Toyota 4Y Carburettor Engine Not Idling Well
Results 1 to 4 of 4
    Feb 2014
    Nairobi
    Default Toyota 4Y Carburettor Engine Not Idling Well
    Hey guys, recently, I did an engine swap on my Jeep Cherokee XJ and fitted it with a Toyota 4Y Carb engine, I have not driven the car a lot. But the engine does not seem to idle well. I adjusted the jets on the carburettor and even the idling screw, but when the engine runs for a while the idling goes high, when the engine is cool and i start it the idling seems to be low because if i dnt step on the gas a little it'll switch off. Recently i tried starting it but even if i stepped on the gas, it would just switch off. Now i fiddled with alternator and the idling seems to have gone very high. I really need help on this one, I just cant figure out whats wrong with it. Thanks.
    Dronk-word-baai
    Thanked: 53
    Good day, welcome here.. What carb do you have on the motor, the original nikky or the newer version with electrical choke to the firewall side? It is possible that your choke is setup incorrectly and you adjust while cold and once it is on temperature you have high idle.
    1990 Toyota Hilux - In process..
    The more people I meet the more I like my dog..
    Real 4x4's have splash guards, not sump guards..
    Gordon's Bay
    Thanked: 4378
    you put a Toyota motor in an XJ??!?!?!
    Dronk-word-baai
    Thanked: 53
    Let him learn what suffering is..
  1. Hilux / Fortuner problems
    By tjs in forum Toyota
    Last Post: 2011/08/31, 05:05 PM
  2. How likely is your vehicle to be stolen?
    By mvcoller in forum The 4x4 Pub
    Last Post: 2010/12/18, 03:10 PM
  3. Toyota does not honour warranty
    By James_Hatton in forum Toyota
    Last Post: 2010/08/16, 07:28 AM
  4. Toyota 16 days no spare available
    By div in forum Toyota
    Last Post: 2010/06/25, 02:33 PM
