Courage Mod thread - Page 3
Page 3 of 43 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 28 ... LastLast
Results 41 to 60 of 847
  1. #41
    Jhb
    For my LED lights I went to conqueror and bought the black sealant that they use on the trailer panel joints.
    I put some of that on the back of each LED strip and stuck them down, I first did this over a year ago on the kitchen light, now done for all the others. I hope I never need to get them off... they are officially going nowhere! probably overkill but it works!
    2017 FORD, Ranger Wildtrak
    2015 Bush Lapa, Boskriek 444
  2. #42
    Jhb
    Default Mod 6 of many, Tarpaulin
    So a few weeks back I got my tarpaulin custom made by Jackalberry, as always they did a great job. So this weekend decided to brave the cold to ensure it worked out as planned.
    A few small adjustments to make to avoid water collection, otherwise, very happy
  3. #43
    Apr 2008
    Secunda
    Thanked: 254
    Sven
    Looks really great
    Hoping to get a winter trip in also
    2013 Toyota Hilux 3.0D4-D 4x4
    Bush Lapa 810 Miskruier
    ORRA Call Sign: X85
    Gerbers Alu Canopy
    Howlingmoon RTT
  4. #44
    Thanked: 19
    The various mods depicted so far are all practical and well executed. It all seems to be done on new trailers ie not extensively used and towed on typical Namibian and Botswana sand and gravel roads. I would appreciate feedback on how well the mods stood up to this sort of punishment, specifically wrt the sturdiness of the kitchen units, ie how many glasses got broken, how many items got dislodged from its tie downs etc – and then more importantly, what did you do to prevent it from happening again? I have used my Courage in those conditions and just about everything got dislodged and damaged in some way
  5. #45
    v-town
    Thanked: 31
    @ HILUX01 when you replaced the wheels with 17" Toyota rims did you add spacers, because the hilux rims are +30 offset and conqueror uses 0 offset rims ?
  6. #46
    Jhb
    Hi Gotto, I have taken my courage on numerous long haul trips from rough gravel to soft sands of Botswana pans. I am comfortable to say that that everything stays in place ... Of course all big items that can be are bolted down are.
    As for lose items, it is for this reason I made my kitchen a slide with 2 meat trays ... So everything goes inside the trays.
    The only lesson I have learnt is that if you have any plastic cups don't travel with them stored upside down in the trays as they vibrate and land up getting an almost sand papered rough edge on the lip.
  7. #47
    Apr 2008
    Secunda
    Thanked: 254
    MXDURO
    Your answer sent to PM
    ORRA Call Sign: X85
    Gerbers Alu Canopy
    Howlingmoon RTT
  8. #48
    Thanked: 19
    Thanks for the feedback SvenT, appreciated
  9. #49
    v-town
    Thanked: 31
    Thanks Hilux01!
    Do any of you guys know the height of the trailer with the tent open ?
  10. #50
    v-town
    Thanked: 31
    Hier is my nuwe Courage moet vandag hout gaan kry om die kombuis te begin bou. Het nie gedink die trailer sleep so lekker nie. Die power pack het verander op die nuwes maar die res dink ek is die selfde.
ID:	296355   Click image for larger version.
  11. #51
    Thanked: 140
    Baie baie
    Van al die trailers, dink ek sleep die oukie die lekkerste, nie eers die compact wat kleiner lyk sleep so gemaklik nie :-)
    My wife is simple, in a complicated way
  12. #52
    v-town
    Thanked: 31
    Dit moet die as wees toe ek die toyota rims opsit toe sien ek dit is 1 van alko se "RUB AXLE" 1800Kg. Het al 3 trailers self gebou en die soort werk die beste. So bly hy kom met dit uit.
  13. #53
    v-town
    Thanked: 31
    The new Electrical board.
  14. #54
    v-town
    Thanked: 31
    Started with the kitchen area on the weekend.
    What basecoat should i use on the supawood before spray painting it?
  15. #55
    v-town
    Thanked: 31
    Gas cooker done.
  16. #56
    Jhb
    It's looking great, u motivating me to get on with my next set of mods too
  17. #57
    Sep 2010
    Lonehill
    Quote Originally Posted by MXDURO View Post
    Gas cooker done.
    That is very neat!! Which gas cooker did you use?
    2013 Toyota Land Cruiser 200 VX 4.6L
  18. #58
    v-town
    Thanked: 31
    Dometic
  19. #59
    Apr 2008
    Secunda
    Thanked: 254
    MX
    Glad to see the 17" Mags are on, know mine not as unique anymore
    Your mods look great
    Between work, studies and new babt I dont seem to get around to as much as I should, but that will also pass so I hope to make use of your experience soon
    ORRA Call Sign: X85
    Gerbers Alu Canopy
    Howlingmoon RTT
  20. #60
    v-town
    Thanked: 31
    Installed a water pump today. Works like a charm.
  1. Rear Seat Mod - Part II (Pic Heavy)
    By AcidHawk in forum Land Rover
    Last Post: 2015/04/15, 11:27 PM
  2. Mod or accessory
    By OFFROAD ADDICT in forum The 4x4 Pub
    Last Post: 2010/04/09, 08:43 AM
  3. Courage vs Bush Baby
    By Rasmus in forum Camping, Fridges, Accessories
    Last Post: 2010/03/01, 03:44 PM
  4. UK to Cape Town Overland: Lost Thread
    By MikeAG in forum The 4x4 Pub
    Last Post: 2009/11/20, 04:10 PM
  5. A sad time (mod note: posts moved to new thread)
    By SimonB in forum General 4x4 Discussion
    Last Post: 2007/08/28, 12:57 PM
