Results 1 to 9 of 9
    Dec 2007
    Gordon's Bay
    Default Flashing Handbrake Lights
    Guys,
    last night I noticed that the handbrake light flashes when I'm braking downhill, and stays on for a few seconds until I drive off again.
    Any ideas on what's going on there?
    Pretoria North, Patryshoek
    Thanked: 3382
    Brakefluid is low. Don't top it up, else it will spill on the paintwork when you replace the pads. Rather fit the new pads, then top it up.
    +27 zero eight 2 four 95 9252
    Dec 2007
    Gordon's Bay
    Quote Originally Posted by henris View Post
    erm, does this mean that pads need replacing as well? Also, which brand/type of brake fluid must I use?
    Thanked: 3382
    Not neceseraly(spelling). Just make sure it is not to low in the reservoir.
    When the pads are finished you will know it. Will make a terreble grinding noise. Nothing serious. Only the high ridge on the disc rubbing on the pad.
    By default you allways buy the softest pads. They brake the best and will not eat up your discs.
    Pietersburg
    Without bashing brands,
    Which makes would be the softer make, Henris?
    Deon
    If you can't fix it with a hammer,you have an electrical problem...
    Jhb & Juba
    Thanked: 15
    The best on a Landy bar none ........ Ferodo Platinum.
    It's a compromise between soft and wear and these are my first choice.
    Dec 2007
    Gordon's Bay
    Funny that, I went and bought some Dot4 brake fluid to top up the reservoir. Imagine my surprise when I opened the brake fluid reservoir to find that it was below the MAX level by only about 2 cm!!! So I topped it up and the flashing handbrake lights never occured again!
    Is the sensor *that* sensitive!?
    De Kelders
    Thanked: 136
    On some vehicles the sensor is sort of overly sensitive. Found it many times on Toyota vehicles.
    Dec 2007
    Back in Boksburg (ex PE)
    Thanked: 33
    Quote Originally Posted by Naks View Post
    Lol -- Always buy the bestest brake fluid you can. ( i got Motul RBF600 in mine)
    (do you know -- British Police change their vehicles brake fluid every 3 months)
    We should change ours at least once a year.
    Brake fluid collects condensation - and damages components, not to mention the danger of brake fade.
    Hot and Sweaty- Nice if you with a Lady, - BAD if you in the Jungle.
    Triumph ST 1050
    Toyota 2.8 Auto
    Honda CBR 1000
    Toyota Fortuner D4D
  1. Discovery 2: TD5 Auto Box Flashing Green Lights
    By Grant66A in forum Land Rover
    Last Post: 2014/01/26, 09:25 AM
  2. Hazard Lights Flashing
    By AMA-ZING in forum Land Rover
    Last Post: 2014/01/06, 02:18 PM
  3. Flashing 4x4 Lights not flashing
    By otto1 in forum Mitsubishi
    Last Post: 2011/09/30, 04:23 PM
  4. A new type of Flashing lights
    By UCAB in forum Mitsubishi
    Last Post: 2009/04/21, 04:11 PM
  5. Disco II M & S Lights flashing
    By Johans in forum Land Rover
    Last Post: 2009/01/05, 09:24 PM
