Share your DIY Camping gadgets - Page 9
Page 9 of 85 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 34 59 ... LastLast
Results 161 to 180 of 1696
  1. #161
    Default Battery Boks
    Hierdie draagbare krag boks staan in ons huis bekend as "Eskom" (maar dit is baie meer betroubaar). Ek het die battery boks gekoop by Outdoor Warehouse, 3 Hella proppe direk op die boks gemonteer en toe 'n ekstra boks aan die kant vasgesit met nog 3 Hella proppe en 1 x sigaret prop. Ek gebruik 'n C-Tek herlaaier om te herlaai, maar die plan is om 'n extra konneksie in die bakkie te installeer om die battery in die ry te laai.
Name:	IMG_1803 (1280x960).jpg
ID:	275748   Click image for larger version.
Name:	IMG_1804 (1280x960).jpg
ID:	275749   Click image for larger version.
Name:	IMG_1805 (1280x960).jpg
  2. #162
    The hills
    Quote Originally Posted by Welly View Post
    To keep myself busy this weekend I decided to make up some camp lights.
    I installed 2 x 12v batteries in a plastic crate. I can either charge the batteries with a trickle charger or a 10 watt solar panel. For the lights I used 4 x 30mm LED strip lights, each one with its own switch. The lights connect to the power pack with cigarette lighter connectors. The lights can also be connected to a normal 12v transformer fitted with a female cigarette lighter socket. The dual connectors on the power pack also have a USB port.
    Ek gebruik n jumperpack wat ingeboude charger en ook usb port het. Charge op 12 volt of 220 volt en meer kompak en kan ook jumpstart.
    EX PERD
  3. #163
    Thanked: 107
    Quote Originally Posted by gerhardperth View Post
    Gerhard, I've seen those, but always wondered if they were really what they said they were.
    What size battery does it have inside? Can't be much bigger than 2x 7ah can it?
    Or is this something completely different than a normal battery?
    Looks nice and compact though. Price?
  4. #164
    Thanks will take you up on thhat. Will call you.
    If you don't risk a no .... you will never get a yes
  5. #165
    Smile
    Quote Originally Posted by Adam Stander View Post
    Janis, I see you're in Pta.
    Thanks Adam will take you up on that
  6. #166
    Mar 2013
    Quote Originally Posted by HandeVierVoetJimny View Post
    Dis netjies en welgedaan. Sal dit in n Jimny ook pas?
    Het hom spesifiek vir die beskikbare spasie gemaak ~800x400x450mm, jy moet maar die dimensies aanpas as dit nie vir jou werk nie. Deel graag my ondervinding /planne indien jy belangstel.
  7. #167
    The hills
ID:	275810Click image for larger version.
    On the rear its got a solar batery charge input with built in voltage regulator. Can buy this as optional.
    EX PERD
  8. #168
    Thanked: 107
    Have you used it to jumpstart a motor Gerhard?
    Looks like a nice item. Better than the previous picture.
    Price?
  9. #169
    Apr 2012
    Thanked: 49
    Looks like a nice item. Bettere than the previous picture.
    Price?
    I manage our department's vehicles at work and they don't drive to often so the result is I usually have complaints that the vehicles don't want to start. Got myself one of these jobbies at autozone for about R800 if I remember correctly. Works like a charm...one petrol nissan hardbody and one oooold diesel hardbody. No issues to start either.
    Also know of someone that uses one at this auto body shop when vehicles stood a while and bettery ran flat.
    You'll be amazed at how well this thing actually work....I can't understand how you can jump a few times on one small internal battery....
  10. #170
    May 2012
    Thanked: 1030
    From the picture it looks like it's got a 24AH battery.
    I suspect a normal High Cycle with high CCA.
    "Grent" Vitara
    EX- EL JIMBO - RED AND "FAST" 8)
  11. #171
    Patensie
    Thanked: 21
    Bos Stort . Gardena 5 liter pressure spray. Two people can shower with 5 liter of water . Price +- R200
  12. #172
    The hills
    Default Share your DIY Camping gadgets
    Its got a built in AGM batery thats replacable. Yes done a few jumpstarts with it ( ls1 v8 twice in a row) and run 50 liter fridge while camping. Need to charge it in about 1 and half day. But fridge needs to be cool before you get this kind of results.
    The front charger is a slow charger where as the rear is for quick charge. Either straight charger or solar.
    First pict was example. 2nd picture the real deal. Tested and proved. 2 years now. No problem.
    Reason I got this is cause I drive an auto and go solo. For me its serves a double purpose.
    Also easy to use to air up matress inside tent. Click image for larger version.
ID:	275887Click image for larger version.
    EX PERD
  13. #173
    Thanked: 107
    Dankie Gerhard
    Duidelik gaan ek vir my een moet aanskaf
  14. #174
    The hills
    Dankie Gerhard
    Ja dit maak dit net makliker en kompact waner jy gaan kamp.
    EX PERD
  15. #175
    Ek gebruik dieselfde en werk baie lekker. Het nig nie my yskas daarop probeer maar hardloop al my led ligte vir die hele naweek voor ek hoef te herlaai
  16. #176
    Apr 2011
    JHB
    Waar kan 'n mens die units aanskaf locally...? (Gerhard ek sien jy is in Aus)
  17. #177
    Ek het sommer n cheapie by Adendorffs gekoop vir so R400; maar moes paar ekstra kragpunte bysit. Hy kom net met een sigaret poort. Gerhard sn lyk na n beter kopie as mens dit hier rond kry...(myne het ook net een opsie vir herlaai en kan nie sonpaneel vat nie).
  18. #178
    Apr 2011
    JHB
    Quote Originally Posted by grobbepj View Post
    Ek het gou probeer kyk maar kon net die kry wat beskikbaar is in Aus.
  19. #179
    Jul 2013
    Witbank
    Thanked: 53
    Busy planning my DIY awning. But first I need some info...
    Where can I buy aluminium square tubing with connector bits? And how much should I pay roughly?
    I'm trying to do a costing for the plan.
    Please reply or PM me if you have details on price or weight of aluminium tubing. Thanx.
    2013 Jimny, stofpad4x4 undies, OME suspension, DIY alu roof rack.
    2011 Jimny SOLD
  20. #180
    Virginia
    Thanked: 25
    You get the connectors at Maizey Plastics!
  1. Camping tips, tricks and gadgets
    By Davidvan in forum Camping, Fridges, Accessories
    Last Post: 2019/12/09, 07:44 AM
  2. Camping info needed: Namibia
    By rudiedj in forum Namibia
    Last Post: 2014/04/23, 08:42 AM
  3. Replies: 538
    Last Post: 2014/01/11, 10:19 PM
  4. Need to share camping site at ihaha - 2nd nov.
    By bushballie in forum Botswana
    Last Post: 2011/08/23, 02:24 PM
