Share your DIY Camping gadgets - Page 6
Page 6 of 85 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 31 56 ... LastLast
Results 101 to 120 of 1696
  1. #101
    May 2012
    Thanked: 223
    Quote Originally Posted by HIGHFLYER View Post
    Hi Sandboarder...what a great idea..and portable..!!
    How did u cut it and how did you prepare the gasbottel before cutting?
    Thanks and cheers
    Angle grinder with a thin cutting disc, circumference halved for the middle point
    It's a R22 refrigeration gas bottle so no flammable fumes.
    I had a built thread about it here
    http://www.4x4community.co.za/forum/...d.php?t=146991
    (SUPERCHARGED ZOMBIE ZOOK)
    (DEFENDER 130 300HP V8 "MR PUGLY")
    (LC 80 VX 1HDFT TOURER)
    --->YouTube channel<---
    Hendri Mouton (Zombie)
  2. #102
    Thanked: 107
    Homemade awning:
    Some picks showing planning and production and open and close pics.
    Also 2 vids of opening in 45sec and closing in 90sec here:
    http://www.youtube.com/watch?v=NF6OKquelSs
    http://www.youtube.com/watch?v=E61hhlHJ_7s
ID:	273823   Click image for larger version.
ID:	273824   Click image for larger version.
ID:	273825   Click image for larger version.
ID:	273826   Click image for larger version.
  3. The Following 2 Users Say Thank You to Adam Stander For This Useful Post:
  4. #103
    May 2012
    Thanked: 223
    Quote Originally Posted by Adam Stander View Post
    Homemade awning:
    Great! Mens kan sien wie is handig agter die naaimasjien (en dalk stoof?) in daardie huis
  5. The Following User Says Thank You to Sandboarder For This Useful Post:
  6. #104
    My homemade Visboks: (On homemade camping table)...
    Very innovative Adam. 8)
    Also like your DIY awning but I will not take it as far as the sowing part, that I will outsource.
    All round excellent ideas by all, well done.
    07 LC 79 4.2D (Brutus)
    Still have a flaky, rusty, leaky '05 Conqueror Conquest Trailer
  7. #105
    Thanked: 107
    One of my biggest problems with 4 people in the vehicle was the bulky soft items: sleeping bags and clothes bags.
    Takes up loads of space and always in the way.
    The space between the top of my fridge/ crates and the roof was always used, but that meant that I had to unpack before I could get to my fridge.
    So decided to build a roof cage.
    Version 1 was a steel cage and worked very well but used a lot of space when not in use.
    Then I moved to a webbing design that when empty was totally out of the way and not even visible in my rear view mirror.
    Streches from the rear right up the C- pillar. Fully packed I can use my fridge and get to anything else under the net without unpacking.
    Used rivnuts and the rear safetybelt mountings to fix aluminium strips.
    Changed from prastic clips to steel as they couldn't take the strain. (Nou trek ek hulle goed vas)
    Can comfortably load 4 big sleepingbags, 4 travel bags and 2 pillows.
    At max I've loaded 6 sleeping bags, 3 bedrolls, 4 bags and 2 pillows.
    Nice thing is, these light items are quite high, so I can put all the heavy items as low as possible so my COG is not that affected.
ID:	273851   Click image for larger version.
ID:	273852   Click image for larger version.
ID:	273853   Click image for larger version.
ID:	273854   Click image for larger version.
ID:	273855   Click image for larger version.
ID:	273856   Click image for larger version.
ID:	273857   Click image for larger version.
  8. The Following User Says Thank You to Adam Stander For This Useful Post:
  9. #106
    Thanked: 107
    Wheel step, fits over any of the 5 wheels.
    To be used as seat, table or platform for working on the roof.
    When placed over the spare it forms a platform that I've used to transport 3 bags of wood.
    Folds up nice and compact. Easy open and close.
    Forgot about it and drove over it once - no damage.
    Got a neighbour to weight test it to 155kg, no problem.
  10. #107
    Jan 2009
    Pretoria...(closest)
    Quote Originally Posted by Sandboarder View Post
    Hi Sandboarder
    Thanx...will check it out..
    Cheers..
    " IF THE GIANT BEASTS ARE GONE, MAN WILL SURELY DIE FROM A GREAT LONLINESS OF SPIRIT "
    1996 3.0L SANI "EXECUTIVE" S/W
    CAMIL SUSPENSION
    3O/9.5/15 BF GOODRICH A/T
    WILCAT BRANCHES
    REAR SUPER LEAF-SPRINGS
    PORTABLE NL DUAL-BATTERY POWER PACK
  11. #108
    Thanked: 107
    Okay, last one, the drawers.
    This was also my very first project when I bought my vehicle.
    Featured in the WegRy mag 2010 it has undergone a few changes to make it even more user friendly.
    100% scrap metal bought from the scrap metal dealers.
    I plan to build another one for the new Prado, but this time I'd like to do it properly: Lasercut and bent.....
    Here is the WegRy article
    Attached Files Attached Files
  12. #109
    Jul 2010
    Garsfontein, Pretoria
    Thanked: 436
    I bought a 2001 Venter bushbaby in February this year.
    I immediately removed the Echo Roof top tent and sold it to a guy in the Cape and bought a decent Trailer Top Tent from a gent in Pietermaritzburg.
    The trailer was too low for the tent and I made an extension piece from 200 x 75 x 25 x 2,5 of which I cut the inside piece out in order to match the trailer's top edge width.
