Help with Trailer Wiring
Results 1 to 9 of 9
    rjb Guest
    Default Help with Trailer Wiring
    Trailers here with lights are not commonplace, so as a result, there are no readily available wiring kits/looms. Does anybody have a wiring diagram or some info on how I can go about wiring in a coupler for my trailer on a 2006 Hilux 4x4 D4D? Does Toyota provide any connectors to wire in an aux loom, or do I need to start splicing wire? Many thanks in advance.
    Richard
    Ladismith western cape
    HI
    The S.A.B.S no 1327-1981 standard wiring setup is as follows,
    on the plug numbers,
    1= Left indicator
    2= Auxiliary
    3= Earth
    4= Right indicator
    5= Right tail light
    6= Stop light
    7= Right tail light
    5 gets bridged to 7
    Ive got the workshop manual on the KZ-TE Hilux, will go through it and see if I can post pics of the wiring for this.
    Quote Originally Posted by rjb View Post
    Richard
    Could not come write with the manual,
    Toyota is usually pritty jacked when comming to this sort of thing, I would expect there to be ready made connections fitted somewear near the towbar area and they would usually use a standard colour coding. I'll check tomorow on my camry for the colourcode and let you know.
    Springs
    The connections and colour code for the plug is as follows.
    pin 1----L/H indicator-----Yellow
    pin 2----Rear fog light or supply to caracan/trailer-----Blue
    pin 3----Earth------------White
    pin 4----R/H indicator-----Green
    pin 5----R/H tail light------Brown
    pin 6----Stop light--------Red
    pin 7----L/H tail light------Black
    What the colour code of the car is I don't know. This could be quite different. The German cars normally use brown for the earth.
    Hope this helps
    Andre
    Andre van Rensburg<br>Swambos baby V6 Pajero shorty<br>My overland vehicle "Datsun" 3.3l v6 hardbody d/cab.<br>Play vehicle Sizuki SJ413. Mods: Toyota 2c Diesel engin and 5 speed gearbox, 50mm lift<br>Love the bush, overlanding and crazy about animals.
    rjb Guest
    thanks for the info guys. I have the colours, etc, but was wondering more what provisions Toyota has made for connecting an aux loom to allow for trailer wiring. I can't seem to locate anything, so I'm guessing the only option is to splice wires and connect into the main harness. Not ideal
    Thanked: 864
    rjb.
    My KZ (may she rest in peace) had a plug, and I got a harnass with a caravan plug on the other end which I just had to plug in! Can't remember where the plug was located, but I think it was somewhere in the left rear corner of the vehicle. I am sure that the d4d will have one somewhere as well.
    H2F
    Overkill - isn't!
    Pennington
    Thanked: 119
    The wiring connection on the Hilux is behind the tail lamps. Wiring loome for Toyota std towbars has two electrical plugs one for the RHS & the other for the LHS. Remove tail lamps unplug wiring to lamp & plug in tow bar wiring loome.
    Modderfontein, naby Rysmierbult
    Thanked: 561
    Default Trailer electrics
    Looking at the female plug on the towing vehicle, this is what you see
    Johan Mitchell, .... r.i.v. Swambo Marthie
    My beste kennis is diť oor my eie onkunde
    '96 Colt DC V8 ... Safari Camper ... '88 Fleetline L
    '88 Ballade 150 ... sold
    "The rule here is that there is no rule" .. MikeAG
    rjb Guest
    Quote Originally Posted by mplester View Post
    Thanks for the info - will check it out tonight. Guess I'll need to order a loom and pick it up in SA in June. Dealer here hasn't a clue
  1. Towing Regulations
    By Ant in forum Trailers, Caravans, Towing etc
    Last Post: 2018/10/29, 05:27 PM
  2. Nuwe Boswa
    By Bogaards in forum Camping, Fridges, Accessories
    Last Post: 2011/06/06, 11:26 AM
  3. Help with wiring of ECHO 1 trailer please.
    By ockert in forum Camping, Fridges, Accessories
    Last Post: 2008/11/26, 12:10 PM
  4. Conqueror trailer battery and wiring help please :)
    By Honu in forum Camping, Fridges, Accessories
    Last Post: 2008/08/04, 07:43 PM
  5. Leo or Conquest s - some advice needed?
    By Wiv in forum Camping, Fridges, Accessories
    Last Post: 2007/09/02, 10:49 PM
