Strange Noise Coming from Engine Bay
Results 1 to 4 of 4
    Default Strange Noise Coming from Engine Bay
    Hi
    I have a strange noise coming from the engine bay almost sounds like when you turn on the tap and there is air in the pipe blowing out, might also be sucking air in. It sounds like its coming from the right hand side if in front of the Jeep (battery side) of the engine bay.
    04 Jeep Wrangler
    2" Zone Off-Road Lift with quick disconnects
    31" BFG Mud KM2
    "You know you drive a TJ when you buy one of the most capable offroad vehicles on the market and then replace everything on it to go offroading."
    Sep 2012
    S2950'26.46", E3057'25.92"
    Thanked: 16
    What vehicle?
    Which engine?
    My first thought would be a leak in one of the intake hoses. Most likely between the intercooler and intake manifold if it's coming from that side.
    Does it stop straight away if you turn the engine off?
    If not it's likely a vaccuum leak...
    [life is what happens when you're notp aying attention]
    2003 Jeep GC Laredo 2.7CRD
    2011 Jeep GC Overland 5.7 HEMI
    Vryburg
    Sou ook raai , dat dit 'n vakuumpyp is wat lek.
    Carl Swanevelder
    2001 Jeep Grand Cherokee ( WJ ) 4.7 V8 Limited
    2000 Jeep Grand Cherokee ( WJ ) 4.0l Limited
    1988 Toyota Hilux 4x4
    1977 Mini
    Sep 2012
    Thanked: 16
    Thinking about it now, if it's like a tap with air in the pipes then it's a hissing and knocking sound.
    That makes me think bearing. Maybe one of the idler bearings?
  1. Advantages of 50ppm diesel
    By Sanman in forum Vehicle & Technical Chat - General
    Last Post: 2015/04/16, 05:11 PM
  2. Advantage of a Diesel vehicle?
    By Krimpie in forum Mitsubishi
    Last Post: 2014/12/26, 12:05 PM
  3. Petrol or Diesel
    By Varkienel in forum Toyota
    Last Post: 2011/03/15, 02:59 PM
  4. Colt 2.8tdi engine "ticking" noise
    By Trev in forum Mitsubishi
    Last Post: 2009/06/21, 07:24 PM
