Suspension W164 ML500 Air suspension failure and fix
Results 1 to 9 of 9
    Constantia Kloof
    Default W164 ML500 Air suspension failure and fix
    After 6 and a bit years the right front strut air-bladder started losing air. Not wanting to work the compressor too hard I started the search for a replacement strut only to find out it is quite possible to replace the bladder alone.
    I got into contact with Air Spring Supply Company in Jet Park who were able to supply the part, with instructions and special tools required for the princely sum of R5 130.00 incl VAT.
    Did the install this morning in less than 3 hours and the ML is fixed.
    Great stuff,
    How did you find the leak? Warning light?
    They also stock Arnott industries range.
    2013 ML500
    2017 Mahindra PIKUP S10 4x4
    2005 SLK55 (Speelding)
    1997 BMW Z3(Future father/son project)
    2013 BMW 320D Sport(Mom's taxi)
    Infanta 675Si r/duck with 150 V6 Yammie
    Jurgens Exclusive (Huisie by die see)
    Constantia Kloof
    Quote Originally Posted by Towatoy View Post
    Great stuff,
    No warning light. I saw the drooping front right suspension. The leak was quite slow, taking about two hours to sag.
    The new bladder is a Arnott industries unit.
    Mar 2012
    Thanks for that info Koebelwagen. I've got a 2009 Ml 350 CDi, and am not looking forward to a bill of over R20 000 to replace the front air spring when it goes.
    Any tricks regarding the fitment or things to watch out for?
    A private Merc workshop tried to tell me that one couldn't just fit the air bladder only, and one had to replace the whole unit (shock plus bladder). I would be interested to find out if this works for you in the long term. Would you mind getting back to this thread sometime in the future to report back?
    Ex 2009 Merc ML350 CDi
    Now 2011 Discovery 4 3.0 TDV6 HSE (Takla Seat covers with heated seats!)
    Constantia Kloof
    Quote Originally Posted by FO Gyro View Post
    Sure, will do.
    There are no tricks, the bladder comes with black and white photo illustrated instructions.
    You will need:
    Trolley jack
    Jack stands (You have to level the vehicle to disconnect the swaybar)
    10mm ring spanner
    13mm ring spanner
    17mm socket
    21mm socket
    24mm socket and spanner
    Power bar
    Ratchet
    Short socket extension
    Hammer
    Small flat screwdriver
    Needle nose pliers
    vise grips
    Set of torx bits
    Set of allen keys
    Clean motor oil to lubricate the o-rings
    Mar 2012
    Many thanks for the good gen.
    Mooi River
    Great stuff.
    Even better if you had taken a few pics of process and posted here.
    This forum then works as a reference manual for anything that needs doing.
    Sent from my iPhone using Tapatalk
    2000 Ford Courier DC 2.5TD 4x4
    2009 Fiat 500
    2001 Merc C200K
    2007 Disco 3 TDV6 manual
    Constantia Kloof
    Quote Originally Posted by Naami View Post
    Great stuff.
    The instructions that came with the bladder have great pictures and descriptions.
    I think you can download instructions with photo's from the Arnott industries website
    2013 ML500
  1. 2009 Discovery 3 -blown engine 89000km !!
    By McD23 in forum Land Rover
    Last Post: 2015/07/28, 10:39 AM
  2. Discovery 3 Fixing air suspension in the bush on a Discovery 3 / 4
    By Cats in forum Land Rover
    Last Post: 2014/06/17, 07:21 AM
  3. Land Rover - Engine Reliability - Top 10
    By Mojito in forum Land Rover
    Last Post: 2013/02/07, 02:18 PM