    The 2001 Bushbaby did not come out with a side door so last weekend I employed my grinder and cut an opening through the side panel extending into the extension piece. I framed the opening with 25 x 25mm Square tubing and made another frame for the door. I covered the door frame with 0,8mm Cold rolled sheet. I bought the hinges and anti-loose clips from a trailer spares shop in Silverton yesterday to be fitted this weekend.
    I also bought new trailer jacks, the ones that swivels down from horizontal which then jacks up with a lever as the standard Venter trailer jacks are thin tubes which ends up causing an "ocean motion" feeling when you are lying in bed. With those thin legs you cannot even dream of "fooling" around a little.......
    I also bought two gas bottle brackets which I will mount inside the nose cone and lastly I will do the electricals with LED lights in all the right places, dual battery system and inverter with solar panel as back-up.
    Oh, I nearly forgot, I moved the two toolboxes that come as standard mounted on top of the wheel arches to their new position both on the left side of the trailer and I turned tem on their sides so the lids can be used as small table tops.
    Johan De Graaf
    2019 Ford Ranger Wildtrak 2.0 Biturbo 4x2 D/C
    2013 Range Rover e-vogue HSE Dynamic SD4
    2010 Range Rover Vogue TDV8
  13. #110
    Apr 2008
    Kuils River
    Thanked: 53
    Pictures?
    Francois Johnson
    (swambo: Christel)
    Our rides
    • 2010 Isuzu KB300LX DTeq 4x4 D/C
    • Metalian Maxi Trailer, Maxine
  14. #111
    Mar 2013
    Southern Suburbs
    Any chance of a drawing for this please?
    2012 Ranger T6 3.2 M. Vanilla.
  15. #112
    North of Zambezi
    Thanked: 356
    Very neat Adam!
    Some real good ideas in this thread
  16. #113
    Thanked: 107
    Quote Originally Posted by atholgordon View Post
    Sorry this was just spoeg en plak, but I could take more detail photos if you want.
  17. The Following User Says Thank You to Adam Stander For This Useful Post:
  18. #114
    Mar 2013
    Southern Suburbs
    Please do so Adam if you don't mind.
  19. #115
    Thanked: 107
    I'm leaving for the coast tomorrow morning early and will be back 06/04.
    Send you the pics then with pleasure.
  20. #116
    Mar 2013
    Southern Suburbs
    Thank you Adam. If you are near the Cape Coast and need anything, let us Kaapies know. And travel safely.
  21. #117
    Brits
    Het n tafel laai met n deksel gemaak onder my yskas. Het nou nie die nuutste fotos nie, maar het nou canvis sak gemaak vir messe en vurke wat aan die deksel vas gemaak is.
    Die burner was altyd n probleem om in en uit te haal ens. So, die outjie het ek toe agter die spaarwiel ingebou en die gas bottel is nou vas aan die canopy en pyp dierek aan die burner. So, opslaan vir koffie vat nou so 10 sec.
ID:	273962   Click image for larger version.
ID:	273963   Click image for larger version.
ID:	273964   Click image for larger version.
ID:	273965   Click image for larger version.
ID:	273966   Click image for larger version.
ID:	273967   Click image for larger version.
ID:	273968   Click image for larger version.
    Rulof
    Ford 3.0TDCI DC 4x4 2008- Wit Blits. LR Defender90 2.8i.-Bulletjie. Heeltyd speeltyd!!!
    ......you only experience the bush when the engine is switched off
    <v:shape id="_x0000_i1025" style="width: 415.5pt; height: 105pt;" type="#_x0000_t75"><v:imagedata src="file:///C:%5CTEMP%5Cmsohtml1%5C01%5Cclip_image001.jpg" o:title="untitled"></v:imagedata></v:shape>
  22. The Following User Says Thank You to Bulletjie For This Useful Post:
  23. #118
    Sep 2011
    Potch/Brits
    Thanked: 583
    Die mense van Brits is kreatief
  24. #119
    Mar 2013
    Bronkhorstbaai
    Thanked: 22
    Default Jimny Drawers
    Jimny Drawer system for now... Roofrack and others in progress.
ID:	273990   Click image for larger version.
  25. #120
    Lichtenburg
    Thanked: 162
    Default Drawer system for approximately R1000
    Drawer system from mild steel for my trailer. The drawer is running on 8 small beerings which cost R26 each. Up till now it only cost me R850 and if I add a sheet of 6ply wood to cover the frame, the total cost will only be R1120. The plasic drawers I had, so they are not included. The size is 1.7 x 0.7 x 0.37.
    Erich Visser
    2015 Suzuki GV 2.4 m/t 40mm lift and Bash Plates
    2015 Off Trax Outplay Trailer
    2006 Mercedes A170 (Swambo's)
    1996 Mazda Magnum 2600 D/C 4x4 (Sold)
  26. The Following User Says Thank You to ErichV For This Useful Post:
  1. Camping tips, tricks and gadgets
    By Davidvan in forum Camping, Fridges, Accessories
    Last Post: 2019/12/09, 07:44 AM
  2. Camping info needed: Namibia
    By rudiedj in forum Namibia
    Last Post: 2014/04/23, 08:42 AM
  3. Replies: 538
    Last Post: 2014/01/11, 10:19 PM
  4. Need to share camping site at ihaha - 2nd nov.
    By bushballie in forum Botswana
    Last Post: 2011/08/23, 02:24 PM
