Results 1 to 11 of 11
    Harties
    Thanked: 11
    Default Freelander 2 keyfob battery replacement
    My sister in law bought a 08 Freelander 2 HSE.
    We received the spare key, but the “remote” didn’t work
    After a quick search found that various people has successfully changed the battery.
    A battery (Panasonic VL2330-1hf) was sourced from RS component in Midrand for R53.00
    We tried to open the remote at the space where the key goes in.
    This was done with Leatherman and flat screwdriver; you have to be VERY CAREFUL.
    With just too much force you will tear the plastic. (exactly what I did..)
    So plan B was the “answer” used Dremel and cut a small incision at the top. This helped to get in screw driver and pop open remote.
    Great care was taken not to damage the pc board. The battery is held with black plastic retainer at bottom and is soldered at 2 points.
    Just enough heat was applied to get the soldered parts loose.
    The new battery was put back and soldered again.
    With a little super glue the 2 pieces of remote was put back together again.
    As for the slight gap we used non other than Q-bond to mend it
    The rough Q-bond was “sanded” with the Dremel to make it look good again.
    Only thing is that the Q-bond section is not black but slight charcoal color
    New remote is R2500 from stealers and fob was fixed at R53, luckily it’s the spare and we can live with the “repairs”
ID:	286625   Click image for larger version.
ID:	286626   Click image for larger version.
ID:	286627   Click image for larger version.
ID:	286628   Click image for larger version.
ID:	286629   Click image for larger version.
ID:	286630   Click image for larger version.
ID:	286631   Click image for larger version.
    "Jaag elke avontuur met n Hart wat gelowig klop"
    2008 Land Rover Puma 90 - sold
    2003 Land Rover Disco 2 Td5 - sold
    1972 Land Rover Series 3 88'' - investment
    2011 Land Rover Puma 110 - SWAMBO daily
    1966 Land Rover Series 2a 109" diesel - investment
  2. The Following User Says Thank You to Pappa-Jakkals For This Useful Post:
    Aug 2010
    Thanked: 134
    Cool, thanks for detailed explanation
    Freelander 2 i6 SE - loveeee iitttttt!
    650 V Strom - my trusty beast
    Honda XR400R - wanna play......
    Vespa - when you just have to be cool 8)
    GT Expert and Giant Anthen MTB's - keeping the tummy in check
    Thanked: 251
    Default Re: Freelander 2 keyfob battery replacement
    Is there anyone in Jhb that can do this battery change? I don't trust myself with a soldering iron
    Thanked: 625
    I have seen the repair on youtube but my search for the batteries was fruitless.
    Thanks for the info - I will pick up new batteries today!
    Si vis pacem, para bellum
    Thanked: 251
    I managed to split the key fob apart...
    RS Components in Midrand have the battery. Will go get it today.
    I just need to find someone who can solder it for me.
    Feb 2015
    Thanked: 21
    Quote Originally Posted by veedub View Post
    I had a local electronics guy (TV repairs sorta person) do some micro soldering on my old Renault credit card key fob. Worked perfect.
    Can you tell me the spec of those batteries my spare key charges after a long drive but then runs out in a day or so. Haven split it open yet. Perhaps I should read back through this thread.
    _____________________________________
    Me: 2008 i6 HSE Freelander 2 black. ()
    Me: 1.6l Renault Megane (sold)
    Swambo: Chevy Captiva 2.4 Auto
    Swambo: 2.0l Tucson Gls (sold)
    Thanked: 251
    I've decided to just buy a new one...R2500 for the key and R1000 for one hours labour
    Thanked: 251
    Went into Midrand Land Rover today (had to book the car in) and got my new key. All done in about 90 minutes.
    I'll try and get the battery replaced on the old one and keep it as a spare.
    Apr 2016
    Milnerton
    Thanks so much for the informative thread! Seems like I will need to do this myself soon. Just a question.. I see that RS components have a VL-2330/HFN in stock. Is this the same as the VL-2330/1hf, or is it a different battery entirely and shouldn't be used?
    Jan 2019
    UMHLALI
    I also had the same problem ,however I replaced the battery and resealed the casing without any evidence.
    So I am more than happy to help ,if you live in the Ballito area. Current cost to replace fob is +- R4000
    Jan 2019
    UMHLALI
    So I am more than happy to help ,if you live in the Ballito area. Current cost to replace fob is +- R4000. I will charge R600.
  13. The Following User Says Thank You to PHIL CAD For This Useful Post:
  1. Discovery 3 Battery Replacement
    By T le Roux in forum Land Rover
    Last Post: 2023/11/23, 12:14 PM
  2. Ctek D250S DUAL - Query
    By astoltz in forum Camping, Fridges, Accessories
    Last Post: 2016/01/30, 08:38 AM
  3. Duel Battery System Issues
    By PRB in forum Camping, Fridges, Accessories
    Last Post: 2014/02/11, 10:42 AM
  4. Shocking truth about Cycle Light Battery Packs
    By HannesZ in forum Mountain Biking & Cycling
    Last Post: 2013/10/29, 12:50 PM
  5. 120 battery replacement
    By Randy in forum Toyota
    Last Post: 2009/09/09, 04:11 PM
