Share your DIY Camping gadgets - Page 85
Page 85 of 85 FirstFirst ... 35 60 75 76 77 78 79 80 81 82 83 84 85
Results 1,681 to 1,696 of 1696
  1. #1681
    Wilderness
    Thanked: 1104
    Default Re: Share your DIY Camping gadgets
    Made a bracket to fit a light winch on the towbar. 500kg only, and will do double, with a snatchblock.
ID:	562023Click image for larger version.
    Sometimes its all you need to get you out of trouble. You guys are welcome to copy. I made the plate the same width as the winch. The hole for the towball is slightly bigger than 50mm. If i remember correctly. The slot was 35 mm wide. The plate length will be determined by the length of the crank handle+ 150mm. Holes for the winch can also differ between makes.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  2. The Following 5 Users Say Thank You to Pieterk For This Useful Post:
  3. #1682
    Feb 2014
    Thanked: 32
    Very cool, are these available for purchase?
  4. #1683
    Jun 2013
    Thanked: 101
    Quote Originally Posted by d7e7r7 View Post
    Roadque sells the manual winches.
    2010 Defender 110 Puma HCPU (Bostrok)
    2015 Mercedes Benz GLA (Swambo's Glam)
  5. #1684
    Oranjemund Namibia
    Thanked: 144
    Quote Originally Posted by Alberto View Post
    nou in die righters veld was, toe haal ek die pomp uit en daar val alles uitmekaar en toe prop ek dit maar alles so terug ook en maak plan vandag daai pompe pomp gou gou, kan nie verstaan dat mense klein pompe koop nie .bly ek kon help.
    I had one of those double pumps, stopped working in the kaokoveld when I was traveling alone with Bridgestone tyres . I had to take the thing apart and got it to work but it took a while.
    Bought two of those olive green small and cheap volcano pumps.
    Carry two, if I am in a rush, I use them together and they are probably just as quick as the big pumps.
    Kimball R. Pitcher
    Head - 2007 Toyota Fortuner, OME, extra tank, roof rack, bent running boards
    Heart - SFA hilux dcab
  6. #1685
    Thanked: 34
    This is the first time I am posting on this thread, as I look at all the good ideas with wonder.
    However I made the decision long ago to use ONLY stainless-steel screws etc on my gear. This kills rust which ALWAYS comes out after a holiday.
    My tip therefore is 'Replace with stainless when possible'.
    Life starts
    where the comfort-zone ends.
  7. The Following User Says Thank You to Mick For This Useful Post:
  8. #1686
    Wilderness
    Thanked: 1104
    Very easy to make yourself. 6mm plate. 3 holes for winch and the big hole with slot for tow ball.
  9. #1687
    Feb 2014
    Thanked: 32
    Everything's easy if you have the equipment and know-how hey...
  10. The Following User Says Thank You to d7e7r7 For This Useful Post:
  11. #1688
    Cape Town Southern Suburbs
    Thanked: 1043
    Quote Originally Posted by Mick View Post
    Just watch out for galvanic corrosion.
  12. #1689
    Thanked: 34
    Yes. No signs after many years of Galvanic corrosion where I have used stainless, but looking out for it anyway. Thanks for a valuable, and to-the-point rider. Mick
    Life starts
  13. #1690
    Jul 2014
    Lonehill
    OK, here is my DIY double battery project. The existing one is a NL portapac. I used Anderson plugs from the 2nd battery to plug into the NL box. The theory being that I have a degree of protection from the circuitry. It can be now used both off and on the vehicle.
    Pic 1 shows how I can use both battery's in the house to run an inverter off the grey Anderson plug
    Pic 2 shows how I can link both batteries and still receive charge from the alternator via the red input plug on the portapac
    other pics just show wiring. There is a battery monitor on the NL box and a dual one in the vehicle. A single one on the separate box.
    I can also when camping disconnect the 2nd(3rd) battery to use in camp or tent.
    Quite chuffed with my little project
    @Stranger - where did you buy the battery box for the 2nd battery, not the NL box? TIA
  14. #1691
    Oct 2012
    Lambert's Bay
    Thanked: 110
    Dis nou n bakgat idee.....kan ons dit maar 'copy'? Dis seker nie geregistreerde patent of hoe? Wil net een vir myself hę. Ek ry al jare so 'n los winch met n staalkabel soos daardie, saam; sogenaamde 'comealong' maar hierdie sal beter werk.....solank jy agtertoe kan trek en iets het om aan vas te maak. Ek ry ook 'n ysterpaal van so 1,2m lengte en 'n groot hamer saam vir sulke gebeurlikhede en ingeval daar nie n boom of ander voertuig is nie. Gelukkig nog nooit nodig gekry nie.
    There is no human problem which could not be solved if people would simply do as I advise
  15. The Following User Says Thank You to Alto For This Useful Post:
  16. #1692
    Sep 2014
    Rustenburg
    Quote Originally Posted by johannvisser View Post
    Brilliant!
    Great
  17. #1693
    Aug 2016
    Thanked: 107
    SS is used extensively in the food industry. It creates its own problems. The biggest problem with stainless is when you tighten it properly, it tends to start seizing up. This is much worse if the nut is also SS. When you need to take it out it seizes solid. You then have to turn it right off, drill it and hope there is enough meat left to re-tap. A drop of nickle-antiseize at installation normally solves that. Coppa-slip also works but not as well. Problem with that, it affects the torque applied. Do not use SS on critical bolts and especially not on bolts that need to be torqued.
  18. #1694
    Thanked: 11238
    gonna steal that idea, have one of those in the workshop that I was wondering what to do with
  19. The Following User Says Thank You to jelo For This Useful Post:
  20. #1695
    Dec 2014
    Thanked: 43
    Quote Originally Posted by Pieter de Waal View Post
    Look up “Galling” for some info on various steel bolts and nuts.
    Solved a lot of headaches with this.
    Jack
    2005 Discovery 3 V8 HSE - 🤩
    2004 Discovery 2 TD5 GS - sold
    1996 Discovery 1 5.7lt Chevrolet 🤤 - sold
    1994 Defender 110 Hardtop 3.9 Auto Conversion - sold 🤑
  21. #1696
    Thanked: 34
    IF I am concerned with taking the stainless screw or bolt out again, (& IF I remember to apply an anti-sieze compound) I use to a squirt of Tectyl 506 (an old rustproofing trick - more about rustproofing later) to make it take-out-able after a time.
    I have also found that the blue-lined self-locking stainless nuts work well.
    I seldom have faced these issues though, and for purposes of this site, I stick to my original comment : 'Replace with stainless when possible'.
    Life starts
  1. Camping tips, tricks and gadgets
    By Davidvan in forum Camping, Fridges, Accessories
    Last Post: 2019/12/09, 07:44 AM
  2. Camping info needed: Namibia
    By rudiedj in forum Namibia
    Last Post: 2014/04/23, 08:42 AM
  3. Replies: 538
    Last Post: 2014/01/11, 10:19 PM
  4. Need to share camping site at ihaha - 2nd nov.
    By bushballie in forum Botswana
    Last Post: 2011/08/23, 02:24 PM
