Gen 3 Speedo
Results 1 to 4 of 4
Thread: Gen 3 Speedo
    Jun 2007
    Pietermaritzburg
    Thanked: 141
    Default Gen 3 Speedo
    On my previous Pajero, the speedo was operated by an electronic sender located at the rear of the gearbox but on my Gen 3 the location of this unit is not that obvious. Assuming that the 3.2 also makes use of an electronic speedo, please can someone tell me where the transmitter it is located?
    The speed indicated on the speedo is, from time to time, erratic and I am guessing that the plug on the transmitter needs to be secured / cleaned as found on the iO after playing in the mud.
    4ePajero Guest
    Item g on this diagram:
    Jun 2007
    Pietermaritzburg
    Thanked: 141
    Thank You.
    Much appreciated!
    Jun 2007
    Pietermaritzburg
    Thanked: 141
    4ePajero.
    Thanks for the info. All working 100% again. Plug has nothing to retain it in the socket so it has come loose. Seems there should be some sort of "clip" mechanism to retain it but its not there. A dab of glue will do the trick I guess. Thanks for you help.
  1. General Pajero Information
    By SimonB in forum Mitsubishi
    Last Post: 2020/01/12, 09:40 PM
  2. Pajero Gen 3 vs Gen 4
    By Let's Play in forum Mitsubishi
    Last Post: 2010/02/06, 04:48 PM
  3. 'Pomene Trip Feedback, Jan 2008'
    By huntsman in forum Mozambique
    Last Post: 2008/02/28, 08:36 PM
  4. Pajero Gen 3 Flex-ability
    Last Post: 2007/11/27, 09:40 PM
  5. Advice neede on Gen3 DiD SWB
    By ArthurB in forum Mitsubishi
    Last Post: 2006/12/26, 07:54 PM
