Recovery resistance
Results 1 to 6 of 6
    Default Recovery resistance
    Found these lurking on my PC, couldn't find where I got them.
    If you're recovering a vehicle, it pays to know how much resistance you're likely to encounter. Use the two flowcharts to work out the resistance, add the two figures and then apply to the vehicle weight.
    Example:
    My Jeep is stuck, and it needs to be towed out of soft sand over an incline of around 35 degrees. It was spun in, up to the wheels. The Jeep weighs 800kg's wet. Thus, being mired in sand up to the wheels, is 1 times vehicle weight. 35 Degrees is between 50% and 75% of vehicle wight, so guestimate it at around 65%.
    Thus, the resistance encountered when pulling this very light vehicle out of this situation is 1300kg's. That would mean that, if a UNIFORM pull is exerted, this recovery can be done with a 2-ton breaking strain tow strap. remember that this does not take into equation the further obstacles that might eb encountered, ie mud etc.
    As a measure of safety, DOUBLE this figure to see what the minimum breaking strain is for ALL equipment used in the recovery.
Name:	gradiant resistance.jpg
ID:	15158   Click image for larger version.
Name:	surface resistance.jpg
    May 2007
    Thumbs up
    super thnx been looking for something like this ....
    Printed and getting it laminated ..
    P.S. Mods need to sticky this one ..
    Mitsubishi 4 Door
    3lt V6 2006 Facelift 4x4
    ORRA Details:
    29mHz: ZRF430
    Club Call sign: B33
    The you'll probably also love this - it's called a "stiff-leg" and is used extensively by paramedics and ems personnel in the states. I've been dying to try this out, but the last two times I've rolled my Jeep I only laid it on it's side. Pity
    It needn't be long, about 1 meter will suffice. I reckon one can hack one together in a pinch on the trail.
    Thanked: 7
    Very nice info, it can be very usefull when deciding on buying recovery equipment as well. Need to keep all these factors in mind otherwise you end up spending a lot of money on equipment that is meaningless to you when stuck in certain scenarios.
    David Maritz
    Triton - Barberian!
    Oct 2008
    Quote Originally Posted by bushcamp View Post
    Great idea
    You can use you hi lift jack to perform this, then no need to carry extra equipment with you.
    Actually your hi lift jack can perform a few functions:
    Jack
    Winch
    an now this!
    (Think I'll start a thread "how many functions can your hi lift jack perform?")
    Mar 2014
    Smile
    here is the actual formula sheet
    see pdf
    [/SIGPIC] 2007 fortuner 4.0 V6 (M) with ARB replacement bumper OLD MAN EMU Suspension, roof rack, snorkel, 12000lbs winch, rock sliders, BFGoodrich All Terrain Tires
  1. Defender Rear Recovery Points
    By terratiger in forum Land Rover
    Last Post: 2011/09/09, 10:59 PM
  2. Recovery advice - Some finer points
    By Herlu in forum 4x4 Recovery & Recovery Gear
    Last Post: 2011/01/08, 09:55 PM
  3. Autodealer Recovery article
    By JohnDough in forum 4x4 Recovery & Recovery Gear
    Last Post: 2010/10/10, 06:11 AM
  4. Pajero front recovery points on nudge bar
    By Grant Anderson in forum Mitsubishi
    Last Post: 2010/05/25, 07:12 PM
