Metalian Maxi super thread - Page 138
Page 138 of 152 FirstFirst ... 38 88 113 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 ... LastLast
Results 2,741 to 2,760 of 3024
  1. #2741
    Simon's Town
    Thanked: 270
    Default Re: Metalian Maxi super thread
    Quote Originally Posted by Heinz Modricky View Post
    Just some pics to show you guys our new tent with 270 degree awning. The mechanism is made in Cape Town, but the canvas work and some poles are changed in Australia to produce what must be the most successful 270 awning and trailer tent combination. Note that either component, the awning or the tent can be independently deployed, and when both are setup, they join up to form one unit with no folds, open gaps or leaks.
    The awning is on a lift bracket that swivels down to the rear. This is particularly good because it retracts the awning front from sticking out up front and shifts weight to the rear of the trailer, lightening the ball weight during travel. Also, when erecting the awning, more cover is given to the fridge area.
    Looks good, Heinz.
    Malcolm
    2015 Pajero 3.2 LWB
    Bushwakka Sundowner No. 31
  2. #2742
    Jan 2014
    Little Falls, Roodepoort
    Thanked: 32
    Is the tent and awning available as an option in SA as well?
    2008 Fortuner D4D
  3. #2743
    Bothasig
    Thanked: 14
    Very very nice!
    Well done Heinz
    '02 Patrol 3.0Di GL
  4. #2744
    Nov 2014
    The Far East (...Boksburg)
    Thanked: 69
    I've also added some updates to the kitchen, notably the new stainless steel lids and the side panel to the fridge. The fridge is now held down with fixings under the fridge and no longer requires hold down straps.
    Nice updates to the Metalian Heinz!
    + I really like the side panel at fridge. Option to put spices rack/bag there could be nice.
    + Fridge bolt down way better than straps.
    + Kitchen gas burners look same size now. 90deg turn chops off kitchen counter space though. My Swambo loves her counter space and not always happy about not being able to put two reasonable sized pans/pots on the old burners.
    + Those canvas shelf fronts and door caddies/bags are still the best ever (shout out to Jenny and Henk). Haven't see many other brands (eg Patriot) going this route yet.
    "Adventure is the distance between the present and the fulfillment of your dreams. How you navigate the in-between, is the great unknown."
    Platkar: 2002 Audi A4 1.8T 110kW Multitronic
    Swambo: 2014 Clio IV 0.9L 66kW Turbo Expression
    Camper Trailer: 2012 Metalian Maxi
  5. #2745
    Nov 2014
    Thanked: 69
    "Fixings for the fridge"? Is that just a NL baseplate or a more creative (less expensive) solution? I see re-positioning of the fridge gives the space for the fridge side panel.
  6. #2746
    Thanked: 692
    Quote Originally Posted by Honey Badger View Post
    It's no extra cost (or weight), I've put the same mounts into the fridge slide. Don't know why I took so long to do this.
  7. The Following User Says Thank You to Heinz Modricky For This Useful Post:
  8. #2747
    Thanked: 692
    Quote Originally Posted by Jan777 View Post
    With time. I can do the awning, but need to make up the tent. And no I'm not putting a time line to this. You know how slow I am to introduce new items.
  9. #2748
    Thanked: 692
    Note this is the Smev stove that we fit for Australia because it iis approved by their gas association. In SA we fit the Dometic CE99 model which is a bit smaller and can rotate 90 degrees and thereby provide more work surface. (Obviously we can alos fit the Smev for SA customers - it's also about a grand dearer.)
    The difference between the two is that the Smev has a higher burn rate and is fitted with a pizo starter.
    The mini cannot be fitted with a built in stove for Australia because the Smev is too big for the door. In this instance we provide a weber type kettle (braai) oven that fits into the rear of the trailer. It's a bit bulky, but was I surprised with this unit. They're very popular down under. I never understood why Patriot made a special place for such a kettle braai in their nosecone, but it makes absolute sense for their market and has a place here as well. You get water to boil very quickly, so it is efficient if you're boiling potatoes, etc..
  10. #2749
    May 2017
    All
    I am moving to Australia at the end of the year and unfortunately need to say goodbye to my trusted Metalian Maxi. Anyone interested can private message me or look at my add posted on Gumtree.
  11. #2750
    Thanked: 1952
    Thanks but those are not my canvas work, my ideas but copies
    Henk
    Follow us on Facebook
  12. #2751
    Nov 2014
    Thanked: 69
    [/B]
    This Honeybadger knows Henk. Just reminder to the unlearned eye where the idea originated.
