Results 1 to 17 of 17
    Jun 2008
    Thanked: 226
    Default skydiver almost gets struck by meteorite
    Where are the stats experts?
    Ironman Suspension
    40mm Body lift
    31x10.5x15 Cooper STTs
    Thanked: 995
    DAMN!!!! That guy's LUCKY - and then some.
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
    Jan 2011
    Mtwalume, South Coast
    Thanked: 145
    Now that is "Skid Mark" stuff....
    Gordon's Bay
    Thanked: 4378
    Meteorite?
    Meteorites arrive at somewhere between 10km/second and more.
    thats 400m per frame off a go pro at 25 fps. Minimum. you won't even see it pass by at close range.
    It looks more like someone threw that rock. weird.
    Jun 2008
    Thanked: 226
    Maybe it was packed in someones 'chute? If it was filming in 60fps or 30fps might change calculations.
    Edit: There are some pretty good calculations here:
    http://norskmeteornettverk.no/wordpress/?p=1329
    Ironman Suspension
    40mm Body lift
    Douglasdale Fourways
    Thanked: 9
    Owen stats are easy bud. You have the same chance of getting hit by a meteorite while skydiving as the chance that JZ will pay for Nkandla out of his pocket.
    Jeep, there is only one.
    JHB
    Thanked: 99
    I think it was a "boeing bomb" like in the movie joe dirt
    http://www.youtube.com/watch?v=Rtm8w3o63AA
    edit added you tube video to explain
    2012 Pajero Sport 3.2 A/T
    2020 Forester 2.0IS CVT
    EX: 2001 colt V6, 2010 jimny
    Dec 2006
    Thanked: 870
    The relative speed between the rock and the jumper makes it highly unlikely to be a meteor....not meteorite, well, not yet at that stage.
    Although it would slow down to terminal velocity, it being very dense, even that is helluva fast. MUCH faster than 4 frames? from a camera held by a guy hanging from an open chute.
    I think these jumpers set it up to attract attention.
    Sakkie Coetzee
    Gordon's Bay
    Thanked: 4378
    http://www.news24.com/Travel/Interna...orite-20140404
    When a meteoroid enters the Earth’s atmosphere it forms a blazing track across the sky and becomes a meteor.
    When the light disappears, the meteorite enters the stage called 'dark flight,'and falls straight down.
    Helstrup's video footage is the first ever that manages to capture a meteorite in this 'dark flight' mode.
    I call BS.
    even if you 'only' dropped a rock from a plane, never mind slowed it down from interstellar speeds, it's still going to be moving a bit after a few seconds.
    gravity at 10m/s/s, and the terminal velocity of a rock is pretty high as it has low drag for it's weight.
    a 'spread' skydiver does around 200km/h or 60m/s, if they dive (head down) it's faster. a dropped rock must be good for well over 250m/s or 800km/h after 25 seconds. I'm betting way more. once the chute is up they are doing about 10m/s
    differential speed would still be huge - I say that rock was added in post...
    Heidelberg
    Thanked: 20
    Cant be meteor... When a meteoroid enters the atmosphere, friction, pressure, and chemical interactions with the atmospheric gases cause it to heat up and radiate that energy, thus forming a fireball, also known as a meteor or shooting/falling star.
    None of the above was seen on the vid.
    Also thinks that skydivers done this for attention....
    Dec 2006
    Thanked: 870
    Quote Originally Posted by leonlieb View Post
    Not all the way to earth. Only really big ones do that, and they leave big holes where they hit.
    Done some calculations quickly. Not perfect, but close enough for a good guess.
    Terminal velocity for an iron based object that far into the atmosphere is roughly 140m/s
    Terminal velocity for a guy hanging from an open parachute is roughly 5m/s
    Differential speed = 135m/s
    @ a frame rate of 29 frames per second (the slide show effect makes it highly unlike that it is high speed footage) that would mean that rock will travel just under 5m per frame, in relation to the jumper....
    Sakkie Coetzee
    Jun 2008
    Thanked: 226
    it does look suspiciously smooth and grey.
    Ironman Suspension
    40mm Body lift
    Thanked: 2777
    If a chunk of meteoroid passed him and he was lucky enough to film it he would be in a heap of trouble when that sized stone hits earth sort of a fire and brimstone landing
    Henk
    Follow us on Facebook
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by Sakkie View Post
    Don't know what the shutter speed is on a go pro, but it's usually 1/frame rate.
    as far as I know, the Go Pro records like a TV refreshes - records from top down over and over, so you don't lose the shutter close monent like an old school movie camera.
    the rock is perfectly focused and still - no motion blur - in every frame like a 1/1000 shutter speed shot. with a 5m motion it should just be a streak.
    definitley added in post...
    Gordon's Bay
    Thanked: 4378
    http://www.universetoday.com/110963/...es-it-on-film/
    multiple frame picture on this page... definitley doesn't look real to me!
    Dec 2006
    Thanked: 870
    Pause the video, and go through it frame by frame. Prior to the "meteor" lots of sun glare. The four frames showing the rock have dark blue sky with zero glare, the 5th frame (no rock) has glare again.... Photography does not work like that.....and I don't believe in coincidence when it comes to things like this.
    Also, if you follow the path of the rock, the 5th frame should still have the rock.
    This is fake.
    Sakkie Coetzee
    Jun 2008
    Thanked: 226
    Some evidence of it being a stowaway piece of gravel in the 'chute.
    http://www.planetary.org/blogs/guest...allistics.html
    Ironman Suspension
    40mm Body lift
  1. Any meteorite hunters in SA?
    By Francois Theron in forum Other diverse topics
    Last Post: 2014/05/21, 11:40 PM
  2. Lightning has struck
    By MariusFourie in forum The 4x4 Pub
    Last Post: 2013/02/11, 08:59 PM
  3. Lightning struck your house?
    By Jeep Luvva in forum The 4x4 Pub
    Last Post: 2010/02/18, 12:13 PM
  4. Thunder struck
    By Spike in forum The 4x4 Pub
    Last Post: 2008/05/21, 11:15 AM
