Hi all Disco owners,
My clutch isn't releasing properly, the place where the pedal takes changes, sometimes I need to pump it a few times to get pressure. I had the same symptons on my defender and it was the little spring inside the master cylinder that had broken and thus wasn't closing the inlet properly when applying pressure. There doesn't appear to be a leak anywhere.
Does the disco master cylinder work in a similar way? I have a manual for the disco, but it doesn't show the internals of the master cylinder. It appears to be a fairly simple job to remove the mc? If I had to do this myself, will it effect the extended warrenty? Its for a 2003 Disco Td5 facelift. Where in Jhb is the best place to get spares?
Many thanks
Jan
