, but in your installation you used a 50 amp. Is the 100 amp fuse fine, or should I consider replacing the fuse with a lower amp rating?
    Jurgen
    ______________________________________________
    Now: 2014 Toyota Prado TX 3.0D AT
    Then: 2012 Jeep Wrangler Unlimited Rubicon 3.6 V6
    Then: 2013 Ford Ranger 3.2L XLT AT D/C 4x4
  13. #213
    Bellville
    At that rating it is much of a muchness .... the only reason these fuses should blow is due to a fault, and then it would blow either the 50 or 100A in an instant. (yes, in theory one could draw 60 or 70 A and the wire could heat up.... but that WONT be hapening with one fridge)
    In fact most stores only stock the 100A National Luna fuse and holder. Not that easy to get hold of the 50A fuse.
  14. #214
    Hillcrest, Malaysia
    Exactly.
    Cable fuses are there to protect against catastrophic failure of a cable and the possibility of fire.
    Equipment fuses are there to protect equipment or protect the supply from equipment failure.
    VERY different requirements and applications.
    ZS5KAD
    3 V8's
  15. #215
    Struisbaai
    You mention that the compressor is connected to the second battery. Would it not make more sense to connect it to the main battery and let the engine idle when using the compressor? At least there will be enough in the second battery to run the fridge and lights.
  16. #216
    Bellville
    Quote Originally Posted by Chukkie View Post
    Paul (Ore) wanted the compressor to be build in permanently. This placement was just the most practical for his requirements.
    Connecting directly to the second battery ensured the shortest cables.
    Most of us only re-inflate just before the return trip - thus there will be more than enough time to back the amps the compressor used.
    BUT, you are correct - it wont be a good idea to re-inflate four large tires (which he does not have) in camp, with limited time to re-charge, and then to park off for a few days.
    all that said .... you have made me think about this again .... primary battery connection of the compressor may just have merit for most people
  17. #217
    v-town
    Where can i get a fuse distribution block like the one in post #9 ?
  18. #218
    Mxduro, try auto-part shops like Midas or Autozone.
    07 LC 79 4.2D (Brutus)
    Still have a flaky, rusty, leaky '05 Conqueror Conquest Trailer
  19. #219
    Cape Town, Plumstead
  20. #220
    v-town
    Quote Originally Posted by AndyT View Post
    Those i can get everywhere but i need 1 that gets + main supply and the fuses are already connected to that + supply. See pic.
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
