Jurgens Xplorer Fan Club - Page 8
Page 8 of 123 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 33 58 108 ... LastLast
Results 141 to 160 of 2450
  1. #141
    Quote Originally Posted by Long John View Post
    I was at Brian's place today - I checked out your Van "looking great so far"
    regards, Long John
    Jip just paint and then I can do pickup. Cant wait
  2. #142
    Aug 2010
    Krugersdorp
    Quote Originally Posted by Biggles View Post
    And the extention awning? The same?
    Yes
    VW AMAROK V6
    Land Rover Defender Td5
    Land Rover Discovery 4 V8 HSE (Swambo)
  3. #143
    Pretroria
    Ons het 'n 2008 Jurgens Explorer en geniet die wa terdee!
    Het ook die neus verander in 'n uitswaai tent. Baie groter as die nuwe modelle s'n. Amper so breed soos die karevaan self.
    Kroeg ingebou en tafel laat monteer aan tent kant.
    Ook vir my 'n nuwe tent and side wall stel gekoop. Geniet die tent baie!
    Beste verandering wat ek gedoen het was om vir my 'n custom cutlery sak te maak wat in die deur hang. Life saver!!
    As jou krane begin lol, is dit die micro switch wat moeilikheid gee. Moenie die kraan vervang nie. Nuwe kraan kos R1 000 plus terwyl micro switcht R20 kos.
    2009 Toyota Hilux 3.0 D-4D 4x4 AT
    Garsfontein, Pretoria
  4. #144
    Quote Originally Posted by Coetzee Swanepoel View Post
    Daai is nou waardevolle informasie. Maar waar is die kiekies
  5. #145
    Aug 2010
    Krugersdorp
    Quote Originally Posted by Sennin View Post
    Just got an update from Brian that they have started with my caravan. Whoop whoop. 2 weeks and counting
    When are you getting your Explorer back, I would like to see the photos.
    VW AMAROK V6
  6. #146
    Quote Originally Posted by JohanJvV View Post
    I should have had it last weekend already. But supplier delivered wrong seleant colour so getting her this weekend whoop whoop. 3 days and counting
  7. #147
    Just picked up my Xplorer. Now the itch is strong to go camping.
ID:	300585Click image for larger version.
ID:	300586Click image for larger version.
ID:	300587Click image for larger version.
ID:	300588Click image for larger version.
ID:	300589Click image for larger version.
ID:	300590Click image for larger version.
  8. #148
    Looks fabulous. Enjoy the first trip and the many to come.
    Robin Thompson
    Landrover Discovery 4 TDV6 S
    Crestliner VT19 - Mercury Optimax 135HP
    Bush Lapa - Miskruier B374 -"The Bear"
    8)
  9. #149
    Rivonia
    looks great enjoy your next trip
    2010 Land Cruiser 200 VX V8 Petrol
    2013 FJ Cruiser
    1996 Land Cruiser 80 GX 4500 Carb. 400000Km's
    2010 Jurgens Xplorer Customised 2014
  10. #150
    Kathu
    Bought mine 2006.
    Quite a few mods. Just to mention a few. Water capacity increased to 120l. Inverter with extra 220v plugs installed. Extra battery system with own charger to power inverter and second 12v National Luna. 160w solar panels with dc to dc charger.
ID:	301119   Click image for larger version.
ID:	301122   Click image for larger version.
  11. #151
    Gordon's Bay
    Hi Sennin, plse post some close up pics of the kitchen pull out with how mechanism works. Im in Somerset West & nobody here seems to be able to do the mod for me. I am even prepared to do it myself if I can just see how the mechanism works. (some guys say you have to cut the kitchen cupboard in half but yours has been well done with the whole cupboard still in one piece.)
    BushyBushy
    Toyota Land Cruiser 79 Dc V8 Diesel 2015
    Toyota Fortuner 3.0 D4D 4x4 2011
  12. #152
    Quote Originally Posted by BushyBushy View Post
    Will do so with pleasure, but will only be the weekend. In short they have added an additional rail onto the existing slide out rail. And then restricted the original rail to only extend that 400mm needed for the cupbourd to clear (instead of cutting the cupbourd shorter)
  13. #153
    Pretroria
    Nice work Sennin! Excellent mods! Also interested in kitchen modification. My fridge is a bit shy and remains inside the van ..... Looking to lure him out!
    I have a bar where you have the plates. Also contemplating whether I should use the area better.
