My Triton-Bashplate project
Results 1 to 20 of 24
    Default My Triton-Bashplate project
    I played around with SketchUp and the idea for my own bashplate design.
    I got the original design/layout from NewTriton.net as a PDF.
    Made a few changes and ended up with this...
    Johan van Rensburg
    2009 Mitsubishi Triton 2.5 - Rocksliders - Bashplate - Radio Replacement
    DiWa Offroad Caravan
    And the second plate...
    Johan van Rensburg
    Johan van Rensburg
    Sep 2012
    Looks nice, but where is the cut-out section to access your sump?
    Richard
    ONE LIFE. LIVE IT.
    1995 Land Rover Defender 110 300tdi - Winston
    BMW Z4 - Platkar/Fuel saver
    4x4Action Group - 0001
    [email protected]
    "Buying a Land Rover, specifically a Defender, is not a transaction, it's a marriage of personalities, a natural childbirth, a proud moment in time......!!" - Oldtimer
    Quote Originally Posted by JollyGP View Post
    The back plate is secured with only 4 bolts, not that much work every 10 000km...
    Johan van Rensburg
    Strand
    Hi Sky
    I like the look of your bash plate.
    I especially like the idea of it being in 2 parts. I would perhaps leave away the Mitsu sign and centre the triton or put the sign first and then triton.(reading mitsubishi triton)
    But that's just me.
    Any chance of sharing dimensions/PDF's?
    Quote Originally Posted by JeanR View Post
    Hi Sky
    PM Sent
    Johan van Rensburg
    Johan van Rensburg
    Quick fit before painting...
    Johan van Rensburg
    Strand
    Hi Johan
    Dit lyk smart.
    Nov 2011
    Hillcrest, Durban
    Default Awesome!!
    Ok, dit wil gedoen wees. Baie nice!!
    Ek is amper klaar met my rocksliders, so die bashplate is volgende op die lys.
    Ek sal self graag ook daai dimmensies en design in die hande wil kry? Gewillig om te deel?
    '10 Mitsubishi Triton 3.2 DiD Manual 4x4
    Lets go play!!
    May 2013
    Pinehurst
    Looks great!
    Sent from my GT-I9190 using Tapatalk
    2010 Pajero Sport
    2011 Triton 3.2 C/C 4x4 (sold, excellent vehicle)
    How much?
    Francois Hamman
    2010 Mitsubishi Triton 3.2 Auto
    1992 Mitsubishi Pajero JDM SWB 3SGTE ST205 32x11.5x15 Maxxis Bighorn
    Sep 2013
    Looks very nice, Well Done.
    Just be careful, I have a Lynx bashplate and bought it because I liked the design and it got some reputable endorsements. After a year of use I can confirm it is way better than I expected.
    One key design feature is an angle iron cross piece under the radiator to prevent the bash plate from bending under the radiator if it took an impact.
    You have a lot of cut outs in the area of the radiator so I would seriously consider some bracing under the radiator.
    My main caution is however that the the place where the 2 plates are joining has a very weak attachment point on the chassis cross member. My bash plate has taken only a few moderate knocks and already one of those brackets that the bolts screw into have broken off. If it were not a 1pc bash plate it would have rattled around and another hit would make bending the plate a lot easier. With the 1pc the bash plate is still supported by the cross member if it takes an impact so the strength is in no way compromised.
    I like your design and it looks super smart but I would personally put a support under the radiator and have stronger mounting points fitted on the cross member at the joint!!
    Triton DC 2,5 SS 4x4
    Lynx Bashplate
    Powerbrake AT
    Kumho KL71 265/75/16
    DIY Dual Battery System
    DIY Rocksliders
    DIY 40mm Lift Kit
    Next Project, Transfer case skid plate
    Oct 2006
    pretoria
    Baie nice
    LEON CAHILL
    Jeep Wrangler JK Rubicon
    PajeroSport 2.5 HP
    Echo 4 4x4 Trailer
    Jeep Wrangler TJ '99 (My Classic Toy stock standard)
    *3.2 PajeroSport replaced with 2.5 PajeroSport
    Dec 2014
    Amanzimtoti
    Quote Originally Posted by Skymaster View Post
    PM Sent
    Hey bud. Hope you well.
    I am keen doing a bashplate for my new 2014 triton. I really like the one you have done.
    Is there any chance that you wouldn't mind sharing the info on the bash plate.
    Would really appreciate it.
    Krijn Haus
    Mitsubishi Triton 2.5 DID 4x4 2014
    There is no better channel then BUSH TV
    Would you share the dimensions / drawings?
    Jan 2014
    Default Re: My Triton-Bashplate project
    does someone maybe have the dimensions for the front bash-plate as I drove the factory one off, and it seems that it wasn't shared here...
    thanks
    I just love minerals!
    Dec 2013
    Pietermaritzburg
    That came out looking really professional - good looking plate. Who did your CnC work?
    Pajero Sport 2013 3.2 A/T
    Quote Originally Posted by Topazguy View Post
    thanks
    Daar is m triton whatsup groep. Hulle het planne vir een. Ek het myne sommer self gemaak en gesny met grinder en dremmel. Die cnc manne wou my rook.
  1. Project Triton Roof Console - come guys!
    By Die SwartKat in forum Mitsubishi
    Last Post: 2016/07/19, 08:20 AM
  2. Project Triton - Canopy Side Doors
    By HannesvZ in forum Mitsubishi
    Last Post: 2014/07/21, 07:52 PM
  3. Project Triton Cargo Slide
    Last Post: 2014/04/01, 01:10 PM
  4. Replies: 112
    Last Post: 2013/12/19, 03:39 PM
