Isuzu Auto Gearbox Problem
Results 1 to 11 of 11
    Question Isuzu Auto Gearbox Problem
    Hi All,
    I have an automatic 2007 Isuzu (Not D-Teq).
    I am experiencing problems with the gearbox lately.
    Symptoms:
    1. When I pull away from a standstill the gearbox sometimes disengage, causing the engine to rev with no power to wheels and then the wheels would suddenly engage causing a pullaway with wheels spinning.
    2. While standing still or idling or creeping forward in slow traffic, the gearbox would alternately engage and disengage at random, causing the vehicle to lurch and jump.
    3. The speedo guage would jump up and down erratically when this happens.
    Any ideas anyone?
    Kind Regards
    Andre
    Jan 2010
    Prieska
    It sounds as if you have a problem with your torque converter...
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 741
    Andre
    AFAIK there was a call-back by Isuzu on the auto box LDV's at the time. Something to do with the oil cooler in front of the radiator that caused issues. Find out from Isuzu (with your VIN Nr) if that was done to your truck.
    May be the cause of your troubles.
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
    Thanked: 182
    Do you have enough oil in the box? Maybe do an oil change.
    Isuzu Frontier 280LX 4x4 2001
    Jan 2011
    I have exactly the same vehicle right down to the year/model & I'm experiencing the same problem . I just got back now fro the gearbox specialist here in Durban.
    The technician said I have to do a complete overhaul of the gearbox ( new pistons , clutches etc) as well as replace the radiator. All for the princely sum of R21000.00. I nearly dropped a load.
    And this diagnosis was derived from a 2 minute test drive.
    Hoping to find a cheaper alternative.
    Quote Originally Posted by aviljoen View Post
    Hi All,
    Symptoms:
    Any ideas anyone?
    Kind Regards
    Andre
    Jan 2010
    Prieska
    Quote Originally Posted by YzeOne View Post
    I would def get another opinion.... REX diff and gearbox center is probably your best bet...
    Hi All,
    Thanks for all the responses. I got lucky.
    I found a post on a UK site mentioning the same symptoms caused by a faulty gearbox speed sensor. I located the speed sensor of my gearbox on the drivers side towards the rear of the gearbox. The sensor has three wires coming from it. It is fixed by one M8 bolt and pulls out with a bit of wiggeling and turning. A new sensor from Delta cost me R920.80. I installed the sensor and problem solved. The speedo is now solid as a rock and the gearbox shifts smoothly.
    Jan 2009
    Germiston
    Thanked: 93
    excellent news!
    from my fone!
    __________________
    '01 Isuzu Frontier LX 4x4 Diesel8) - For the brown Stuff
    '14 Renault Sandero 900cc Dynamique, small with a big heart
    Sep 2008
    Swakopmund
    Thanked: 166
    Now can you believe that... I bet if you didn't read that post it would have caused you a great deal more on repair costs for something so silly
    Fortuner 2.8 GD-6 4x4 Auto
    (Tough Dog Suspension / Frontrunner Roofrack and some more goodies...)
    parys
    Hi ekt nou presies dieselfde probleem. Sal jy my kan skakel op 0829339450
    parys
    Ok nee ekt nou bietjie verder gelees, dit is dan die spido sensor. My 2006 doen presies dieselfde. Gaan nou sensor gaan koop want sodra ek die plug uit geplug het en weer terug sit is hy fine vir so dag. Dankie
  1. Fortuner gearbox problem
    By Jannie0127 in forum Toyota
    Last Post: 2014/01/08, 09:17 AM
  2. Discovery 2: ZF auto gearbox pumps ATF out @ extreme angles
    By Oilrag in forum Land Rover
    Last Post: 2012/11/02, 07:58 AM
  3. Isuzu KB300LX Auto Gearbox
    By Johnvanrooyen in forum Isuzu
    Last Post: 2012/10/04, 12:14 PM
  4. Auto gearbox
    By NO FEAR in forum Jeep
    Last Post: 2008/11/12, 03:20 PM
  5. Auto Gearbox
    By jaztau in forum Jeep
    Last Post: 2008/08/08, 10:42 AM