  14. #154
    Gordon's Bay
    Great! Thank you. I look forward to your pics.
    I recently added an access hatch to the side of my Xplorer so I could access the storage space under the back left bunk from outside. (ie. without breaking up the double bed inside.)
    I used a 250mm x 600mm plastic marine hatch which cost R400.00 (obviously marine hatches are waterproof & dust proof...)
    this has given me a huge amount of extra packing space that I was not using effectively.
    BushyBushy
  15. #155
    Dec 2006
    Durbanville, Otjiwarongo
    Pics? (or it didn't happen )
  16. #156
    Honeydew
    Default Airlock in the water system
    Help, anyone out there who knows how to get rid of an airlock in the water system, its a 2014 Xplorer and I can't get water either side(shower or basin) and it won't drain at the rear any advice on refilling would also be welcome
    2011 Defender Puma 90
    2014 Xplorer
  17. #157
    Jul 2007
    I have found the following helps if you have an air lock while the tank is full. Open the bottom drain tap and then open both the kitchen and the bath rooms taps at the same time. This seems to get rid of the air locks. Once the lock is out close the drain tap and all should be fine.
    For filling I just put the hose pipe in as deep as it will go and open the tap. The water would typically run back out the filler cap for a few seconds but then it would "blow" out the filler as the air lock releases after which it fills smoothly. Opening the taps as per top paragraph while filling sometimes also helps.
    Hope that helps!
    Andre
    Discovery 4 V8
    Jurgens Xplorer
  18. #158
    Oct 2006
    Pretoria (Rietvalleirand)
    Quote Originally Posted by 90puma View Post
    Mine had similar symptoms when we bought it. Turned out to be the breather pipe that wasn't installed properly. It had a few kinks and curls where water would accumulate - blocking the airflow.
    I straightened and tied it up properly and have never had an issue since.
    Johan
    Pajero Gen 4 GLX 30 Year Heritage Edition - Grondpad
    VW Tiguan 2.0TDi - Teerpad
    Bushlapa Boabab 4.2 in tow
  19. #159
    Spend some quality time with the Xplorer this weekend, camped out in my garden
    Here's the update on the slide out kitchen modification as was requested:
    1. The original rails were widened, the door skirting was cut to facilitate the extra space. So your kitchen door must be fully opened to allow the kitchen to slide out:
    Rear(Left):
    Front(Right):
    Then there is a sling used to stop the original slide from sliding out more than 30cm (I will exchange this with a chain)
    An addition slide is then installed inside the original slide, hope you can see the old on the outside with new one inside (with release lever)
    Also the pipes are re-located to the bottom with quick release fittings. Gas, Hot and cold water. I'm going to take the pipes back into the caravan and use a bungee type cord to do pipe management, as I'm not too keen on the quick connect and dis connect as I forgot it once already and tried to push in the kitchen with them still connected)
    The cabinet was also sliced to fit in and today I realised the kitchen sink support doesn't fit anymore, will phone brian tomorrow regarding this.
    also I am not too happy about the front fold out bed, there is a massive step, roughly 7cm between the old bed surface and the fold out section:
    also I'm not too sure how the fold out bed extra cover work, have additional poles but dont know where they fit in, Brian will have to explain
    Also I fitted some 265/75R16 Rims and Tyres to the van, including the two spare wheels , spacers are on order to give lift and ensure the wheels don't rub on full upward travel
ID:	302414   Click image for larger version.
ID:	302415   Click image for larger version.
ID:	302416   Click image for larger version.
ID:	302417   Click image for larger version.
ID:	302418   Click image for larger version.
ID:	302419   Click image for larger version.
ID:	302420   Click image for larger version.
ID:	302434   Click image for larger version.
ID:	302435   Click image for larger version.
ID:	302437   Click image for larger version.
ID:	302438   Click image for larger version.
  20. #160
    Gordon's Bay
    Thanks Sennin. Looks awesome......gonna try get my kitchen done also.
    BushyBushy
  1. Jurgens Xplorer Questions (Again....)
    By Gentoo in forum Trailers, Caravans, Towing etc
    Last Post: 2017/11/09, 07:51 PM
  2. Replies: 16
    Last Post: 2013/10/22, 12:26 PM
  3. Jurgens Xplorer Xcell questions
    By Constant in forum Trailers, Caravans, Towing etc
    Last Post: 2012/10/30, 07:46 PM
  4. Electric fan
    By Gert in forum Kia
    Last Post: 2011/10/04, 06:15 PM
