Ranger T6 lift kit
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 43
    May 2012
    Default Ranger T6 lift kit
    Hi community.
    I have a T6 Ranger 4x4 and am looking at fitting the 50mm lift kit from
    WR OFFROAD in pretoria the kit is called "Level-It". This is like the Stofpad kit, it is basically spacer rings that go between the shock and the shock tower. They also do a longer shackle kit for the rear.
    the kit together with installation and wheel alignment is +-R3700
    has anyone had this installed? any comments on wheel alignment problems, handling changes etc would be greatly appreciated.
    Does anyone know of any problems with this type of ki on other vehicles?
    Currently do not own a 4x4, driving a sedan
    Ex: 2013 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2012 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2013 Ford Ranger 2.2 XLS 2WD manual
    Ex: 2009 Mazda BT50 3.0 CRDi double cab manual
    May 2012
    Sorry the quote was R3 380
    but my question is not really the price.
    I need to know how it affects roadholding, general drivability.
    I am asking as my vehicle is used daily on the roads of jhb.
    Sep 2013
    Meyerton
    Quote Originally Posted by Andz View Post
    Hi community.
    Hi Andrew
    I fitted quite n bit spacer lifts on the Ranger T6, some with Extended shackle and some with the Loadhog helper spring, I used both spacers from Stofpad and from WR Off Road and both products work very well, Stofpad spacer looks better
    As far as i know there is no difference in road handling with the spacer lift, Here is a couple guys on the Forum who i did fitment for and they don't have any problems
    Riaan
ID:	283695   Click image for larger version.
ID:	283696   Click image for larger version.
    May 2012
    Hi Riaan.
    Thanx for your advise.
    what is the pricing for the stofpad spacers and shackles with fitment and wheel alignment with you?
    Where is your business based?
    Sep 2013
    Meyerton
    Hi Riaan.
    Hi Andrew, i sent you a PM, I am base in Meyerton on the Cnr of R59 Freeway and Johan le Roux rd
    Riaan
    Sep 2013
    Meyerton
    Hi Riaan.
    Riaan
    May 2012
    I have Ironman springs in front with a 50mm spacer total lift 60mm at the back a 50mm longer than standard 25mm lift shackle and a helper spring 35mm lift total 60mm, I felt that the bakkie was top heavy but fitted 30mm spacer on the wheels and now it fine and handles corners like the standard bakkie. I ve now removed the spacers and fitted aftermarket rims with a 50mm offset and I am happy.
    Marius B
    2013 Ford 3.2 d/cab 4x48)
    2014 Ford Kuga
    May 2012
    Quote Originally Posted by Marius Botha View Post
    Hi Marius
    have you got any photos of your vehicle? I am not sure I want to go for full replacement spring and shock setup, I just thought the 50mm spacer lift kit would assist with ground clearance, especially the break over angle as the T6 is very long and scraping the running boards is almost guaranteed offroad.
    May 2012
    Quote Originally Posted by Riaan hard View Post
    Riaan
    thanx Riaan
    Is this something you would be able to do on a saturday?
    if not is it a job I could wait a few hours for, as I am not local.
    May 2012
    Hi Marius
    Hi I don't have but you are welcome to contact me if you are in the East Rand, Kempton Park, we can then meet. I had the same issue with the Ranger when I decided on the suspension mod.
    Marius B
    2014 Ford Kuga
    May 2012
    Thanked: 86
    Hi Andrew
    Riaan
    Riaan, which do you suggest is better between extended rear shackle and the Loadhog helper spring.
    Prices?
    Current: 2018 Ford Ranger 3.2L XLT AT D/C 4x4 (since: 24/04/2018 )
    Previous: 2015 Ford Ranger 3.2L XLT M/T D/C 4x4 (31/08/2016-24/04/2018 )
    Previous: 2013 Ford Ranger 3.2L XLT M/T D/C 4x4 (05/01/2013-31/08/2016)
    Previous: 2010 Nissan Navara 2.5D LE M/T D/C 4x2 (Sold: 30/10/2012)
    HoneyDew
    Quote Originally Posted by Prodigal View Post
    Prices?
    Hi Prodigal.. i had the load hogs on my navara... although you get lift, its more what tge name says... load! You lose a lot of wheel travel. Its very stiff.
    I now have the extended shackkes on my ranger... imho its tge better option.
    FordRanger T6 / 3.2 XLT 4x4 Auto.
    The 3Ton Gravel Road Monster over weekends.
    The Pavement Special in the week.
    Since March 2013
    ConquerorComfort.
    Camping instyle since January 2012.
    HAM CallSign: ZS6LSC
    ORRA CallSign:AG34
    <a href="http://www.fuelly.com/car/ford/ranger/2013/zs6lsc/172702" target="_blank"><a href="https://badges.fuelly.com/images/sig-metric2/172702.png" target="_blank"><a href="https://badges.fuelly.com/images/sig-metric2/172702.png" target="_blank">
    May 2012
    Thanked: 86
    Quote Originally Posted by ZS6LSC GP View Post
    Thanks, I'm up in Jhb this weekend, going to get some shackles tomorrow I think.
    May 2012
    Thanked: 86
    Picked some up today, will install when I'm back in Durban.
    Iv got a 50mm spacer lift on my ranger. Still drives great
    Zane
    3.2 ranger double cab 4x4 mine
    Renault duster swambos
    Venter bushbaby our.
    May 2012
    Thanked: 86
    Quote Originally Posted by zkramm View Post
    Yes, I've had a 40mm lift on the front (new coils) for about a year and a bit, the back looked like it was sagging a bit.
    I've just installed the extended shackles, took me around 40 minutes, looks better. Provided a 30mm lift.
    HI
    I have fitted the EFS 50mm lift kit. drives awesome and still has the comfort.
    Hi community.
    Oct 2012
    Eversdal, Kaapstad
    Thanked: 474
    Tell me more about these shackles.
    May 2012
    is alignment not needed following shackle fitment?
    May 2012
    Thanked: 86
    Quote Originally Posted by Mickeynelster View Post
    The rear shackles that connect chassis to leaf spring is replaced with extended ones. This pushes the body up.
ID:	308853 Click image for larger version.
ID:	308855 Click image for larger version.
ID:	308857 Click image for larger version.
  1. What lift kit is the best for the jimny?
    By cruzer244 in forum Suzuki
    Last Post: 2015/09/09, 02:25 PM
  2. Replies: 6
    Last Post: 2014/05/06, 07:01 PM
  3. Fortuner Budget Lift Kit
    By Navigator in forum Commercial Member Adverts
    Last Post: 2013/10/24, 05:20 PM
  4. Disco II Lift Kit
    By Disco-Deon in forum Land Rover
    Last Post: 2013/02/10, 08:45 PM
  5. Mopar 4.5" Dealer Lift Kit
    By Dirk in forum Jeep
    Last Post: 2010/11/24, 04:55 PM
