Confusing Option in GL350 Quote?
Results 1 to 9 of 9
    Ebene
    Thanked: 52
    Default Confusing Option in GL350 Quote?
    A MB dealer here sent us a quote for the 2014 GL 350, and the options list has:
    828 Omission of emmission systems
    Just curious what this means, as the dealer is not being very clear. Does this mean this option makes the engine run properly on 500ppm diesel?
    Thanks.
    Kyalami
    I might be incorrect but I think its when the CATs are removed, the ECU wont complain that the CATs are not functioning. They should not charge you for this, it should just be disabled in the ECU. Its disabled in my ML.
    --Kar
    Ebene
    Thanked: 52
    Quote Originally Posted by Ne3M View Post
    Thank you Ne3M.
    I was under the impression that this would mean removal of the Catalytic Converter and the Diesel Particulate Filter, so that the engine can easily use 500+ ppm.
    Please advise? What needs to be disabled for the engine to happily use 500ppm daily?
    Thanked: 2252
    it could be removal of one or a combination of the following
    adblue system
    catalytic converter(s)
    DPF system
    Ebene
    Thanked: 52
    adblue system
    DPF system
    Hello MariusFourie,
    Thank you for the reply. So my main question is, if the 3 above are removed, will the engine safely use 500ppm (and above?) on a daily basis, and achieve longevity? (Of course I understand that this would require more frequent oil changes, like every 5000kms)
    Thank you.
    Thanked: 2252
    Ebene
    Thanked: 52
    Spot on. The lambda sensors may foul up but the engine itself should be fine.
    Aha. Can the lambda sensors be removed or disabled? If they cannot, what damage (and how often) would they "foul up" due to the use of 500ppm?
    Thanked: 2252
    Not sure how quickly they may foul up but they can be removed and replaced with dummy sensors or a tuner can tune out the sensor.
    WITBANK
    Thanked: 26
    Quote Originally Posted by byaru1 View Post
    Thanks.
    The mb system would auto generate this in sa.
    There will be no charge.
    Doc Jamal
    Commercial Member of 4x4community
    https://www.4x4seatcovers.co.za
  1. 4.2D Patrol - good option?
    By Oppers in forum Nissan
    Last Post: 2010/05/19, 08:12 PM
  2. New Ranger cruise control option
    By Scrat in forum Ford & Mazda
    Last Post: 2010/02/06, 09:54 AM
  3. Series III OVERDRIVE? Other option?
    By Wimpy Hightop in forum Land Rover
    Last Post: 2010/01/20, 06:09 PM
  4. Replies: 2
    Last Post: 2009/03/17, 04:09 PM
  5. Cheap option to lift the musso?
    By JGoosen in forum Ssangyong
    Last Post: 2008/06/17, 10:12 AM