  13. The Following User Says Thank You to Honey Badger For This Useful Post:
  14. #2752
    Nov 2014
    Thanked: 69
    Honey Badger, I'm sorry not to have seen your reply earlier (I don't get on the forum as much as I should). The simplest answer I have for you is that the "push-in" distance on the coupler is directly related to the travel distance of the brake lever, so the easiest way to check correct settings is to roll the trailer forward and apply the brakes - the brakes should lock in at 90 degrees. (I don't know if your handle has been modified - these days we cut this and reweld into a more downward position, so in this instance the lever won't reach 90 degrees.
    The other check is that in reverse the trailer brake should apply when the lever is deployed - if not - you have too much travel in the system and the brakes need adjustment. In very early model Metalians, the nosecone would limit this travel and the brake lever would bottom out on the nosecone before the brake could apply. I'll need to know more about your specific build to give your a 100% answer.
    All that said, I think that you possibly can't get the brakes to apply because you aren't pushing hard enough on the coupler to actually make an impact Just a thought.
    1. Eventually concluded that brakes needed adjusting since the coupler would run-in pretty much all the way when braking and we feel a gentle thud against car tow hitch. It's not the damper as that is still stiff to push in manually and it extends from compressed to extended in about 9 seconds (above 30 sec in DIY caravan instruction website means it must be replaced).
    2. Did the adjustment and drove around with webcam pointed at the coupler and Swambo on her laptop giving commentary. Coupler doesn't run in all the way now (maybe 70%) and I can feel the trailer braking better now. Brake drums warming up after some reasonably firm braking as one would expect.
    3. Resolved to visit Oom Henk in the very near future for a service, new brake pads and hands-on training on some things technical.
  15. The Following User Says Thank You to Honey Badger For This Useful Post:
  16. #2753
    Bothasig
    Thanked: 14
    Installed a gas-coupler into the van over the weekend:
ID:	500750   Click image for larger version.
ID:	500751   Click image for larger version.
    '02 Patrol 3.0Di GL
  17. #2754
    Thanked: 158
    @ Heinz, was wondering due to the box design of the trailer (without the nose cone) and some alteration, removing the load bin and fitting a maxi on a bakkie?
    Sought of like those Australian camper canopies.
    Hilux 2700i s/c 4X4 with a few extras ...............
  18. #2755
    Thanked: 692
    Quote Originally Posted by ismail View Post
    It's an idea, but with a sightly different design. The current trailer has a belly of 230 mm depth which you'd ideally like to remove, and the wheel arch makes the doors unpractical for a Ute tray.
  19. #2756
    Bothasig
    Thanked: 14
    So I decided to test the water system of the Maxi last night prior to this weekend's camp and I couldn't get any water out of the taps. I can hear the pump run, but no water ideas / suggestions / recommendations?
    Also, is there a special trick to fill the tanks? As soon as the water leaves the hose at anything more than a trickle, water runs out of the input opening.
    '02 Patrol 3.0Di GL
  20. #2757
    Fourways
    Thanked: 36
    Quote Originally Posted by Stefan View Post
    Ive had this before, there is most likely an air lock in the pipes.
    With the pump running, open the tap and suck with your mouth till water flows freely.
    Have seen Henks helper guy do it.
    As far as filling the tanks go's, patience is a virtue 😉
  21. #2758
    Lonehill, JHB
    Thanked: 834
    The other thing that does happen on these pumps is small tiny pieces of plastic from inside the tanks can block the pump, you need to remove the pump and take some covers off and carefully remove the flecks of plastic. Itís very sensitive but I did mine a few years ago and all good since.
    2014 Pajero 3.2DiD SWB
  22. #2759
    Bothasig
    Thanked: 14
    Awesome, thanks gentlemen!
    '02 Patrol 3.0Di GL
  23. #2760
    Florida
    Thanked: 639
    Does the Maxi have an external tap that you can get water from ie not via the pump? If so connect your garden hose to that tap, remove the filler cap and open the garden hose tap. This means that the tank will fill up from the bottom and expel air out of the filler mouth until the tank is full and water flows out.
  1. Trailer crashed, Namibia
    By Biggles in forum Trailers, Caravans, Towing etc
    Last Post: 2016/09/11, 08:39 AM
  2. Replies: 19
    Last Post: 2015/12/19, 06:10 PM
  3. Metalian Maxi for Rent from Kubu 4x4
    By Jannie Kubu4x4 in forum Commercial Member Adverts
    Last Post: 2013/08/12, 11:52 AM
  4. Can a closed thread be reactivated?
    By Eggie in forum The 4x4 Pub
    Last Post: 2013/06/09, 08:14 AM
