Jerry cans in the Hilux D/cab
Results 1 to 11 of 11
    Mar 2007
    Default Jerry cans in the Hilux D/cab
    Any tips on securing the 3-4 jerry cans in the back of my Lux on our trip to Sadle Hill. The Engel is nice and steady on the mounting, but I am worried about petrol bouncing around on the dunes.
    I will surely empty the first one and a halve the first day??
    Thanx
    Skalla
    Hilux D/C 4L V6.
    If you have a rollbar fit them on the inside of the rollbar. If you tie them properly they will not fall around at all.
    David Maritz
    Triton - Barberian!
    Oct 2007
    Oranjemund
    Pack them as close to the cab as possible, as far forward as possible - they will not bounce as much. Also ratchet them together and then secure them.
    I have done the trip past saddle to meob a couple of times - did not find this to be a problem - normally packed so much in that there was no possibility of anything moving.
    Dec 2007
    Thanked: 92
    I would also like some advice on this topic.
    We are planning a trip to the Richtersveld this September and I plan on taking 2 Jerry Cans with.
    I want to stay away from a roof rack if possible.
    My question is this : how safe is it to transport the jerry cans in the back of my Hilux with all my other stuff?
    Any other ideas on where to mount the J-Cans ?
    Birmingham
    I did Cape Town to Etosha and across to the Skeleton Coast and back down with 3 Jerry's in the back of my ex Hardbody. I agree best place them near the centre of gravity. I placed mine in a large plastic box and packed them tight with foam. I them tied the box to the bakkie tight. No trouble the whole trip. Even doing that I still got paint rubbing around the area. I also use large plastic boxes for other stuff like food. Easy in and easy out the back. As few boxes as possible makes life easier. They just need to be secured.
    durbanville
    Hi scalla
    weet nie saam met wie doen jy die trip nie, die ouens wat ons uitgevat het , het extra diesel/petrol saamgevat vir ons.
    ons het dit net met hulle gereel
    jumbo
    Mar 2007
    Tnx Jumbo
    Ons doen dit saam met Coastaway tours.
    Blykbaar moet ons 160L Petrol he. Dit beteken ek moet 4 kanne neem. My plek is goed want ons ander pelle vat 'n Challenger sleepwa wat hulle los by Luderitz.
    Terloops, die bakkie is vandag by Hein Burnet afgelaai.
    Skalla
    Skalla
    Hilux D/C 4L V6.
    Jul 2007
    Pretoria (PvR)
    Quote Originally Posted by jumbo View Post
    Hi scalla
    jumbo
    Vat eerder jou eie brandstof saam(as jy kan), jy kan met hulle vooraf reel om vir jou brandstof saam te vat maar jy koop dit dan by hulle teen R11.00/liter
    Ek het ook my 4 jerry kanne aan die rollbar agter teen die cab vasgemaak met tiedowns, hulle het mooi stil gesit en saamgery oor die duine.
    Albert Gravett
    Isuzu KB6 3.0 D-Teq D/C 4x4 Auto
    ORRA Call Sign B66
    Thanked: 82
    S my gaan die dra van die brandstof kanne op die dakrak 'n groot invloed op jou bestuur in die duine h? Het iemand al die duine gery met die brandstof kanna op die dakrak? Ek weet dit het te doen met die gewig wat hoog is en dus die voertuig top swaar maak. Die kanna behoort vinnig leeg getap te word soos 'n mens vorder.
    Wie het dit al gedoen?
    Groete.
    Ben
    RY WAAR JY MAG MET PASSIE
    2009 Toyota Hilux 3.0 D4D DC 4X4
    Loevenstein, Bellville
    Thanked: 331
    Quote Originally Posted by Whisky View Post
    Groete.
    Ek sal meer worry oor die kanne wat warm bak in die son as die gewig op die dak. Ek kan nie dink dat die hitte kan goed wees nie.
    Wat ek dink wel 'n probleem kan wees is 'n groot tenk op die dak, amper soos die 50 liter plat tenks wat mens kry by Makro. Die moeilikheid is dat vloeistof altyd gaan waar jy hom nie wil h nie. Dis nou behalwe as die tenk vol is of leeg is.
    Niel
    2012 BMW F800GS
    Die jerry kanne sal vinnig uit brandstof raak want die voertuig raak swaar op brandstof met al die sand ryery. As die kan vol is maak dit nie saak nie dit sal nie skommel nie maak net seker dat die gewig gebalanseer is.
    Uit ondervinding, al jerry kanne heeldag op die dakrak in die son en niks gebeur nie. Moet net nie die kan vinnig oopmaak nie baie van die brandstof sal op die grond le. Maak die kanne verskieslik stadig oop en as dit koel is so maak die tank eerder vol in die oggend ipv die middag.
    David Maritz
    Triton - Barberian!
  1. Pressure Testing of Jerry Cans
    By Sonspar in forum Vehicle & Technical Chat - General
    Last Post: 2014/09/01, 01:10 PM
  2. Replies: 22
    Last Post: 2011/03/09, 07:12 AM
  3. Hire Jerry Cans
    By PRA in forum The 4x4 Pub
    Last Post: 2010/03/08, 12:46 PM
  4. Rust in Jerry cans
    By AVM in forum Camping, Fridges, Accessories
    Last Post: 2010/01/18, 08:50 AM
  5. Cleaning jerry cans
    By Silurian in forum General 4x4 Discussion
    Last Post: 2008/12/03, 06:17 PM
