Suzuki Jimny Lift Kit Available
Results 1 to 7 of 7
    Pretoorsdorp (Centurion)
    Thanked: 151
    Default Suzuki Jimny Lift Kit Available
    Hi All
    I am proud to announce my Suzuki Jimny 40mm Spacer Lift Kit
    The kit include the following:
    4 x 40mm Coil Spring Spacers
    2 x AmadaXtreme 40mm Longer shocks
    These shocks does not require any spacers or bushed to be changed and will add extra flex, articulation and stability to your Jimny!
    Complete kit as mentioned above on opening Special for R6000 -
    Exclude fitment & Transport costs
Name:	Jimny Spacer.jpg
ID:	257735   Click image for larger version.
ID:	257736   Click image for larger version.
Name:	AmadaXtreme Shocks with Specs.jpg
ID:	257737   Click image for larger version.
Name:	Suzuki Jimny 40mm Spacer Upgrade.jpg
    Last edited by Navigator; 2014/01/09 at 12:00 PM. Reason: Price of the Kit reduced to R6000
    WWW.AMADAXTREME.CO.ZA
    203 Edison Crescent, Weca 4x4, Hennopspark, Centurion, GPS: 25°52’19.0”S 28°09’59.3”
    Cobus Böhmer CEL: 071 641 7947 Email: cobus@amadaxtreme.co.za
    Oos Transvaal / Laeveld
    Thanked: 153
    How much for the shocks without the spacers? I already ot a 40mm lift kit.
    Thanked: 151
    Quote Originally Posted by SJC View Post
    Hi, the set of 4 shocks are going for R5000
    Thanked: 153
    Is it a gas or oil based shock?
    Thanked: 151
    The AmadaXtreme are oil based shocks - tested I've found much better to the "modern" technology gas shocks - the oil have better wheel articulation as there is no gas chamber on the bottom of the shock,
    Also more oil in the shock means better cooling thus the shock's performance stays constant for much longer.
    I can send you a load of links of clients that fitted these shocks on other vehicles that posted on the forum their feedback - just give me a bit of time to do so
    Quote Originally Posted by Navigator View Post
    Navigator, on the website, four shocks are R4000 are they different or is it just a error?
    http://amadaxtreme.co.za/product/suz...d-shocks-40mm/
    Ross
    Ross
    Thanked: 151
    Quote Originally Posted by hewhocooks View Post
    Ross
    Hi.... darn my IT has not updated the prices - I will honour the prices on the Website for this week for R4000 for the set. But thereafter unfortunately will be R5000 for only shocks and R6000 for the Spacer Lift Kit
  1. Jimny Lift
    By garyshell in forum Suzuki
    Last Post: 2012/05/28, 04:20 PM
  2. Replies: 7
    Last Post: 2012/01/10, 12:12 PM
  3. Replies: 15
    Last Post: 2010/12/29, 09:30 AM
  4. Replies: 61
    Last Post: 2009/10/06, 07:28 PM
  5. Cherokee Body Lift kit to accomodate 245/75/16
    By 4X4byFAR in forum Jeep
    Last Post: 2009/07/15, 10:03 AM
