Defender Cracked chassis! can you weld it?
Results 1 to 19 of 19
    Witbank
    Thanked: 205
    Exclamation Cracked chassis! can you weld it?
    Good Morning all,
    Looking for some advice. I recently bought a 130 300Tdi and when I was replacing the front right wheel bearing I happened to notice a crack in the chassis rail.
    It is luckerly not all the way through the chassis rail. It is only a hairline crack at the moment but I don't really want to leave it unattended and let it progress to the point where it cracks all the way through.
    So my question is how do I fix it? Do I weld over the crack or do I put a plate over the crack and then weld the plate. Or do I drill through the chassis and bolt a plate on either side?
    If I was to weld it where/who could do something like that (I don't trust my welding that much).
    Thanks in advance
    Gordon's Bay
    Thanked: 4378
    I'd head to a proper body shop. Have them check the chassis is straight.
    They will need to check the area for further cracking, and weld plates on all sides of the chassis in the area
    Witbank
    Thanked: 205
    Thanks Apoc
    Now all I need to do is find a decent body shop here in Standerton, not keen on driving it too far with the crack.
    Anyone know of a decent one in the standerton/ secunda area?
    Thanked: 36
    I know Modern Collision repair (MCR) in Trichard is an approved panelbearer shop, maybe have them take a look
    Jun 2013
    Firstly i would drill 2 small holes, one at each end of the crack to stop it spreading.
    Then grind a nice "v" into the crack and weld it up. then i would weld a plate over the crack
    ADMIN REMOVED
    Witbank
    Thanked: 205
    Thanks Sennin,
    I'll give them a call.
    Wilderness
    Thanked: 1223
    Get 6mm flat sheet cut pieces and weld on to the chassis, (Box the chassis) and forget about it.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    doonside
    I would weld it my self then put a patch over it. Apocalypse advice is also good. A good panel beater with a chassis straightening machine should be able to check and make sure everything is still in speck.
    Wesley
    1988 Range Rover 4 door. 2.7 turbo diesel. 4.7:1 diff ratios. 2" body lift. 255/85R16 maxxis bighorn's + camel cut. AKA: shady
    A true oil burner that runs on Black Diesel.
    Jan 2011
    Thanked: 9
    Yup, have them check its all straight, then ask them to box it or fishplate it if they can't box it..
    May 2010
    Bergbron, Roodepoort
    Thanked: 223
    Quote Originally Posted by wallee View Post
    What he said
    Jul 2013
    Underberg
    Hi .I have a 130 that had a small crack,welded it with LH rods.never had a problem again.If the crack is small,grind a V into it and weld,no plating needed.
    Thanked: 14234
    Yes. that's the way. Drill holes through the plate before you weld it on, and then weld on the sides and also do a fill-weld in the holes.
    3mm is fine, the landy chassis is only 3mm anyway.
    Thanked: 36
    Just remember that welding on a chasis changes the metals characteristics and can cause fractures later on if not done correctly
    Sent from my SM-N9005 using Tapatalk
    Nigel
    Thanked: 2311
    Quote Originally Posted by Sennin View Post
    Yes. No sharp angles. Rather us a round patch.
    Uniglide
    +27 zero eight 2 four 95 9252
    Secunda
    Thanked: 38
    Remember to disconnect the battery first before welding is done.
    Sep 2012
    Fourways
    Thanked: 25
    Just remember to use a decent mig, or even tig welder as well.
    Sent from my iPad using Tapatalk
    Springs
    Thanked: 280
    Get a exhaust shop to weld in the crack extending 10mm beyond the visible crack
    Do not grind down
    Use a hammer to gently knock the welded section in so the welding does not protrude
    Lay a 40 x 3 flatbar over the welding and weld in place
    This "patch" will ensure that the chassis is not again stressed in the same spot where it cracked originally
    Sep 2012
    Thanked: 7
    +1 was just about to say that
    2007 VW Touareg 3TDi V6 with air suspension
    Kemptonpark
    Thanked: 79
    Chassis welding/repair is not as clear cut as some seem to think, you need to establish the cause first. That will tel you what action you need to take and size of the repair to prevent it happening again. Just slapping a bunch of patch plates/box sections could make things worse.There is a rule of thumb, what you do to one side, you do to the other side. On lighter chassis's where repairs are in critical area's you don't want to over stiffen one beam over the other. This is very relevant in the 50Ton and up trailers, where patch plates can cause complete failure on the beam.
    2007 TDV6 S
    ARB BB and winch,BRS HD tow bar,TT and EGR's blanked,RR with dual awnings,Duel batterys,Custom long lange tank,Centre mount fridge,Custom rear box,Custom internal water tank 65Lt,Custom dash consol,Custom swing out spare wheel carrier, Adjustable 50mm suspension lift, SDV6 3Lt conversion.
  1. Cracked Navara chassis
    By JGoosen in forum Nissan
    Last Post: 2016/02/06, 09:37 PM
  2. Chassis Number???
    By Navigator in forum The 4x4 Pub
    Last Post: 2013/03/06, 01:00 PM
  3. Chassis number stamped on chassis
    Last Post: 2011/07/22, 10:10 AM
  4. Cracked Chassis
    By Willies in forum Vehicle & Technical Chat - General
    Last Post: 2008/09/20, 06:29 PM
  5. Welding on Chassis
    By Andre N in forum General 4x4 Discussion
    Last Post: 2008/09/10, 09:02 AM
