Diesel freezing/waxing
Results 1 to 13 of 13
    Sep 2012
    Default Diesel freezing/waxing
    Advise needed: Do we need to add additives to our 50ppm diesel to prevent freezing? If so what do you recommend?
    Sasolburg
    Thanked: 67
    Hi Werner I googled the technical spec of Bp and Engen 50ppm diesel.It seems no additive is needed since these companies do make adjustments for winter and summer.I am tempted to say all of them do but since I only checked on these two companies. Winter time they increase the freezing temperatures to between -1 and -7 degrees. It should be sufficient since we do not live in Antarctica.Very interesting question you asked never thought about it.
    Sep 2012
    Morning Splashcamper, thank you for the response. We are planning a trip to Lesotho at the end of June and somebody told us that your diesel can freeze overnight. Itdid happen to my fiends fathers Discovery (-17) in Clarens a few years ago. Have you or anybody else experiece this before?
    Jun 2012
    Fisherhaven
    Werner
    Yes diesel will gel or freeze at any temp below -3 depending on conditions. Living in the US for many years it was always a concern. I know over there the fuel companies do adjust for the cold. I'm not sure over here though. I'm sure they do to an extent.
    Do they even sell an additive here?
    Mar 2007
    Thanked: 117
    2so!!!!!!!!!
    Gerhardt Olivier
    GWM H5 2.4
    Gwm 2.2 d/cab
    Always carry a knife, in case there is biltong or you need to stab someone in the throat.
    Mar 2013
    Thanked: 380
    On my uncles old Volvo 940 6cyl Diesel we had heated fuel lines fitted, which let the car run on summer diesel at up to -20* no problems. He would always take the car up to Norway in the winter so that was the main reason for the install.
    Sasolburg
    Thanked: 67
    Add 20+Cetane booster to your diesel it will increase the gel point to -35degrees.According to what I read you use it 10ml to every 100l of fuel.If you get follow instructions since I never needed to use it.
    Sep 2012
    Splashcamper baie dankie vir jou raad en advies. Sal bietjie gaan na-lees daaroor en jou op hoogte hou.
    Jun 2008
    Joburg
    Thanked: 15
    Wynns make an anti-freeze additive in an orange bottle. We used it in Lesotho last year with temperatures at -16. It worked very well.
    Defender 90 TD5 with steering guard, Warriorworx rocksliders and diff guard, 33' Bridgestone MT, Warn winch, outback roofrack, frontrunner penthouse RTT and awning.
    African Backbone offroad trailer.
    Thanked: 348
    Jip,the orange bottle from wynns works and then Nitrous Fuel also have a product that could be even better,cant remeber the name.Something like outback guard or so
    Thanked: 395
    AFAIK SASOL (-7) diesel has a lower CFPP that e.g. ENGEN (-4):
    http://www.sasol.com/sites/default/f...ta_sheet_5.pdf
    http://www.engen.co.za/common/downlo...2050%20ppm.pdf
    I wonder on which date does the switch-over takes place? (From summer <-> winter diesel)
    May 2012
    Never had a problem with diesel freezing in Lesotho before, even at Oxbow last year when it went down to -16 and we got snowed in. Always park your car with the nose down wind.
    Thanked: 8114
    I understand that farmers use a 10% paraffin dilution in their diesel, but this is not advized for new gen hi pressure common rail pumps as it reduced the lubrication properties of the diesel.
    Ela Diablo: Land Rover S2A 109 PUP: SOLD
  1. Zim, Moz, Malawi, Tanzania, Zambia and Bots trip report
    By nhouston in forum Overland advice, reports etc
    Last Post: 2013/10/16, 07:02 PM
  2. Colt 2.8D(NA) Particle filtering oil and diesel
    By Mulder in forum Mitsubishi
    Last Post: 2013/09/23, 04:20 PM
  3. your thoughts on bio-diesel
    By sjbosbfk in forum General 4x4 Discussion
    Last Post: 2011/06/27, 03:57 PM
  4. Toyota answers D4D 2Stroke in oil query
    By Fluffy in forum General 4x4 Discussion
    Last Post: 2010/12/17, 08:28 AM
  5. NEw Isuzu beats new Yota offroad.
    By Bryan Webber in forum Isuzu
    Last Post: 2006/12/20, 09:31 PM
